Question about Maytag HYE3657A Electric Dryer
My dryer keeps shutting off after a few 10 to 13 minutes...and clothes are not drying. An element was changed some time ago. it does heat up but keeps shutting down...is it the timer or element?
  • David Sanchez Apr 13, 2011
    WELL THE PROBLEM SEEMS TO BE A SHORTED RESISTOR...BUT NO-KNOWS WHICH ONE IT IS. IT IS A 10K OHM ROUND CANISTER RESISTOR WITH 4 COLORS ON IT...
  • David Sanchez Apr 23, 2011
    well i am back again and I had changed the motor and it still doing the same issue of shutting off every few minutes. So I am back to square one and I really need help here. Would it be the heat coil by chance or an intemmited element in this case. Its really drying me crazy here. What else can be done.
    Scholar:
  • 125 Answers
Turn the breaker to the dryer completely off and back on again. Also check that nothing is blocking the venting. Remove the vent hose and run the unit if you are not sure. Make sure the lint trap is cleaned first. It probably is neither element nor timer since it is heating and quits without the timer advancing completely.
Posted on Apr 05, 2011
  • 4 more comments
  • David Sanchez Apr 06, 2011
    will look into these options and see what happens....will keep you posted thanks
  • David Sanchez Apr 07, 2011
    ok i did all but the dryer still goes for 10 minutes and it shuts down. I noticed thou that the light goes out and the dryer wont go back on until the light goes back on, then its goes on for ten minutes and it shuts down again. almost as if it were over heating or something. its really getting frustrating drying clothes when it keeps shutting off. What else can be the problem so that I can fix it. I am very handy in fixing things but its hard when I am not skilled in doing this on a daily basis.
  • aviandragon Apr 07, 2011
    When you disconnected the vent hose to the unit and ran it was there good air flow out of the vent? If you're not getting good air flow out the back check that your blower wheel is working. Does the cabinet get physically hot when it shuts down? To open the machine use a putty knife to disengage the clips holding the top of the unit on. Stick your knife in between the top and front panels of the dryer and push back the clip on either end. The top should then swing up. Your blower wheel is the fan assembly in the front that runs to your vent. Also check that your element was properly installed since it was replaced shortly before your problems. Another thing to test is your thermal and high limit fuses. Here is a link to a fuse kit that should fit your model. There is also a video on how to test the fuses. Let me know what you find. Good luck.http://www.repairclinic.com/PartDetail/T...
    Well so far everything regarding the elments work good. They all have continuity thru-out all of them. The vent was very clean and the fan wokrs and blows out fine. But here the funny thing, when you put the temperature to air fluff the machine will go on for as long as you put it to. But when you put it on any other temperature it will go on for the short time and shut down. So this is where I am lost...So what would be the next move in checking this machine. Thanks ...all your advices have been very helpful so far.
  • aviandragon Apr 08, 2011
    Hmm if all these things are working I guess I would start looking for something unusual. Pop open the cover for your dryer cord and make sure all the nuts holding each separate cord are good and snug. Check for physical wear all along the cord. If your cord can't hold up to the strain it might be your problem. If that isn't your problem you may want to have an electrician test the outlet to be sure it can take the strain. Before doing that I guess you could check any other wiring for signs of burning or physical wear. The components in the machine seem to be functioning properly so there must be a wire somewhere that can't hold up to the current or surely a thermal fuse would have overheated and blown if it was heat related. Let me know if you find anything.
  • Richard Murray
    Richard Murray Dec 06, 2013
    The door is not staying closed. Mine does the same thing. Came here to see if anyone had a fix for it.
How to replace a heating element on a Kenmore Elite Oasis ST dryer
Sounds like you need to replace the timer one the dryer not the element but to make sure I would do a little trouble shooting to rule out the element or heating coil turn on dryer cycle like normal for about 30 seconds then open the door to feel for heat if you do feel heat its your cycle/timer knob if you don't feel heat then it's the coil or element witch are the same also first always check your lint trap and ducts going outside the dryer make sure you have proper airflow through ducts vents. clogged vents ducts ect. Cause over heating of element coil causing a safety fuse to shut down heating coil/element but will not stop cycle also moisture censors detect moisture causing cycle to continue on hope this helps.
Sep 04, 2014 | Kenmore Elite Oasis 6808 Electric Dryer
Dryer will stop heating after ten minutes...
This caused by one of two possible things. Either you have poor air flow, or a clogged vent preventing air from flowing freely and therefor making the dryer short cycle, which in turn will take you two or three times to dry yor clothes, or the heating element has gone bad, burnt in half and is making contact with the case to provide it just enough power to barely heat. The second thing is a very rare occurance. I would turn the dryer on, find out where the air vents out to, and with the dryer running, go to where it vents and check to see if there is a strong flow of air. 9 times out of 10 that is going to be your problem. Another way to check air flow is to just pull the vent off the back and let the dryer run and see if your clothes dry faster. If you do it that way and they still take a long time to dry, then you'll probably need to replace the heating element
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Apr 28, 2012 | Dryers
Having heating problem with Roper REX4634JQ0 dryer?
probably have a weak hi-limit thermostat on the element housing or cycling thermostat on the blower housing
Apr 26, 2012 | Roper Dryers
The dryer keeps shutting off after very few minutes (and it has no heat). sat and watched it and it is stuck on the "sensing" cycle. Tried timed dry and it stayed on the full 20 mins - but clothes still...
This sounds like you have a bad heating element. Double check the breakers and make sure that one side of the double breaker has not tripped. If you have meter and know how to use it check for 220v at the outlet. If I can be of further assistance please let me know.
Apr 15, 2010 | Whirlpool GEW9868K Electric Dryer
Dryer won't heat up to dry the clothes the heating element works
Check the following to address this issue--
Note: Normal drying time for a dryer is about 45 minutes (some may take up to an hour).
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
Jun 03, 2009 | Kenmore Dryers
Maytag LDG 712 shuts off before clothes are dry.
First, The most common part would be the over limit safety, it will be mounted to the element housing. Second, there is a thermal fuse usually a small disk with a little fuse inside. You can find these (with your model no.) at www.Repairclinic.com .Good luck.
Apr 20, 2009 | Whirlpool LER5636P Electric Dryer
Inglis dryer-spinning,not heating,Inglis washer not spinning well
Your heating element is going out. Mine did this a few months ago. It is an easy fix. Look up the part online.
Apr 13, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Whirlpool dryer model LER7646EQ1
Thats what it's supposed to do hopefully the clothes are coming out dry. The dryer has both thermal sesors and fuses that tell the dryer when to heat up and when to cool down. So yes the heating element will come on and go off multiple times in a cycle.
Mar 31, 2009 | Whirlpool LER4634J Electric Dryer
DBXR453ET3WW Electric Dryer Won't shut off unless on timed cycle.
hi thanks for the question in the ge dryer theres 2 elements so if one is not working you only get half heat i would check the heater thanks the appliance doc
Jun 18, 2008 | GE DBXR463EBWW Electric Dryer
Maytag HYE3657A Electric Dryer Logo
2,181 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
