Question about Samsung L210 Digital Camera
When I power on our Samsung L210, it turns on for about 4 seconds, beeps 3 times then turns off. What is the issue?
    Novelist:
  • 125 Answers
Welcome to FixYa.
As i've read the manual of your camera, there where no reason indicated why its happe,ned however there are some steps or option that you have to do to check if this will happened again.
* You can try to removed the battery and re-insert it again and try to turn it on
* try to get a new battery and turn it on again. if this happened again I suggest to contact your nearest service center.
If you want to know more about your camera and its troubleshooting, here is the link
You just have to enter the character below and you will have your manual for free.
I hope this link will help you in your issues about your camera.
Thank you for using FixYa.
Posted on Apr 05, 2011
    Sergeant:
    Champion:
  • 244 Answers
Sometimes the LENS can get stuck inside of it or outside of it. I would wiggle the lens around a little bit, putting a bit of pressure on it while doing so and see if that fixes it. Make sure you're attemping to turn the camera on while doing this.
Tv turns on for 10 seconds and then turns off. Then a red flashing blinks 6 times and repeats
Search Results
    Samsung TV On/Off Issue - Repair - Instructables
    www.instructables.com/id/Samsung-TV-OnOff-Issue-Repair/
    InstructablesThe result of this issue is a TV that will cycle between on and off repeatedly and/or an annoying clicking noise while turning on. Time to get informed about the ...
    Easy fix for new Samsung TV switching on and off power ...
    ? 4:41
    https://www.youtube.com/watch?v=H0cG3lzjuw8
    Sep 15, 2012 - Uploaded by alwaysafix
    www.alwaysafix.com Find the correct TV part for your TV and more at ShopJimmy.com Click Here: http ...
    Samsung 46" LCD TV (LNT4665F) turns off and on over again - Forums ...
    www.cnet.com > Forums > Samsung
    CNETAbout 3-4 months ago, my TV would start turning off and on a few times at startup but eventually would stay on after a couple of minutes. Every once in a...
    Samsung TV turning off [Solved] - Samsung - Displays - Tom
Jan 19, 2016 | Televison & Video
Samsung trouble shooting
Your problem - Zoom not work -
If you want to repair yourself - use this documentation -
L210
Aug 20, 2014 | Samsung L200 Digital Camera
The PS3 works fine but freezes in career mode of MLB 10 The Show. Is this also an over heating issue?
It doesn't sound like an overheating issue, more of either a disc read issue or firmware issue.
Please try my following tip for re-installing the firmware. If this does not fix it then try cleaning the laser lens.
Failing that, if it is an overheating problem usually it will tell you with an onscreen prompt or shut down with a flashing yellow light
Step 1.
Turn your Playstation 3 off into standby mode (red light on)
Step 2.
Press and hold the power button. The Playstation 3 will beep when you first press it, then beep again 5 seconds later and then beep once more and turn off back into standby mode (red light on). You must now release the power button.
Step 3.
Press and hold the power again. The Playstation 3 will beep when you first press it, beep again 5 seconds later then there will be 2 quick beeps together. When you hear these 2 quick beeps release the power button.
Step 4.
Your Playstation 3 will now start up with a screen asking you to connect a controller via USB. Connect your controller and then press the PS button.
Step 5.
A menu will now be displayed on screen. Select option 3 "Restore File System". This will then ask you to confirm that you wish to go ahead with the system restore. Accept whatever the Playstation 3 says
Hopefully this will cure the problem on its own.
Hope this helps
Jan 29, 2011 | Sony Playstation 3 (PS3) Console
My Dell Inspirion Mini 10 is beeping 8 times when I turn it on. Nothing on the screen.
Try holding Fn + End with battery and power cord out and while still pressing Fn + End plug only power cable back in and try to power on.
Oct 12, 2010 | Computers & Internet
The unit beeps
I am getting these directly from the user manual (available here: http://www.apcmedia.com/salestools/ASTE-6Z7VAQ_R3_EN.pdf)
Issue: On Battery - UPS is supplying battery power to the load connected to the Battery outlets.
Visual Indication: Power On LED - ON (off during beep)
Audible Indication: Beeping 4 times every 30 seconds
Stops When: UPS transfers back to Power On operation, or when UPS is turned off.
- OR -
Issue: Sleep Mode - During On Battery operation the battery power has been completely exhausted and the UPS is waiting for utility
power to return to normal.
Visual Indication: None
Audible Indication: Beeping once every 4 seconds
Stops When: Utility power is restored, or if utility power is not
restored within 32 seconds, or the UPS is turned off.
All other issues are CONSTANT tones, which you did not specify, or there are no audible tones associated with it.
Apr 07, 2010 | APC Back-UPS ES 350 - UPS ( external ) -...
My camra beeps 4 times and shuts down. what could it be ?
maybe u need to charge it or put in batteries most cameras do that
Apr 04, 2010 | Samsung L210 Digital Camera
My samsung l830 camera lens is stuck open and when i press the power button it beeps 3 times and remains blue then does nothing
If the lens on the camera is stuck out, look to see if it's a little crooked. If it is, try to gently straighten it. If it still won't retract, try to gently push it in as you turn the power on.
If it won't turn on (the green light blinks and it beeps 3 times) push and hold the 'power' button and the 'play' button at the same time for a few seconds - it worked for my S730. Good luck!
Jun 28, 2009 | Samsung Digimax L830 Digital Camera
I turn camera on. Lens comes out. beep 3 times. turns off.
Everytime I try to turn it on, the lens comes out for about a second, the camera beeps 3 times, the lens retracts and the camera shuts off. The battery is completely charged and the camera is only 4 months old. HELPP :(
Jun 17, 2009 | Samsung Digimax S500 Digital Camera
Samsung L200, you turn on and after 5 seconds you hear 3 beeps and its turned off automatically
Hi Bruno,
[ENGLISH]
first, try to reset the camera to factory defauts. Your memory card maybe corrupted as well, try to format it on the other camera. Another issue is when lens get stuck. Check if the lens go in and out of the camera smoothly. Good luck!
[BRAZILIAN PORTUGUESE]
Olá Bruno, como você parece ser brasileiro como eu, vamos em português também. Tenta resetar a câmera e formatar o cartão de memória. Vê se as lentes não estão emperradas e se elas entram e saem da câmera de forma bem suave. Boa sorte!
Oct 04, 2008 | Samsung L200 Digital Camera
Samsung S730
no solution ours does this
waste of money return it if u can
Aug 11, 2008 | Samsung Digimax S730 Digital Camera
Samsung L210 Digital Camera Logo
123 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
