Question about Bosch Nexxt 800 WFMC8400UC
I have a vision 800 series laundry washer. I have a "check Pump" error. From what I have read I need to clean the pump filter. Also from what i have read I need to remove the bottom panel but am having trouble doing this. Is there a specific way to open the bottom panel? ty Robert
  • rawcliffer Apr 06, 2011
    Ok thanks, I got the cover off finally. Ty
    I located the drain pump and have cleaned it out, but am having trouble putting the pump back together again.
    The cap does not want to thread in.
    Any suggestions?
    Brigadier General:
  • 6,277 Answers
Our (older) Bosch has 2 visible plastic '90 degree turning' screws holding the bottom front panel on. On some others the screws are covered by plastic caps. If yours has neither of these it could be that the cover should simply 'unclipped' by pulling at the ends.
John C
Posted on Apr 05, 2011
My Bosch Vision 300/500 DLX series washer machine washer stopped in mid cycle, with error code 13. What to do
The code means that the water is taking to long to pump out
unsrew the pump filter at the bottom front right
have some towel ready to soak up the water
clean and replace filter
most times this fixes the fault
if it doesn't then check for a blocked drain hose or faulty pressure switch
Jul 22, 2015 | Bosch Washing Machines
How to clean filter in pump fex831cs0
Hi Janis Belcher - According to the model number posted FEX831CS0 (laundry-center), this unit does not have a filter. Generally speaking, the filters only exist on front load washing machines. The filter is typically inside the hose between the bottom of the tub and the drain pump. If there isn't any debris in the filter or pump, then the unit may not be spinning long enough or may not be reaching full speed. I would personally contact a professional to accurately diagnose the washer to determine the root cause to reduce the risk of unnecessary parts.
Apr 17, 2013 | Frigidaire FEX831CS Top Load Stacked...
Front Load Washer will not drain. Frigidaire Gallexy Washer Model # GLTF2940FS0. Get Error Code "E20".
This is an error code for a slow drain or no drain at all problem. It can be due to a clogged/kinked drain hose, blocked drain filter/coin trap, or a broken drain pump. The link below provides the detailed troubleshooting procedure of this error code. In addition, replace the drain pump after having found no problem with the drain hose, cleaned the filter, and checked the drain pump impeller but the drain pump just hums or whirs.
Error Code E20 on Frigidaire Front Load Washing Machines
Aug 21, 2011 | Frigidaire Washing Machines
My MAYTAG washer 9000 series with steam is flashing F21 and won't drain?
F 21 means slow drain if you can here the pump that means something pluging it. remove lower kick plate . the pump will be there remove cleanout counter clockwise turn .put back together.. hope this helps...good luck
Feb 01, 2011 | Whirlpool AWM9000 Front Load Washer
Kenmore Oasis Washer won't drain. "Ld" code during
Hi
Error code LD means long drain. This error appears when the washer takes more than 5 minutes to pump out the water till point where pressure switch resets. To resolve the issue you'll need to clean the drain hose, inspect if the drain hose is plugged. If the hose is fine, then remove the front kick panel and access the drain pump and filter, if you are unable to find the pump and filter remove the back panel as well and trace the drain hose to the bottom of the tub. There is a drain filter connected with the drain pump. It usually gets clogged, and needs to be cleaned every 6-8 months or so. The drain filter is a small white filter connected to drain pump with a hose. If it still doesn't work then you'll need to check the connections of the drain pump, check the electrical connections with a multimeter. Hope this helps... Please post back for more information.
Daniel
Nov 26, 2010 | Kenmore 4.5 cu. ft. Oasis Canyon Top Load...
Did one load of laundry, went to start a new load and no water is coming out. Tried different water temp, different water levels. If this helps the tag on the upper corner of dryer reads as...
Coin or clothing in the pump
Remove the filter and clean out the pump
You first need to put the oulet hose down into a bucket to drain the water off
Feb 13, 2010 | GE Spacemaker Washer and Dryer Electric...
My washer keeps coming up with errors
You have a right mixture of errors,
F11 indicates that the pump is not working.
F05 indicates that the pressure switch is jammed on full.
F04 indicates that the pressure switch is jammed on empty.
I would start by checking the pump is working o/k.
Next locate and clean filter.
This can be found by removing the rear panel of washer.
Locate and remove large black hose onto tub, remove filter and clean, refit same, make sure hose is on properly.
Test for leaks.
If no improvement, then I think your only option is to call an engineer out as it could become quite involved.
Good luck.
Plz rate my solution.
Thanks.
Jan 19, 2009 | Hotpoint Aquarius WD640 Front Load...
0E error
Product Laundry Washer
Symptom Error Codes
Sub Symptom OE error
Question Drain Problem Error.
Answer
Make sure that drain hose and drain filter are not bent or clogged. In case of there are objects in the drain filter, It might drain to slow or not at all. HOW TO CLEAN THE DRAIN FILTER 1. Allow the washer to cool down before cleaning the drain pump filter. 2. Open the lower cover cap with a tool such as coin. 3. At this time use a catch pan to prevent water from flowing onto the floor. Unplug the drain plug, allowing the water to flow out. When water does not flow any more, turn the pump filter open to the left. 4. Remove any foreign objects from the pump filter. After cleaning, turn the pump filter clockwise and insert the drain plug to the original place. Close the lower cover cap. If the drain filter is not clogged, you will need to call LG Customer Service at 800-243-0000.
Aug 18, 2008 | LG Washing Machines
F2 error code on my Kenmore Elite HE3 washer
Based upon your description, the drain pump has either failed or the pump filter has become clogged.
To check the pump, remove the bottom access panel. There you will find access to the pump clean-out.(Large,white screw cap) BE READY TO CATCH LOTS OF WATER. CAREFULLY AND S_L_O_W_L_Y unscrew the pump clean-out, catching and discarding the water. When the water flow finally stops, completely remove the clean-out filter. Inspect the clean-out filter, the drain hose from the tub as well as inside the pump impeller for any additional debris.
If you need further assistance, let me know
Regards,
reg501
Jul 04, 2008 | Kenmore Elite 45986 Front Load Washer
Bosch Nexxt 800 WFMC8400UC Logo
310 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
