Question about Goldstar R8000 Air Conditioner
HOw to get off front cover - Goldstar R8000 Air Conditioner
Close Front Cover For Toshiba E-studio 350
There are many possibles that can cause "Close Front Cover"
Check the front cover actuator, switch. If all covers, switches is working fine, probably power supply is faulty.
Dec 02, 2015 | Toshiba e-Studio 350 Copier
Need to remove front panel located under the filter cover
Press around the panel edges while pulling back. There are probably plastic clip locks that need to be depressed to unlock. Flex carefully, taking care not to break the plastic cover.
May 13, 2015 | Samsung AW1293L Air Conditioner
Kyocera Mita KM-2530 error close front coveR
The front door switch or actuator is broken or the door may be warped .Have you tried putting pressure on the front cover? as this may help to indicate if the switch is faulty.
Sep 10, 2012 | Kyocera Mita KM-2530 Laser Printer
How do i remove the front cover from my nokia c3
Sir please open the back side cover of your phone and there you will see four small lock of front cover press backward the lock front cover will be removed automatically go do it..'
bye
Aug 19, 2011 | Nokia Cell Phones
How do you time a 350 gmc motor
4.8L, 5.3L and 6.0L Engines
    • Locate the camshaft sprocket alignment mark in the 6 o'clock position and install the camshaft sprocket and timing chain
    • Camshaft sprocket bolts and tighten the camshaft sprocket bolts;
      1. Torque to: 26 ft. lbs. (35 Nm)
    • Oil pump
    NOTE: Do not lubricate the oil seal sealing surface.
  1. Lubricate the outer edge of the oil seal with clean engine oil.
  2. Lubricate the front cover oil seal bore with clean engine oil.
  3. Install the crankshaft front oil seal with a suitable seal installer. NOTE: Do not apply any type sealant to the front cover gasket (unless specified). Special tools are used to properly align the engine front cover at the oil pan surface and to center the crankshaft front oil seal.
  4. Install the front cover gasket, cover, and bolts onto the engine.
  5. Install the front cover-to-oil pan bolts and do not overtighten.
  6. Tighten the cover bolts finger tight and do not overtighten. J41480 installation-4.8L, 5.3L & 6.0L 9308kg59.gif
  7. Start the J41480 or other suitable tool to front cover bolts but don’t tighten the bolts yet. NOTE: Align the tapered legs of the tool with the machined alignment surfaces on the front cover.
  8. Install tool J41476 or other suitable tool.
  9. Install the crankshaft balancer bolt and tighten the crankshaft balancer bolt by hand until snug but do not overtighten.
  10. Tighten the J41480 bolts and front cover bolts;
    • Torque to: 18 ft. lbs. (25 Nm).
  11. Remove the tools. NOTE: Place a straight edge across the engine block and front cover oil pan sealing surfaces. Avoid contact with the portion of the gasket that protrudes into the oil pan surface. Insert a feeler gauge between the front cover and the straight edge tool. The cover must be flush with the oil pan surface or no more than 0.5 mm (0.02 in) below flush. If the front cover-to-engine block oil pan surface alignment is not within specifications, repeat the cover alignment procedure. If the correct front cover-to-engine block alignment cannot be obtained, replace the front cover.
  12. Snug the oil pan-to-cover bolts in order to position the cover at the pan rail.
  13. Tighten the oil pan-to-front cover bolts;
  14. Tighten the front cover bolts;
  15. Install the crankshaft balancer and bolt (See: Crankshaft Damper).
  16. Install the water pump (See: Water Pump).
  17. Fill the engine to the proper level with oil.
  18. Fill the engine to the proper level with coolant.
  19. Test drive the vehicle to confirm the repairs.
6.6L Engine To Remove:
NOTE: The 6.6L engine uses gears in place of a timing chain. For removal and installation, please see the Camshaft and Lifters procedure. This procedure covers the removal of the front cover and seal.
  1. Before servicing the vehicle refer to the precautions at the beginning of this section.
  2. Remove the upper intake manifold sight shield as follows:
    • Remove the retaining bolt in the front of the shield
    • Lift up on the front of the shield, then lift the shield off the rear bracket
  3. Drain the cooling system.
  4. Remove or disconnect the following:
    • Negative battery cables
    • Right front wheel
    • Right front fender splash shield
    • Upper fan shroud
    • Fan clutch (See: Engine Fan and Clutch)
    • Drive belt
    • Oil dipstick tube
    • Thermostat housing crossover
    • Crankshaft damper (See: Crankshaft Damper)
    • Crankshaft front oil seal
    • Water pump (See: Water Pump)
    • Camshaft sensor electrical connector
    • Camshaft sensor bolt and sensor
    • Crankshaft Position (CKP) sensor connector, bolt and sensor
    • CKP sensor spacer bolts and spacer
    • 5 bolts securing the upper oil pan to the front cover
    • Bracket bolts and the bracket for the turbocharger outlet coolant pipe
    • Engine front cover bolts
    • Use a suitable seal cutter to separate the front cover from the cylinder block and upper oil pan NOTE: Do not bend the turbocharger outlet pipe.
    • Oil pressure relief valve from the front cover
To Install:
  1. Clean and inspect all sealing surfaces.
  2. Install or connect the following:
    • Oil pressure relief valve with a new O-ring and tighten the valve
      1. Torque to: 30 ft. lbs. (41 Nm)
  3. Apply a 1/8 in. (2-3mm) wide to 1/16 in. (0.5-1.5mm) high bead of sealant to the front cover sealing surfaces to the engine block and oil pan.
  4. Install or connect the following:
    • New front cover O-ring after lubricating it with engine oil
    • Front cover and bolts and tighten the front cover bolts
      1. Torque to: 15 ft. lbs. (20 Nm)
    • Upper oil pan-to-front cover bolts and tighten the bolts
    • Turbocharger coolant outlet pipe bracket and bolts and tighten the bolts
      1. Torque to: 15 ft. lbs. (20 Nm).
    • Camshaft sensor and bolt and tighten the bolt
      1. Torque to: 80 inch lbs. (9 Nm)
    • Camshaft sensor connector NOTE: The CKP sensor spacers are machined with different timing positions. If you have to replace a spacer, make sure it has the same part number.
    • CKP sensor spacer and spacer bolts and tighten the bolts
      1. Torque to: 89 inch lbs. (10 Nm)
    • CKP sensor and bolt and tighten the bolt
    • Oil fill tube
    • Drive belt
    • Upper fan shroud
    • Right front fender splash shield and wheel
  5. Refill the cooling system with the proper type and quantity of antifreeze.
  6. Inspect the engine for leaks.
  7. Test drive the vehicle to confirm the repairs.
Aug 27, 2010 | GMC Sierra 1500HD Cars & Trucks
Can't send faxes , keeps saying document jamed
Open the front cover by pulling it towards you (that is the cover where are the digits and other function keys), see if any paper has inside and than close the front cover and press the " Stop " button.
Remember if you do not close the front cover good the message will still appear on the screen because the machine thinks that the cover is not closed. That happen because of the sensor on the front cover which detects do the front cover is closed so check dose the door is good closed. If your machine do not pull the documents in the " document feeder " than open the front cover and you will see pair of rubbers inside, clean them with alcohol or glass cleaner and clean peace of cloth.
Jul 03, 2009 | Brother IntelliFAX 770 Plain Paper Thermal...
How do I remove the front cover of a nokia 7360
Gently slide your fingernails between the grooves of the front cover and the middle base. The front cover should come off easily as the front cover is only held by clips.
May 26, 2009 | Nokia 7360 Cellular Phone
Need to replace the front bumper cover on a 1995 ford escort
its just the bumper cover.. once you buy the bumper cover it will replace your broke one,, however you my need to buy a bumpercover support..i think its only about $30 more..good luck keith...
Mar 15, 2009 | 1995 Ford Escort
Close front cover
THERE IS A PROBLEM WITH ONE OF THE COVER SWITCHES. EVERY COVER HAS A SWITCH, ONE OF THEM MAYBE STUCK, BROKEN, OR MISSING. GOOD LUCK.
Jan 12, 2009 | Toshiba COPIERS E-STUDIO 520 Copier
"Offline"
which cover are you opening? You must pull open the bottom cover not the one under the keyboard. It's the bottom front cover not the top front cover.
Sep 26, 2007 | Brother IntelliFAX 4100 Laser Fax
Goldstar R8000 Air Conditioner Logo
20 people viewed this question
Top Goldstar Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
John Tripp
John Tripp
Are you a Goldstar Heating and Cooling Expert? Answer questions, earn points and help others
