Question about Lexmark Wheelwriter 1500 Typewriter
The left margin is stuck and the release margin works only the first time after turning on the typwriter. I can set the margin at a point on the left side, but after a few times of hitting the return key, it just goes to the middle and that becomes my left margin. If I hit the release margin key, it doesn't work. And if I type all the way to the right margin, and hit the return key a few times, then it will lock about 4 inches from the last margin. Every time I type to the far right, it will lock at some point and not hold the far left margin I set. I went to lexmark.com and clicked on support and dowload but they don't have this typewriter: IBM Wheelwriter 1500 by Lexmark. I think it's an old model, I can't find a model number that starts with a letter; all I could find was 1364816. Hope this helps.
  • Lexmark Master
  • 3,594 Answers
Put a shot of WD40 on both sides of the silver shaft that the carroer slides on. If that doesn't do it put some on the carier motor bearings. The front one can be reached from inside of the T/W the rear one yuo will have to remove the case of fish the straw thru it. The motor is located on the R. rear corner.
DickyO
Posted on Apr 05, 2011
How do I set or change the margins on my Royal Safari typewriter?
If you are following user's manual instructions to reset the margin and can't, maybe your Royal Safari is defective? Insist trying and if still no luck try to ge a typwriter repairman, a species in near extintion by now.
Jul 02, 2015 | Royal Office Equipment & Supplies
My Nakajima AE-710 margin release does not work. How can I reset to factory settings?
When using the margin release DON'T HOLD IT DOWN just press and release. if this dosen/t work turn off the machine and see if the carrier will move both ways relatively freely if not look fot debris and spray a little WD40 on the silver shaft that it slides on.
DickyO
May 08, 2012 | Nakajima AE-710 Typewriter
I can't get the left margin to stay. I set it and start typing to the far right and after a few returns, it locks right in the middle. I then use the margin release key and it will but only the first...
DickyO
Apr 05, 2011 | Lexmark Wheelwriter 1500 Typewriter
How do i set the right & left margin on my Swintec 2640 electric typwriter?
Go to the margin, touch but don't hold the mar rel key, space or backspace to desired location, perss L. or R. key.
DickyO
Feb 02, 2011 | Swintec 7040 Typewriter
The return is stuck on 80 on the guide. I cannot
Turn the T/W off and slide the carrier back and forth. If it goes to the left then you have the L. margin set at 80.
Return to the margin, press and release the margin release key, backspace to the desired location, press the L. margin key.
DickyO
Mar 18, 2010 | Nakajima AE-710 Typewriter
Setting nargins
The keys used for margin control on the brothers is the ALT key just to the left of the space bar, and the #3,4,& 5 keys.
To move outside the present margin to the left, backspace to the left margin. Press the ALT and '3' keys at the same time to bypass the margin. Back space past the margin to the point where the margin is to be set. At the point you want the new left margin, press the ALT and '4' keys at the same time to set the new left margin.
To move outside the present margin to the right, spacebar over to the right margin. Press the ALT and '3' keys at the same time to bypass the margin. Then spacebar over to the point where the new right margin is to be set. Press the ALT and '5' keys at the same time to set the new right margin.
The basics are that the ALT +3 releases margins, ALT +4 sets the left margin at the point of the carrier, ALT + 5 sets the right margin at the point of the carrier.
Hope this helps.
Mar 15, 2010 | Brother ML-300 Typewriter
Changing margins
To change or reset margins, the keys involved are the ALT key to the left of the spacebar, the #keys 3,4, & 5.
The ALT & '3' keys are used to bypass the set margins.
To bypass the left margin, move the carrier to the left margin. Press the ALT & '3' keys at the same time. Release them then backspace the carrier to the point the new margin is wanted. Press the ALT and '4' keys at the same time to set the new left margin.
To bypass the right margin, move the carrier to the right margin. Press the ALT & '3' keys at the same time. Release them and spacebar to the point where the new right margin is wanted. Press the ALT & '5' keys to set the new right margin.
The main thing to remember is to move the carrier to the point where the new margin is needed. ALT + 3 bypasses old margins, ALT + 4 sets the left margin, & ALT + 5 sets the right margin.
Feb 24, 2010 | Brother SX-4000 Typewriter
I am using an AE-830 and have the left margin stuck in the middle of the page. How do I release and set back to the left? Thanks
Move the printer to the margin using return button. Press the margin release button, backspace to where you want the margin to be, then press the left margin set. All should be good.
Oct 13, 2009 | Nakajima AE-830 Typewriter
How to reset margins on kx-r340 typewriter?
Hi;
To set or change the left margin space forward and press the left margin key. If you want to go in the other direction the press the margin release key once(do not hold it down) the use the backspace key to get to the point where you want to set the margin and press the left margin key.
The setting of the right margin works the same way.
Andrew
Mar 15, 2009 | Nakajima AE-740 Typewriter
Margin Release
Try holding down on the MR (margin release) key and turn on. Machine will print a few lines with all the letters. Turn off and then on and try. Also make sure someone has not switched the key tops for left marging and right margin, I have seen this "joke" played on people. Can you set either margins?
Aug 13, 2008 | Nakajima AE-710 Typewriter
Lexmark Wheelwriter 1500 Typewriter Logo
112 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
