I only get normal clear picture when using the component inputs from my set top box to the tv. I tried eliminating the set top box and connected directly to the cable input and have terrible reception. Even the computer input and dvd inputs are the same fuzzy reception. Tried a different tv with same cables and it was fine,so its not a cable wire issue.
    Scholar:
  • 126 Answers
Sounds like a bad av main board -
Thanks,
Michael
Posted on Apr 05, 2011
Blurry picture on my 70" vizio
As previously mentioned, try a known good DVD to the same connection (BE SURE TO USE A DIFFERENT CONNECTING CABLE,as your connect cable may be at fault) Also try any of your other inputs to the TV to eliminate 1 or more input issues.
Mar 21, 2014 | Vizio L32 32 in. LCD HDTV
I've tried numerous possibilities with each input but they never show a clear picture.
If the components you are connecting to the tv set are working but the picture quality is the problem, then it sounds to me like you are connecting them to the correct inputs, just your connections or cables don't have a good connection. My visio never gave me a perfectly clear picture (like you see at the store) from my satelite or any other input, until I used an HDMI cable for the connection.
Oct 31, 2012 | Televison & Video
The picture is too large for screen and is cut off on top and bottom. Possibly on the sides too.
There is a button the remote control that will resize images. However this could also indicate that a tv is in the wrong input and or connected to the set top box (ie cable box or satellite receiver) incorrectly. It can also indicate that the set top box is set to the wrong resolution.
Buttons on the remote control could be view mode, aspect or format, and # hd zoom.
The tv could be in the input for the rf connector or the composite cables instead of being on the input for the component or hdmi cables.
The tv could be connected to the set top box with RCA cables or a coax cable instead of being connected with component or an hdmi cable.
Apr 28, 2010 | Televison & Video
TRYING TO INSTALL DIGITAL SET-TOP BOX WITH DVD AND TV
Hi ccraigo
To answer your question;
Your motorola will connect directly(not through the dvd) to the tv set into one of the input ,(preferably using hdmi or component cables for hd) and the dvd will use a different input,
All you have to do then is switch between which one you want to watch.
Hope this help Cheers
Apr 20, 2010 | Pioneer Televison & Video
I have an LG Golden Eye CRT TV, is this compatible to a HD set top box?
well this tv dont have component inputs. u can connect hd set top box via a/v well picture will come but no hd experiance.....u have to buy a hd tv
Mar 24, 2010 | Televison & Video
Connecting hd cable box to philips 60 rear projection
So, You have Five cable leads, The rgb get plugged into there corresponding colors and the other two are your Red and White Audio Input ------Correct? You do not use the in4, that is for a pc with horiz and vert sync. You use input 1 rgb and plug the red and white into the audio input.....your done!
Jun 06, 2009 | Philips 60PW9363 60" Rear Projection...
Connect Macbook Pro to Component input
you should be able to use an SVGA to component rca connector on any component input - i have a wd-65513, and thats how I have my pc hooked up to it. I could also never get a clear picture using the SVGA plug on the back of the set.
Jan 12, 2009 | Mitsubishi WS-65513 65" Rear Projection...
JVC LT-Z37SX5 no sound when using hdmi connection to HD box
the tv has a configaration that conveys the sets focus on both audio and video performance. full hd resolution of 1920-1080 pixels.
hdmi inputs allow connection of the generation of 1080p sources for the systems which offer 1080p outputs
Jan 12, 2009 | JVC AV-36D303 36" TV
Yellowish color from DVD
Hello Tsmith4,
Have you tried another source such as a HD cable box on the same component input (Y Pr Pb) By doing this you will eliminate the TV or the DVD player. If the picture shows great using the cable box on that same input then we will assume that the TV is ok for now. You may want to also check the DVD menu under progressive scan that it is set to progressive scan. if the picture is still not good, we would want to look at the I/O board on the TV. The red path after the Video switch maybe open. If this is the case we will have to go to board replacement. I will tell you what board to change.
Best regards
circuitcity
May 25, 2008 | Sony KDF-E42A10 42 in. LCD Television
No audio
I will try to explain this clearly.
Make sure that there is sound leaving from the connections on the top box.
Check that the audio cables are connected to the associated audio input for the video at the rear of the set. Make sure that there are no other shared inputs for the same input. With shared inputs, only one can be the default reference for input.
Check the menus in both the top box and the TV set to make sure that all setups are correctly done.
Jerry G.
Apr 13, 2008 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
