Question about Vacuums
KIES SAMSUNG GALAXY TAB GT-P1000 VERSON 2.6.32.9
Purchased vanity light galaxy while instructins are clear for black and white wires it also has a green and yellow wire is this just a ground wire
The green and yellow wire is indeed the earth wire, black is the live wire and the white is the neutral for US connection. Please rate this solution.
May 22, 2011 | Galaxy Vacuums
Unsupported file type is shown in my samsung GT s5600 when i want to install any apps
Hi asma faria,
Unsupported file types means that your software is not able to read the file you are accessing. Usually, this means that you need software that can handle the extension used by this file or a codec that can read that particular file.
For example, If you receive a picture in your email that was made with photoshop, you probably would not be able to see it if you don't have photoshop on your computer.
In your case, I would say you need to upgrade the software on your phone so it can handle the apps you want to install.
Hope this helps. If it does, I'd appreciate a 4 thumbs up. Thanks,
Handie Andie
Apr 27, 2011 | Samsung Vacuums
How do I make the printing darker? looks like it needs ink...but how can that be?
you have posted the question in wrong section it should be in printers
as for your problem
there is option in
1. go to start button of windows desktop
2. then setting > control panel >printer & faxes in sub menu
3.a printer icon shall be displayed
4. select properties
a new window with tab will open .. from there select your printer page ink settings
do comment if it helps or not??
Apr 05, 2011 | Vacuums
I have a samsung galaxy europa, i get repeated messages 100s of times (no exagerating) i cant get a replacement as i have had the phone unblocked, it was happening before i got it unblocked too, is there...
glad im not the only one i have the same problem with mine but it just seems to be o2 numbers, i have taken it back to the shop, and they i have changed the sim card about 3 times and they sent it off to samsung and they apperantly changed the handset and i still am having the same problem, they are now saying it is a fault with samsung and they are working to get a new softwear to solve it, so we just got to wait!!
Mar 04, 2011 | Galaxy Vacuums
Cannot turn off ***>>? alarms!
need more info. what make and model and what alarms ?
Feb 03, 2011 | Vacuums
I have a galaxy obsession deluxe 9.5 kw shower which will run for a little while but then trips the fuse, what could be causing this to happen?
your cable supplying power is not correctly sized for the shower causeing it to overheat and trip the fuse, or your main board fuse isnt matched to the power of the shower
Dec 19, 2010 | Galaxy Vacuums
Why don't you CLEARLY show where you need to Register your Warranty when it says to visit this page>>>>>>>>>??????????????????????????
because this is a Help Site ... not a warranty registration site ... go to the site for your machine manufacturer for help with this.
you are at the wrong place.
Jul 31, 2010 | Vacuums
Doesnt pick up water
Possible Causes Remedies
ReadyTools Dial may be at the wrong setting for the cleaning job <> Set ReadyTools <> Dial to either Tools / PreTreat or Floor Cleaning.
Nozzle Window may not be properly attached. <> Press down firmly on the black oval gasket at the top
Window to make sure the two tabs on the back of the Nozzle Window are snapped into the mating slots in the main housing.
Tank-in-Tank lid is not installed <> Re-install lid;
Tank lint filter is blocked <> remove all lint and debris from Tank lint screen.
Tank-in-Tank is not properly seated. <> Tank-In-Tank must be firmly seated to function; remove
and reseat Tank-in-Tank.
Poor tool position (Hand held attachments only). <> Adjust angle; apply more downward pressure.
Tank-in-Tank has picked up maximum dirty water <> Empty Tank-in-Tank
Front Clear Floor Nozzle Window ids blocked <> Remove window and clean all fibres and debris then replace.
Insufficient suction <> Clean Pre and Post Motor Filters.
Sep 28, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
No solution is spraying out when i press the trigger
I had somewhat the same problem.... I had water comming out but the solution was not comming out.... I called bissell and the woman talked me through it.... first put in water only mode,,,,, then Fill water tank with fresh water and put back in place,,,, then remove soap dispenser put to the side,,,, now , power on your cleaner,,,, for the next steps, do this exactly as I tell you >>>>>>hold down the trigger that releases soap the whole time you do the following>>>>>> switch between water only and heavy traffic four times,,,, all while while holding the trigger, then still holding the trigger, stop on high traffic the fourth time, leave it there,,, now put the soap bottle back in,,,,, still holding the trigger and hold the trigger down for exactly one minute after you replace soap bottle,,,, you should start seeing the soap come out........ (make sure its on floor cleaning and not TOOLS) Hope this helps and if it does,,,, give these instructions to someone else in this help area.........
Jul 04, 2009 | Bissell 8910 ProHeat Clear View Upright...
Vacuums Logo
220 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
