Question about Gateway Bestec ATX-300-12EB3 305w Power Supply (ATX30012EB3) Power Supply
No power how do I check or diagnose the power supply? Thank You
  • Gateway Master
  • 27,725 Answers
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
hope this helps also
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
hope this helps
Posted on Apr 05, 2011
Fronier invertor not working
please check the power supply of your TV,multimeter the export voltage of power supply.if it is defective you can replace it.
if not you need check main boards,and inverter boards
From Wisiny.com can find those parts,power supply,inverter boards and t-con
Dec 03, 2013 | Televison & Video
The tv had no power so I put a fuse in where the power cord is and it fries out when I plug it in. Its the same fuse that came out of there. Is there a - & + to the fuse.? thank you
There is no positive or negative polarity to a fuse. A fuse is just an in circuit protective device designed to blow when there is excessive current flow. A shorting transitor, coil or numerous other components in the power supply circuitry can cause this. Take power supply to television store, this will save you a fee from them having to come out, and have them diagnose the power supply, which they are good at. You might want to consider going online and ordering a new power supply.
Apr 03, 2011 | ViewSonic N2751W 27 in. LCD Television
Philips 42pf7621d/37 Will not turn on , red light blinks 4x.......I NEED HELP!!!!!!
have its power supply checked and diagnose by a qualified technician
Aug 18, 2009 | Televison & Video
Engine check light stays on
If the vehicle runs fine it could be your oxygen sensor. Some auto parts stores (like AutoZone) will diagnose the check engine light code free of charge. You could also buy a handheld OBD2 code scanner and diagnose the code yourself. The scanner plugs into a connector under the dashboard.
It's pretty simple to use. A descent scanner will run about $50, and you can use it to diagnose codes on all your vehicle's thereafter.
Jul 15, 2009 | Codegen 4063B-CA Black/Silver with 400W...
I have a hp pavilion 513c it wont boot up! the
There are only two ways this can go for you.
One- you need a new power supply
OR
Two, you need a new mother board
You can verify the power supply by checking it on another machine
If the power suppy is good
And you do not hear the bios beep- then you are looking at a new motherboard- I would double check the powersupply first- most stores that sell them will let you check before you buy a new powersupply.
Mar 26, 2009 | HP Pavilion 513c PC Desktop
Power supply light green but does not work
Check this site out it has everything you need to know about repairing the 360's and diagnosing such problems. http://www.llamma.com/xbox360/repair/Xbox-360-error-codes.htm My name is Tim Ehrhart and I hope this helps you out. Please leave feedback as I am new and trying to build a great rep. Thank You.
Mar 11, 2009 | Microsoft Xbox 360 Console
Power supply
Hello enirehtac
HERE is a link to HP's instructions for trouble-shooting power supply-related issues.
Please, follow the steps outlined there and post back here w/ the results, your observations, and any comments or questions you might have.
** Please, don't assign a rating to any of
** the experts' recommendations until your
** problem has been resolved or diagnosed.
** Once ratings are assigned, the problem
** will be closed and we won't be able to
** continue to assist you. We WILL keep
** working w/ you until your problem is re-
** solved or diagnosed.
Thank you
BJ @:)
Apr 11, 2008 | HP Pavilion A730N (PJ510AA) PC Desktop
Philips CRT Rear-Projection TV 64P8342
Something is preventing the power supply from operating:
Possible causes in order of likelihood:
1) Convergence amps failed overloading the supply (See if you can disconnect them)
2) High Voltage circuit has died. (Most common death mode)
3) One of the CRTs has shorted
4) The power supply itself has died (Is there a lot of dust covering it?)
See if you can isolate the failure by working down the list.
Hope Ya Fix it!
Feb 11, 2008 | Philips Magnavox 51MP392H Rear Projection...
Gateway Bestec ATX-300-12EB3 305w Power Supply (ATX30012EB3) Power Supply Logo
109 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
