Question about Garden
There are 3 blades, on our craftsman model #917.276360. what is the proper placement of the blades. jnjzajic60@sbcglobal.net
    Brigadier General:
  • 3,911 Answers
The little curved vanes go UP to create vacuum and lift the grass! That means if you have the deck off and laying upside down on the ground, they go down. Blades are generally the same size and do not have intersecting arcs so you can't put them on wrong. If they are different lengths assume the short one goes in the middle.
Posted on Apr 06, 2011
I need replacement blades for a Mantis Chipper-Shredder. The Mantis Chip Mate was actually made by a Swiss company called Stoeckler, under the model name Bio-Shredder LGM-600. Can you help?
You might check with Paul Banks at Diamond Knife and Shear
tell Keith Bright sent you.
10942 Wye St
#207
San Antonio TX 78217
United States
210-650-3343
diamondknife@sbcglobal.net
Feb 09, 2017 | Heavy Machinery
My Craftsman Bandsaw's (Model 113.243310) tension wheel is bouncing the blade off every time I turn it on. Any suggestions?
Please be sure that your put correct tension on the blade. Check the blade guides and check if the blade is tracking
properly. Make sure the tires are clean. If they're well worn out, change them . You may try to install new blades too.
Feb 18, 2013 | Craftsman 113.243300 & 113.243311 12" Band...
Setting the proper tension on a Craftsman 10" band saw model 124.214000.
Hope this blog will help you http://bandsawblog.com/blade-tension/ .
What's your band saw blade? I am using Haltbar blades and never got problems tensioning.
Feb 11, 2013 | Craftsman Saws
Model RS267LBSH/XAA - freezer working but refridgerator side warm (54 degrees). Heard sound like fan blade hitting, then no longer hear fan at all. What could it be
Have same model rs267lbsh/XAA and fix refrigerator. What I did was take off cover where evaporator is there a wire called defrost temperature sensor that goes bad I changed that sensor and my fridge is now working .if u need to ask me question please email me at jwilliams1957@sbcglobal.net
Apr 12, 2011 | Samsung Refrigerators
I have a 12" Sears - Craftsman - Band Saw and the blade keeps coming off. How do I install a new blade and keep it on?
Two potential issues here:
a.) You probably need to align your bandsaw wheels. Here's a link to a craftsman 12" bandsaw manual. Assuming you have model 113243310, 113243311, 113243300, or a similar model, read over page 12-14 "Installing the blade". Specifically, look at section 10 about adjusting the tracking.
Having the blade guides set properly is important too. A thrust bearing (the one up top, behind the blade) that's set too far forward can push the blade off the wheels too.
b.) If it's flat out too loose and you can't get it tight, the blade might be too long. It's worth double checking your manual to confirm you are supposed to be using an 80" blade and double checking the blade package to make sure you actually have an 80" blade.
Jun 14, 2010 | Craftsman 12 x 80" Band Saw Blade 6 tpi...
I need a owners manual for Craftsman 16'' chain saw modle 358.35161D I bought a reconditioned unit today but they don't provide an owners manual-----said to get one on the internet Wayne Heins Sr....
358.35161D did not work, 358351610 did (Operator's Manual):
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0807188.pdf
IPLs for you saw here (Craftsman):
http://www.searspartsdirect.com/partsdirect/index.action?psid=26128416&sid=PSx20071217x00001a&OVMTC=Broad&site=&creative=3106507164&OVKEY=craftsman%20parts
Type "358351610" in the "By model number" window. and click search.
Your saw is almost certainly made by Poulan. I think this is the correct IPL (PP3516AVX Gas Saw).
http://www.ordertree.com/modelinfo/PWE/PP3516AVX-Gas-Saw/75.PP3516AVX-Gas-Saw.1.59.1.html
There will differences in color, but you may save a few $ and response is usually faster.
We are prohibited from contacting you directly. If you need more help or need to contact me please reply below. HTH
Lou
Feb 12, 2010 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Removing pulleys from 42 inch Craftsman mower deck
Put the blade back on the star on the shaft and tighten it down. Now you have some backup for the pulley nut. You may have to wedge a 2x4 between the blade and deck. THe EASIEST way is get an impact and zip it off. :-)
Jun 15, 2009 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
Garden Logo
113 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
