We have a 2000 Olds Alero with a "check Vehicle Soon" light on and it is intermittent. When this light goes on (when starting up the car) the windows don't work and the fan doesn't work. Then eventually - after about a 1/4 mile - they work again, but the light stays on. Can you tell me what is happening?
  • flekke Apr 06, 2011
    I went to the site and no one had a problem like mine when filtering the selections to "Service Vehicle Soon" light. So much for this service. I didn't find it helpful.
    Brigadier General:
  • 7,191 Answers
You have posted the problem under "MP3 Players" section.
Kindly submit the question under 2000 Oldsmobile Alero section on the website by clicking this link so that the best car experts can view and post a solution to the problem.
On the page which opens, type the question in the "Ask an Expert" box on the right hand side of the page and click on "Ask a Question" button.
Thanks for using FixYa.
Posted on Apr 06, 2011
  • AliTech110
    AliTech110 Apr 06, 2011
    Thanks for the reply.
    Please re-submit the question by going to the link which I had provided earlier so that it is forwarded to the appropriate experts.
    On the page which opens, type the question in the "Ask an Expert" box on the right hand side of the page and click on "Ask a Question" button. (See attached image)
    Do not check the box next to "Get Immediate Assistance"
    Thanks.
How to install engine air filter "2000 Olds "
How many air filters does. A olds 2001 alero have
Mar 19, 2013 | 2000 Oldsmobile Silhouette
Will a sway bar from a grand am work in a olds alero?
I googled "Alero sister cars". It came back as Grand Ams. Same chassis, engines, and many other parts. They called it an "N-body" vehicle.
Nov 12, 2011 | 2000 Oldsmobile Alero
I have a 2000 Olds Alero that will not start, i have changed the oil, oil filter, spark plugs, wire set, alternator, belt, battery, fuel filter, o2 sensor, crankshaft sensor but my vehicle still will not...
I see you have changed many parts on vehicle, the only other thing that comes to mind is the timing belt. but that depends if its a four or 6 cylinder. some fours have the timing belt as to the chain. and also make sure you are getting spark from coils. but check the belt first. and make sure fuel pump is ok !! have a good day !!
Jun 07, 2011 | 2000 Oldsmobile Alero
Where is the map sensor located on a 2.4 2000 olds alero
on top intake plenum in the middle to the back.a sensor with small vacuum line with grey light green orange wires goes to it.check engine light will replace itsself after so many miles after changeing if light is on it will go off also if your check engine light isnt on then i wouldnt replace this part if it were bad check engine light would be on
Dec 11, 2010 | 2001 Oldsmobile Alero
What is the most common cause for the Anti lock, Trac off, and service vehicle soon indicators to stay on. Vehicle sat for a few months...
Broken wire from speed sensor to harness.
Had this happen on my 02 Buick Century and my 2000 Olds Intrigue
Mar 18, 2010 | 2000 Oldsmobile Alero
I have a 2000 olds alero, how do i reset the change moil light
If you mean the change oil soon light............ Open the fuse panel; on the side of the dash by drivers door. turn on key but not far enough to start car.
Press the red reset button in the fuse panel until the oil light flashes , release the button and then press it again.
It has been a while since I have done this on an alero , so if you have your owners manual , it might be a good idea to read the instructions in there incase i have it wrong. By the way , the low tire pressure light works the same way.
Nov 08, 2009 | 2000 Audi A6
Cant find the low pressure port to charge a/c on 2000 olds alero
It should be near the compressor on the low side line. It is a huge pain to get to. Feel along the line, and you should come to the fitting.
Mar 05, 2009 | 2000 Oldsmobile Alero
Service vehicle soon light is on, scanner at gm dealer read no codes. what all sensors activate this light. aso trac light is on. traction button(in stupid place) doesn't work
ok there is a difference between the check engine light and service vehicle soon light. The service vehicle soon light comes on when a bulb is out on the daytime running lights. Check your bulbs if there is one out and you put a new one in it will most likely take car of problem.
Jun 27, 2008 | 2001 Oldsmobile Alero
 Grubhead
Grubhead
