Question about ViewSonic PJ458D DLP Projector Multimedia Projector
It worked beautifully last night with my macbook in a test run of my powerpoint, but this morning I plugged it in for the REAL presentation it didnt work. A bright, clear picture of the Viewsonic Logo appeared as it should (proving all was ok with bulb, etc) but when I tried to connect the same laptop with the same presentation and the same cords it would only project a dim, blue light. I had to borrow a projector for the presentation- same computer and connections and borrowed projector, and all was fine. Same issue when I brought it home afterward. Obviously, the bulb's ok because I got a bright and clear logo, but only a dim, blue screen when I hooked up my computer. What am I doing wrong? Buddy Burke
  • ViewSonic Master
  • 3,878 Answers
You might need to turn off your computer .
then connect the data projector
and turn on data projector
then turn on computer
hopefully it detects the data projector is connected and switches windows to duplicate projection
On my P.C. F4 key in windows Switches the display manually to duplicate, alternate screen or pc screen only or projector screen only.
As I am not familiar with Apple this support article below might explain the switching of display outputs available on Apple Mac.
Posted on Mar 23, 2017
SOURCE: unit will not power on
Company said it was defective. Sent back for exchange.
Posted on May 31, 2008
SOURCE: Viewsonic PJ556d shuts down after 30-60 seconds
My solution sounds dumb, I had the same issue. Took the lamp cover off the bottom. The screws were loose holding in the lamp. Maybe they heat and expand and eventually work their way out and the lamp doesn't make good contact. Just tightened mine up, the unit would power off after 45 minutes prior. Been on now for 5 hours, no trouble.
Posted on Feb 11, 2009
SOURCE: New ViewSonic PJ 513DB connected to laptop. Cannot see DVD
I think this is your laptops problem with putting out that on both displays at the same time try cloning or playing with those settings
Posted on Mar 10, 2009
  • 11 Answers
SOURCE: Viewsonic Projector PJ506D not working
proable solution the cooling fan is giving problems. the whistling sound most likely is fan rubbing on a wire??? The unit gets over heated and turns off for protection. Good luck
Posted on Aug 19, 2009
  • 25 Answers
SOURCE: Projector not working with Imac
Please visit below URL and download viewsonic projecter drivers for your Imac.
Posted on Mar 26, 2010
How do I recover a corrupt PowerPoint 2013 presentation?
You can try:
PowerPoint Repair Toolbox is powerful .PPT repair software, resolving any problem, causing the damage of PowerPoint files. This tool guarantees the compatibility with all available software configurations therefore PPT on repair of reinforced concrete structures works anywhere in the network.
For more information:
Mar 02, 2015 | Microsoft Office Computers & Internet
I want to open powerpoint presentation.
then, go to format -> slide design, choose to show all documents, and choose the corrupt powerpoint file. now, go to insert -> slides from file, and select the corrupt powerpoint file. make sure you are set to insert all slides, and then import. if that works, great! i suspect, however, that you might crash at that point. if so, try repeating the process, inserting specific slides one by one until you find the problem one. after that, save the file, making sure that fast saves are off (in preferences / save).
if you are unable to open your powerpoint files then try pptx viewer tool. this utility recovers your corrupt and damaged powerpoint presentations (.ppt, .pot, .pps, pptx and ppsx formats) from ms powerpoint files.
Jan 19, 2015 | Microsoft PowerPoint Computers & Internet
August LP102R presenter will not work
You obviously need a driver. Where did you get the presenter?
Apr 11, 2014 | August LP102R Wireless Presenter with Red...
My laptop doesnt start. It's not working. I was just using it last night. I was working well. I shut it down properly as I should. This morning when I turn it on. It didnt work.
Hi there, try to remove the battery, clean the terminals, then place it back, chances are the battery was dislodge. test again. hope this helps.
Aug 06, 2009 | Computers & Internet
Last few slides of a large PowerPoint lose their pictures laptop
Yes, I think having more memory in the laptop will help with the presentation. Try pulling up one of the last couple of pages and wait to see if the image ever appears. You can also pull up task manager to see what the memory and CPU utilization of your system are when you are trying to pull up those slides.
If you see more than 256MB of RAM in use, I would upgrade. Depending on what version of Windows you are running I would try to go with atleast 512MB RAM. If you are using Vista, then you should really be 1GB or more.
Mar 17, 2009 | HP Compaq Business nx7010 Notebook
1997 cadillac deville alarm wont activate light ontop of dash won
with gm alarms you need to wait about 2 min for it 2 arm. also it only protects the doors when opened.
Feb 12, 2009 | 1999 Mercury Cougar
Mac Notebook
Hi there
One of the easiest questions I've had to answer.
From what you say you do not need a high end spec.
A 13in macbook should suite you fine. In terms of cost it is the cheaper mac. The screen size can be a hassle but all you need to do is buy a separate monitor to complement the 13in screen. So when you are at you desk you run dual monitors and when you present you use the macbook.
I'd just recommend to upgrade the ram and hard drive. Presentations such as powerpoint are memory hungry.
Sep 08, 2008 | Apple MacBook Mac Notebook
Iphone touchscreen not working
try fully charging the battery
Apr 15, 2008 | Apple iPhone Smartphone
Ending linked powerpoint presentations
In your last PPT. insert your end there.
make the last slide "End of Presentation".
Dec 05, 2007 | Microsoft Office 2003 Basic Edition...
60 people viewed this question
Top ViewSonic Office Equipment & Supplies Experts
color wheel light...
Are you a ViewSonic Office Equipment and Supply Expert? Answer questions, earn points and help others
