I just hooked up my Flat TV to my Panasonic VHS-DVD recorder player and the screen only shows blurry Black and White when displaying or recording, The TV itself is fine.
  • dfwcrow Apr 06, 2011
    I do have a New Sony TV and don't know if Composite or Component, I'm hooked into the component with my three colored cable and don't know how to get into the user menu, can't find the two composite or component to change over. I'm not a very good 79 yr old tech. New system to me.
    I don't understand the cable colors references. To what TV or Recorder. Where is User Men? What cable colors to what units?
  • 760 Answers
Sounds as if you hooked up your player wrong. If you are using a composite hook up. You should have a yellow, red and white cable. Make sure it gets hooked into the same on the TV. If it is a component connection, then RED, Green and Blue. It sounds like you have your Yellow composite going through your Green component. If by chance your TV is a new Sony, then you might have to go into the user menu and turn component off and composite on.
Posted on Apr 05, 2011
Testimonial: "Many. Many thanks for your latest info that got me to finally figure it all out. Three machines are all correctly plugged into my Flat Panel Sony TV. "
  • 1 more comment
  • David Duncan
    David Duncan Apr 07, 2011
    All I can say is take your blue cable. Hook it in your blue hole on both TV and player. Same with Red and green. If you still can't get it figured out, I am sure someone you know can help you out. Sorry if I can't be of anymore help.
  • dfwcrow Apr 07, 2011
    Thanks, dduncan774. Please show step by step to User menu.
  • David Duncan
    With your remote press your Home button
    With arrow keys, scroll down to Set up and press button in the middle of arrows
    With arrow keys, scroll down to where it says video 1 composite/component and press button in middle of arrows
    With arrow keys press up or down until you highlight which hook up you are using. Red green and blue would be component. Yellow White and red would be composite and then press button in middle of arrows.
    Press return or exit on remote and you will exit menu
How do I hook up a combo vhs dvd player/recorder to my tv?
The AV OUT on your DVD player must go into the corresponding AV IN[PUT] on your TV.
Jan 19, 2015 | Panasonic Televison & Video
I have a Panasonic DMR-ES30V. I've only ever recorded from what I'm watching on the TV to a DVD. I now have a VHS tape that I'd like to record to DVD. I tried starting the dvd to record...
Most Combo Recorders (VHS and DVD) will prevent you from
recording a Copyrighted VHS tape program onto DVD.
Try recording a TV program onto your VHS tape, then
transfer it to your DVD and see if your new DVD recording
will work or not.
Jul 16, 2011 | Panasonic DMRES30V DVD Recorder/VCR Combo
I have a Digistar flat screen TV mod # LC32U5D Was a demo in Walmart - came with no manual - Have a vhs/dvd combo unit hooked up to it with a 3wire set up - can watch TV no prob - can watch dvd or vhs no...
you have to send the video and audio from the tv set to the inputs on the VCR recorder (it should be labeled "IN" there will be one yellow, one white (or black) and one red connector. without these cables hooked up, your recorder has nothing to record from.
Mar 10, 2011 | Televison & Video
Can't record from camcorder to VHS tape on LG Model VCR
ok,uve gone OUT of cam and IN to VCR player?,then press play on cam and record on VCR,u should see whats recording as long as your on your normal video channel
Aug 17, 2009 | LG V181 DVD Player/VCR
DV220MW9 DVD/VCR: won't record video on VHS
your cable tv connect into dvd/vcr,video/audio out connect to av in your tv,solved
Jul 06, 2009 | Philips Magnavox DVD/VCR Dual Player
Plays vhs tape in only black and white (no color).
my old series of ROOTS is playing in black and white and says on cover that they are in color
Jul 03, 2009 | Samsung DVD-VR375 DVD Recorder/VCR
Connect DVD recorder to Video player/recorder- transfer VHStodisc
hook the video output from vcr to dvd input at rear, then hook output from dvd to tv input. note; you can not record protected vcr movies you can only record tv shows from sattelite to vcr or dvd recorder. its best to record straight from sattelite to dvd recorder for picture clarity.
Jan 27, 2009 | RCA DRC8300N DVD Recorder/VCR
Panasonic DVD Player only plays in black and white
have you tried swapping the scart lead socket on the back of the dvd vcr i had this problem and i found out i was using the wrong scart socket make sure you are using the t v scart and not the
decoder one
cheers
Dec 13, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Hooking up my DVD/VHS player to TV & Convertor box
I would just hook up the dvd/vhs player with the red,white,yellow rca cables that should of come with your unit and just go to the input on the tv to watch your dvd/vhs player. This will give you a better picture and sound while allowing you not to have to watch dvd/vhs on a channel which helps make the dvd/vhs player independent. Also if possible I would hook the converter box up with the red,white, yellow rca cables to the tv as well if your tv has more than one set of red,white,yellow plugs since it is a better connection that coax and you probably watch more tv than vhs/dvd anyway. So bottom line try to hook up both boxes red,white,yellow and watch each box on different inputs instead of like channel 3 or 4. Also to record of converter box you can run coax from converter box to dvd/vhs combo and make sure your dvd/vhs player is on tuner input or channel 3.
Nov 16, 2008 | Insignia Digital-to-Analog Converter for...
Televison & Video Logo
119 people viewed this question
Top Televison & Video Experts
