Question about Dinex DX-LCD26-09 26 in. HD-Ready LCD TV
Hi everyone, Im new to this thread, but I have very high IT experience. However, I have a problem that I just cant figure out. My Dynex tv randomly started acting up. All my colors and channels are rediculiously fuzzy, and the pixels are all out of sync and shaking all over the place. I have standard cable connected to this TV so I get my 70 standard channels plus locals. However, my locals I get in standard and digital HD. The weird thing is my local channels I pick up in HD are perfectly fine. No problems what so ever. However, any other channel is messed up. Thus i thought it was maybe the tuner so I checked my other connections. I checked my xbox360 which is connected through component HD and it has the same problem. tried 480p, 720p, 1080i and nothing. I also checked my laptop through VGA and even at different resolutions nothing is working. I called dynex and the guy had no resolution. If someone has an answer any help would be appreciated. Here are some images. Also im going to try to connect PS3 through HDMI and see if it makes a difference. Any help would be appreciated. Also all the tv settings and options menus are displayed fine. Model # DX-LCD26-09 Tv In CBS HD http://i52.photobucket.com/...mridha3/IMG00588.jpg Xbox 360 random game screen http://i52.photobucket.com/...mridha3/IMG00587.jpg Xbox 360 game screen http://i52.photobucket.com/...mridha3/IMG00586.jpg Component input as Xbox 360 off http://i52.photobucket.com/...mridha3/IMG00585.jpg Xbox 360 screen (note the TV menu is open, note that it looks prefectly fine) http://i52.photobucket.com/...mridha3/IMG00583.jpg Xbox home screen http://i52.photobucket.com/...mridha3/IMG00582.jpg Load screen http://i52.photobucket.com/...mridha3/IMG00581.jpg ESPN non hd channel http://i52.photobucket.com/...mridha3/IMG00579.jpg Fox local Hd channel http://i52.photobucket.com/...mridha3/IMG00577.jpg I also tried different cables and connections, no difference. Im a bit desperate here so anything is appreciated. Thank You
    Scholar:
  • 126 Answers
Check the connection to your tcon board and main av board. if the connections are good one of these boards is more than likely bad. Google their part numbers and see if that board has a known issue
thanks,
michael
Posted on Apr 05, 2011
  • 2 more comments
  • mridha3 Apr 06, 2011
    checked all the connections, but nothing is working. Still have the same result, shocked myself a bit aswell but luckely the tv still works. I don't know if this is a t-con issue however, because as you can see in the images linked above, the Over the Air HD channels work perfectly, but everything else is messed up. Could this be a tune issue??
    also i tried a reflow of both the tuner board and the tcon board with my heat gun with no success. Going to check the parts now.
    sorry nvm, i reflowed the inverter and tuner board with no luck. The tconn board is directly connected to lcd without removable connections except one, all connections look fine but nothing is working. Should I attempt to reflow tconn board?
    HDMI input also works perfectly, no problems.
Hi Volume controle is intermittent
Try doing a factory reset on your TV, which should be located under the Settings Menu. This should clear any issues. If you still experience problems afterwards, I would recommend seeking repairs.
Oct 28, 2013 | Dynex 40" Class - Lcd Hdtv - 60hz - 1080p...
I have a dynex tv and i cant figure out what channel is FX
This would be dependent upon your residence and cable provider.
Oct 09, 2013 | Dynex 32 in. LCD Flat-Panel HDTV
The tv keeps randomly turning off, now i cant even turn it on, the light goes blue but the screen stays black
Sounds as if your back lights are not lighting, and that points to the high voltage power board. You may have the dreaded capacitor failure. Start with http://www.youtube.com/watch?v=YfO-KCQIYXQ&feature=related and look around.
Jan 27, 2011 | Dynex DX-L42-10A 42 in. LCD TV
The picture on an older 31 inch tube tv will go to a line randomly and if ya give it a slap it comes back. I did buy a new tv but I figured i would try to fix it myself. I do work with furnaces for a...
Your TV may need some soldering around the deflection circuit. It is too dangerous, to work on a 31" CRT TV due to its high voltage which, can kill you!. There is about 35,000 volts or more around, the deflection board and the tube. You need to resolder the components in the deflection board and you've got to have the right soldering iron and some soldering experience.
Good luck and be very careful
Sabre
Feb 22, 2010 | Sanyo Televison & Video
Dynex 19 LCD
I went over the specs of the TV.
The max input for the VGA is 1360x768 at 60Hz. Anything higher will make the TV go bonkers.
I would try to get the resolution at 1360x768, then change the frequency to 60Hz.
May 29, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
Dynex 19" tv
Go into the setup screen on the TV and set the channel option to CABLE (it is probably set to AIR right now or something).
The website should also have a manual for how to program the remote.
Sep 08, 2008 | Dynex 19 in. LCD Flat-Panel HDTV
Dinex DX-LCD26-09 26 in. HD-Ready LCD TV Logo
372 people viewed this question
Top Dinex Televison & Video Experts
Are you a Dinex Televison and Video Expert? Answer questions, earn points and help others
