Question about True T23 Refrigerator
Will not mailtain 40 degree,everything no matterwhat .temp guage read at 10 degraa.
  • 794 Answers
Hi joonshikchoi,
This means that you need to install a new thermostat since the one that you have is already defective
that's why you cannot maintain 40 degrees. You can purchase a replacement on this link.
Hope it helps.
Thank you for using Fixya.
Posted on Apr 05, 2011
I have Kitchen Aid french door fridge with large temp fluctuation. Please help
Clean your coils first, if they are dirty from dog hair or lint in general it will overheat compressor and cause temps to fluctuate
Oct 17, 2016 | Refrigerators
I replaced my temp sensoe and it reads ccd
Hi Glenn, I'm glad to help! Here's how you check the Ambient Temp Sensor circuit itself to see if its working properly. Disconnect the Ambient Temp Sensor Connector. If the temp reading go to the default mode it will show 40 degrees. If it doesn't go to 40 Degrees then thyere something wrong with the system. Could be wiring or display itself. If it does go to 40 degrees then I'd try another sensor and see what happens. Hope this helps and have an awesome day Glenn.
Apr 11, 2014 | 2001 Dodge Ram 2500 Truck
I know it uses r 22 but what should the low side presure be
This depends on the outside temp . But a suction pressure of 55-65 is good. If you are using a set of guages and you read the outside of the guages scale you will see a temp scale you need to have the suction pressure set to about a 40-45 degree temp on the scale. Be certain that you purge a bit of gas when hooking up your guages or you will allow iar inot your system and it will make matters worse.. Hope this helps let me know.. Jon
Aug 01, 2011 | Heating & Cooling
I need to charge my ac system on my 1999 chevy s-10, what should the readings be on the ac manifold gauges?
With engine running, A/C on max and blower on full speed.
Allow 5 minutes running time like this for system to fully circulate.
Attatch guage to low pressure port.
At 80 degrees outside temperature, you should get between 45-50PSI reading on guage for a full charge. If you have a good reading like that and your A/C is not blowing around 36-40 degree air, most likely you have air in the system. Then a complete discharge of refrigerant in the system and full re-charge is indicated.
Mike
Jul 09, 2011 | 1999 Chevrolet S-10 Pickup
Please, tell me what temperature suppose to be in ref. and freezer compartments.
Hello Leo.
The general rule is 0 degrees F in the freezer, and 40 degrees F in the fresh food section. The temps are best measured with a temp guage in a liquid. Digital guages are usually more accurate than analog. But, use what you have available, and if you can't quite believe the readings, ie ice cream is frozen, milk is good and cold, then move up to a better temp guage. Or, if you have two or three different ones, put them all in there and use the average.
If you think temperature adjustment is necessary after testing, make it very small and wait for a day to take another reading.
Hope that helps you.
fil
Mar 03, 2011 | Dacor Epicure EF48BDCB Stainless Steel...
Oven does not maintain a consistent temperature
Is this oven gas or electric? If it is gas then it can be normal to see 30 to 50 degrees difference in tempature. The tempature in a gas oven works on the average tempature. For example: The oven tempature may rise all the way up to 370 degrees. Then the burner will shut off. And then the tempature can drop all the way to 330 degrees. Then take 330 and add that to 370 then divide that number by two and the average tempature will be 350. If your oven is electric then the tempature should be much more consistant but can have a 10 to 15 degree variance. Also the standard oven tempature guage that you put in the oven or even the temp guage built into the oven are not very accurate. We us a Fluke meter with a thermocouple to calibrate an oven. So to check your oven for proper tempature regulation you will first need to let the oven pre-heat for about 15 minutes. Then place the thermocouple in the center of the oven. If the oven is electric the take a temp reading every 5 minutes and average them out. If the oven is gas then you will need to take a temp reading when the tempature reaches it's highest and lowest points. Take at least 5 consectutive readings and average them out. You should get an average within 10 degrees of set temp(350 degrees). If it is off by 35 degrees or less you can usually caluibrate the thermostat back to proper temp. This procedure can be different for each range model. If it is more than 35 degrees off or you are getting irratic readings then the thermostat or thermostat components might need to be replaced.
Mar 16, 2010 | Kitchen Ranges
I have an 2008 Xciting 500 that will not start when it is below 40 degrees. Any solutions?
kymco 500 has no air temp sensor,ecu reads water temp for coldstart enrickment.a new sender wont fix it ether,sender needs to read 10 degrees warmer to start
Feb 21, 2010 | 2005 Kymco Xciting 500
The temperature gauge on my 2002 grand prix dose
the temperature sending unit on a 97 grand prix 3800 gt(which is also the coolant temperature sensor) is not accurate. the sending unit part of this sensor only sends info to the guage on the dash. the coolant sensor part sends info to the computer of the car. it is located under thermostat and somewhat difficult to get at. i had put a brand new one in and my temperature on my dash is all over the place---even with good thermostat and properly bled system. when i hook up a scanner to my computer, the coolant sensor is sending the computer(ecu??) what seems to be the right temp. anywhere from 194 degrees to 217 when hot. the guage however on dash go from 160 to 260 in less than 2 minutes.
Nov 16, 2009 | 2002 Pontiac Grand Prix
True T23 Refrigerator Logo
165 people viewed this question
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a True Refrigerator Expert? Answer questions, earn points and help others
