Question about Cycling
How do I rebuild the rear hub - Cycling
    Brigadier General:
  • 8,546 Answers
Rear tire stud holes striped on my mercedes 300td 87.what can I do to fix problem?
remove the hub and take to your local engineer they will rebuild it and thread it back to the original, please replace the bolts as well from a Mercedes franchise or check a scrapyard near you, they may sell you second hand hub with the bolts which is cheaper
Jul 02, 2014 | Cars & Trucks
To remove and replace bearings rear wheel
I love rebuilding hubs, here's a link to the process of overhauling hubs: Park Tool Co ParkTool Blog Hub Overhaul and Adjustment
Apr 02, 2014 | Trek 7100
Grease in rear wheel hub
The rear brake cylinders are located inside the hub with the brake shoes on drum brakes...(common in 2004 Rangers on rear only) The brake cylinders are a "wear item" with seals...we used to rebuild the cylinder with new seals...best today to buy new brake cylinders to replace the leakey ones...You will need to bleed all 4 brake line/wheel connections after the replacement. Hope this helps.
Oct 14, 2013 | 2004 Ford Ranger
Rear wheel hub replace
21 FU6RG CRT TV service codes
Aug 22, 2013 | AMC Cars & Trucks
How do i get information and diagrams on rebuild my 105 Hub
http://techdocs.shimano.com/techdocs/index.jsp
or "rebuild 105 Hub" in a search engine
or
http://www.parktool.com/blog/repair-help/categories/hub-service
Lots of instant gratification that doesn't involve a volunteer accepting the challenge,
Aug 04, 2011 | Shimano Cycling
The pedals on my sons green machine just keep going around without turning the wheel how do i fix this
Connect the cahin (kidding). The pawls, something along the lines of these (http://www.bikepro.com/products/hubs/hubs_ringle.html) inside the rear hub are probably shot or just stuck in a position that doesn't engage the cog to the innards. A shot of thin spray lube (NOT WD-40) might loosen things up temporarily. A new rear wheel is probably the only permanant fix unless you can get someone to tear it down and rebuild it cheaper.
How they do it on REAL bikes...
http://www.parktool.com/blog/repair-help/hub-overhaul-and-adjustment
May 19, 2011 | Cycling
I have a 1967 schwinn typhoon and problem is when i pedel the bike forward all the rear gear does is rotate, the wheel wont go with it and when i pedle in reverse it wont brake it just spins in reverse
Your rear hub needs to be rebuilt or buy a replacement hub or wheel. If you buy the replacement hub, you have to relace the spokes. I, myself, would opt to have a reliable shop to rebuild your wheel, find an older shop because they will know how to do it correctly.
Apr 15, 2011 | Cycling
Ineed to replace rear wheel bearings
Why do you say that? Did a professional bike technician tell you? You may be better off buying a new wheel unless you have the tools and the know how to rebuild your rear hub.
Sep 27, 2010 | Huffy 26in Ladies Sante Fe Cruiser Bike -...
Grinding when turning right or left from a stopped position
Losing turning radius is normal for 4x4. The grinding can be from hidden rear emergency brakes in back of rear rotors. The front pads can make noise and the front hubs should be checked if you do decide on replacing the front brakes.
Jun 30, 2009 | 2001 Ford F150 Styleside SuperCrew
Cycling Logo
62 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
