Question about PTC PARTECH,12.1" LCD CAPACITIVE, 56MHZ,40GB,128MB,NO OS, NO CUS PC Desktop
Have a Par Tech POS system, when powering up receive the following beep code - 1, 3, 3, 1 - any ideas??
    Sergeant:
    Champion:
  • 357 Answers
Could be bad memory.
Good luck, I hope this helped.
Posted on Apr 06, 2011
Tip
Beep codes
Diagnostics with Beep Codes Following are the beep messages associated with the IBPbios. 1 short beep specifies a normal post 2 short beeps tells about POST errors that can be find onscreen. Continuous beeps indicates power supply and other cardserrors. One long and short beep indicates system board problems 3 long beeps defines keyboard errors No system beep tells about power supply errors.
on Mar 15, 2011 | Computers & Internet
How i do may my power acoustik play in my truck.power go off and on ?
red pos key on, yellow always pos,blue sends pos to external amp or power antennae if none tape up- black wire neg. the rest pretty much speakers.
Feb 03, 2015 | 1994-1998 Chevy C2500 Truck 10 Piece...
Why does my computer light come on but want boot and want show a screen and making a beeping sound
In simple terms, you have a hardware failure, probably in your motherboard, hard drive or memory.
The beeps your hearing, are there for a reason. The way it works, is, when you first turn a computer on, it goes through a "Power-on, self test", (know as a POST).
During this period, the BIOS queries the system hardware, such as the hard drive controller, the i/o ports, the memory, etc. and expects to receive back a specific return code which indicates that the specific hardware is running properly.
If it finds a failure in some element of the hardware, it will issue a specific pattern of beeps to tell you which part of the system is failing. (It does this because the system may be unable to display the error on the screen).
Each of the different BIOS manufacturers (BIOS is an acronym for "basic input output system, the hardwired code that talks to the actual hardware), have their own series of short and long beeps, for the different type of failures. So to know where the failure is, you must first know what BIOS manufacture you have in your computer.
Some of the more popular manufacturers are: AMI, Award, IBM, Phoenix, Macintosh, etc.
When you first turn on our computer, the display will report which brand of BIOS you have, and its version.
Once you determine the brand, you can go to any number of web pages that have a cross-reference for the beeps for each brand on BIOS.
I think most adhere to the old IBM PC beep codes as follows:
No beeps: no power, bad CPU,
1 beep: normal
2 beeps: POST/CMOS error
1 long beep, 1-short beep: motherboard problem
1 long beep, 2-short beeps: video problem
1 long beep, 3-short beeps: video problem
3 long beeps: keyboard error
Several long beeps: memory failure (most common fault)
Continuous hi-lo beeps: CPU overheating
You can check with the following websites to get an idea of what's going wrong.
Computer POST and beep codes
How to Diagnose Computer Beeps eHow
Often times a SIMM has come loose in its slot (or corrosion on the connector tabs). If your getting a memory error, you can try opening the box and try re-seating each of the memory Simms to see it that might be the problem. (When you have them out, look at the row of pins along the bottom and see if any look corroded.)
Aug 25, 2014 | E-Machines eMachines Desktop PC
FLEX POS 150 - 2 Beeps and the disk light is on solid - nothing on the screen - not even a flicker... have removed the HDD and verified it can be read as a slave in a PC - any ideas would be welcome...
While I have limited POS experience, typically a beep code of 2 means an issue with the memory in the system. Does this system have removable memory modules?
Let me know if there is anything else I can help with!!
Jun 29, 2011 | Computers & Internet
My compaq persario sr1000 power is on the fan is on. but it beeps with a short beep and keep on. beeps pause and beeps again all with the power on but no picture on the moniter
Your ram/ram slot may have gone bad, contact Compaq Tech support for detailed instructions.
For a basic idea of what to do if you know what your doing:
1. Pull out 1 ram card in the first slot
2. Start up system
3. If beeping appears leave that slot empty
4. continue until beeping stops
Side Note:
If you keep removing all the ram cards and the beeping continues, I probably got the wrong error.
Mar 01, 2011 | Computers & Internet
I was previously surfing the net using Chrome and I had opened many many tabs.. My laptop (Fujitsu Lifebook S Series - S6420) then hung/hannged and I couldn't do anything so I held down the power button to...
Your beep codes are..
1 short beep System is OK
2 short beeps POST Error - error code shown on screen No beep Power supply or system board problem Continuous beep Power supply, system board, or keyboard problem Repeating short beeps Power supply or system board problem
1 long, 1 short beep System board problem
1 long, 2 short beeps Display adapter problem (MDA, CGA)
1 long, 3 short beeps Display adapter problem (EGA)
3 long beeps 3270 keyboard card .
So looks like a display problem, have you tried any of the recovery/restore options available when you press F8 on boot up
Sep 30, 2010 | Intel S6240 Notebook
Just started beeping and then went blank. Acts
need more info, but the beeping maybe your memory,video card, or cpu. check the power connects on the mobo and the back of the pc!
Jul 18, 2009 | Partner Tech PartnerTech PT-5500 POS...
Beeps
Standard Original IBM POST Error Codes
Code Description
For more info go here: http://pulonangka.web.id/software/beep-codes-error-codes
Aug 16, 2008 | Dell XPS M1530 Notebook
PTC PARTECH,12.1" LCD CAPACITIVE, 56MHZ,40GB,128MB,NO OS, NO CUS PC Desktop Logo
96 people viewed this question
Top PTC Computers & Internet Experts
David Payne
David Payne
Are you a PTC Computer and Internet Expert? Answer questions, earn points and help others
