Question about Kenmore 24032\24036 Top Load Washer
Main belt Kenmore 70 washer
Old belt broke. How difficult/easy is it to replace? I've put in a pump before, but as I recall, I just fit pump pulley into belt. Thanks for your help
Washer wont agitate, #70
Posted on Aug 09, 2008
Replace power steering pump on 06 chevy uplander
I just finished replacing mine.
It is much easier if you do these steps:
1. Remove the serpentine belt.
2. Remove the nuts holding the main fuse box over the battery.
3. Remove the reinforcing bar over the battery.
4. Remove the battery.
5. Remove the windsheild washer tank.
6. Now you have access to remove the pump pulley. Without removing the stuff, it may be possible, but it will be extremely difficult.
7. Remove the pump pulley.
8. Loosen the high pressure hose fitting.
9. Remove the return line clamp.
10. Remove the power steering pump mounting bolts.
11. Remove the high pressure hose fitting.
12. Remove the power steering pump while sliding off the low pressure hose.
13. Remove the clips holding the reservoir on the pump.
14. Remove the reservoir.
15. Install new o-ring on the reservoir.
16. Install reservoir on new pump.
17. Install clips to hold reservoir on pump.
18. Install new o-ring on high pressure fitting.
19. Place new pump in position while sliding on low pressure hose.
20. Loosely attache high pressure fitting.
21. Tighten pump to mounts.
22. Tighten high pressure fitting.
23. Install clamp on low pressure hose.
24. Install power steering pulley.
25. Install washer reservoir.
26. Install battery.
27. Install reinforcing cross member.
28. Install fuse panel.
29. Install serpentine belt.
30. Bleed the power steering system.
Jul 08, 2012 | 2006 Chevrolet Uplander
Maytag centenial won't spin
Your going to check the belt and pulley inside the machine but let me warn you first, this is a knuckle busting nightmare of a machine, and if your not fond of the idea of bleeding, grease and pain, call a repair company. I'll post a few examples to help you make your mind on the topic.
Belt wore out
Had to remove pump-not easy. Nothing wrong with pump, but had to trash it to get it off the motor shaft, so I had to replace it, too.
Pop up top of cabinet and remove front panel. (I leaned unit back against a wall to facilitate internal access once panel was removed.)
Remove motor assy - 4 screws & connector.
Remove 3 pump screws (torx) and 2 hoses. Pry pump off motor shaft (not easy). I used a heat gun to help expand the plastic fitting on the motor shaft.
Remove old belt, put on new belt. (Do not use automotive belt-this belt is designed to slip because it also spins the tub. The tub will not spin when it's full of water, and the pump will not pump the water if the tub is bogging down the pump. Plus, you will probably overheat the motor.)
Press new pump back on motor shaft (advise not to re-use old pump as seals were probably damaged by removal process.)
Caution: Pressing pump onto motor shaft may cause pump rotor to bind in housing. Try to press it on a little too far so you back off slightly.
Replace pump screws.
Replace motor, giving attention to belt alignment.
Replace motor screws and connector.
Re-attach hoses on pump.
Button up cabinet.
Done.
The hardest part was removing the pump. If not for that, it would have been a 15-min, $20 repair.
Because I felt it wise to replace the pump also, it was a $70 repair.
#2
Drive pump leaked
It took some trial and error but overall not a difficult project.
1. Take the front covers off.
2. Undo the pully spring to loosen belt
3. Remove belt off idler pulley wheel and free up belt from the large wheel.
4. Disconect the wiring harness and the hoses.
5. Undo the motor mounting bolts (4)
6. Take motor out of washer and remove the 3 screws holding the pump to the motor.
7. The pump had melted to the shaft and required I chisel the pump off of the shaft.
8. Attach new pump paying attention to where the belt is positioned.
9. Reattach the motor bolts, hoses, and wiring harnes.
10. Attach the belt and test the pump.
11. Put the front back on
Jun 17, 2012 | Maytag Washing Machines
I have a 13 year old Neptune MAH3000AWW. I've done the wax motor/circuit board fix a couple of years back satisfactorily. Now I have a sound that sounds to me to be a slipping belt noise. Is this a...
No its not hard to replace the belt at all..just remove back access panel and roll the belt off of the main pulley..place the new belt onto the motor pulley and roll it onto the main pulley..the whole job should take about 10 minutes and 5 of that is getting the tools out
GENE
This video is for a different brand front loader belt replacemant but the process is exactly the same
http://www.youtube.com/user/RepairClinic?v=a8jRgOn1wGY&feature=pyv&ad=8842436861&kw=belt
Aug 27, 2011 | Maytag Neptune Washer
I have a Kenmore 70 Series Dryer and the belt broke. I ahve since ordered the replacement belt, but am uncertain how to replace it. Is there somewhere I can view a diagram of my dryer so I know where the...
pulley fits into slots in bottom of dryer near motor pulley. idler pulley will be to the left of motor pulley looking at it from the front. loop belt thru idler and place around motor pulley.
Jun 26, 2010 | Dryers
I am having trouble replacing my belt on my Kenmore 70 series
i've got them down to 10 minutes, but here goes. remove the bolts going into pump, but do not remove pump . remove the transmission bolt with the spacer and this is where you push the belt through and around pulleys.. this is a little more difficult. you will need to take off the yoke spring and move the transmission pulley around until the spin control magnet catches for spin. it will begin to take pressure off of clutch. you will need a long screwdriver or something like it to apply pressure down on the clutch plate this is to allow to to slip the belt thru the bar the spring came off of and under it.. you can then pull the belts around all pulleys and put everthing back in its place and your done...
Jul 18, 2009 | Kenmore Washing Machines
Belt replacement on kenmore washer
One of the transmission bolts has to be removed to be able to remove the 1" spacer . You also have to turn the pulley which moves the wig-wag to move the glide foreward to drop the shaft of the drive. Very difficult unless you've done it before .
Jul 07, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore series 70 washer will only fill with water.
I recently had this problem. It was found that the main drive belt broke and the washer would fill but not spin, agitate or drain. I replaced the belt and everything worked again. A defective or disconnected cover switch would also cause the same problem.
Jun 30, 2009 | Kenmore Washing Machines
How difficult to replace belt for front load clothes washer Kenmore 8 years old? I'm an average handyman.
the belt is held by pulleys, there is an ajustment bolt loosen this (should be marked) to loosen the belt. some models have a frame bolt that must be removed to get the belt off. this repair should be fairly easy to do.
Apr 21, 2009 | Kenmore 22422 Top Load Washer
Kenmore 70 series washer
check securing bolt on adgitator sometimes the bolt will strip out in main stem may need to tap out and fit new bolt
Mar 14, 2008 | Kenmore 22422 Top Load Washer
Washer water not draining
Your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley you should remove the pump from the washer and try to rotate its pulley manually. If it doesn't turn freely (frozen or stiff) it should be replaced. In case of a broken pump's belt or belt looks quite worn, replace it. In any case, check the pump's pulley before you replacing the belt. Let me know if you need for further assistance. Good luck
Sep 10, 2007 | Washing Machines
Kenmore 24032\24036 Top Load Washer Logo
62 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
