Question about Acer Aspire One PC Notebook
My acer aspireone notebook has a glitch constantly that when typing goes automatically to the find feature as if the keyboard is damaged some times the 1 can not be typed nor the exclamation sign like now I can not type it, pls help
    Sergeant:
    Champion:
  • 244 Answers
I noticed this on a client's computer a couple weeks ago. We found out that the registry was all messed up and the only way to fix it was to completely restore the operating system. Contact Acer's support line and they can help you in getting it restored.
good luck!
Posted on Apr 05, 2011
Chromebook reset factory mode
Instructions
Consider what data you still need from your Acer AspireOne's hard drive. Save the files to an external USB device.
Restart the Acer AspireOne's operating system. Wait for the Acer logo to appear on the LCD screen.
Press the "Alt-F10" keys at the same time to bring up the recovery menu. Press "Enter."
Click "Next." Follow the prompts that appear on the screen to restore the operating system back to factory settings.
5
Use the drop-down boxes to select the time zone and language information for your Acer AspireOne. Restart the netbook when you are prompted to finish restoring the computer.
6
Connect the external USB device to your Acer AspireOne and transfer the data you saved earlier back to the netbook.
Feb 28, 2014 | Acer Aspire One Netbook 8.9" Notebook
My laptop acer aspireone mini laptop screen is blackout i can't get it started.
You might have a faulty Liquid Crystal Display [LCD] Panel Power Inverter. Or the LCD Panel itself might be faulty. Either can be replaced. The Inverter is relatively inexpensive, a replacement LCD Panel, a little more.
To test for a faulty screen, connect your notebook to an external Desktop Monitor, using a standard VGA Cable -> press and hold the Fn key bottom left of your keyboard -> press the Function key at the top of your keyboard with the image of the two monitors on it -> release both keys -> if the image sent to the external monitor is correct then the fault is likely to be in one of the components of the LCD Screen and you should take the notebook to a repair centre to test test and replace the faulty component(s).
If you cannot start the computer at all, but there is a constant or flashing Power Light Emitting Diode [LED] on at the front but no Hard Disk Drive [HDD] LED on, then either the battery is faulty, there is a loose Direct ()Electrical) Current [DC] Jack, the Graphical Processing Unit [GPU] chip is faulty or there is a damaged Motherboard Power Management Track.
To eliminate other possible causes of the symptoms you describe, remove the battery and connect the notebook directly to the mains electricity without a battery and then try to power the notebook up. If the notebook powers up and boots into its Operating System then the battery cells are probably depleted and cannot recharge, so the battery should be tested and, if found faulty, replaced.
If the battery is not the problem, check for a loose DC Jack. If the point where the the Power Cable connects to the notebook is loose and is either in intermittent contact or not at all in contact with its solder points on the motherboard, then power might not be reaching the motherboard. Loose DC Jacks can be re-soldered or replaced if damaged.
A loose DC Jack that is in intermittent contact with the motherboard, an electrical power surge or sudden power cut or disconnection of the power cable can damage the Power Management System of the motherboard. It is sometimes possible to repair Power Management problem afflicted notebook motherboards by replacing blown capacitors and/or bypassing burnt out or damaged circuit tracks by creating new ones. Extensive damage to a motherboard might make it uneconomical to repair. Replacement motherboards are available and could be installed but when combined with the cost of labor for the overall repair the price might be prohibitively high.
A faulty GPU can have new tracks made to it, or have a damaged chip (silicon chip) surface cleaned to restore lost graphics by two different processes, Ball Graphics Array (BGA) Reflowing or BGA Re-balling. Re-balling has the longer lasting and better success rate. When the surface of the GPU is too damaged it may not be possible to repair it.
All of these motherboard repairs require a laptop repair specialist to disassemble the notebook and test, replace or repair any faulty components. These repairs can be expensive and need to be weighed up against the current value of the notebook and the cost of a new replacement notebook.
Nov 20, 2011 | Acer Aspire One PC Notebook
I have an Acer AspireOne D255 computer and the keypad only types numbers. Im using the On-screen keyboard. HELP!
Did you turn on your numlock key? try pressing FN + numlock key maybe this what is causing your problem.
Sep 06, 2011 | Acer Aspire 5100 Notebook
Why my acer aspireone display not full???
This is typically caused by a loose cable inside of your screen. I do not suggest tinkering with it as you could possibly damage it more. In case you're feeling brave, here's a guide on how to get to the LCD on your model of laptop:
http://www.dalekeller.net/Other/Computers/AspireOne/Disassembly.pdf
Again, I don't recommend trying this unless you have some prior experience with this sort of thing. Take it into a certified technician or call Acer @
1.800.816.2237
Mar 31, 2011 | Acer Aspire One PC Notebook
I don't know how to use my acer aspireone camera. I can't access an option for its use.
try to download "arcsoft webcam companion 2". this should allow you to use your webcam. it also has a ton of cool features you can use with it. hope this helps.
Oct 09, 2010 | Acer Aspire One PC Notebook
Cant get rid of bilingual characters on acer aspireone netbook
Check your regional settings in the controll pannel. Your keyboard is probably set for "Canadian French"
By default it should just be set to US.
Jan 16, 2010 | Acer Aspire One PC Notebook
KEYBOARD NOT WORKING
The keyboard cable maybe loose, remove the keyboard and reseat the keyboard ribbon cable that connects it to the motherboard.
Aug 15, 2009 | Acer Aspire 5101WLMi Notebook
Keys on laptop not working!
the keys type numbers instead of letters, help!!
Aug 01, 2009 | Acer Computers & Internet
Several keys on keyboard not working - Acer AspireOne
If you have warranty they can fix it for you, but if not, you can take the laptop apart, and clean the contacts of the keyboard youself. Which would be the same thing they would do ("they" the warranty people). But is not sure, you can take it to a repair shop for inspection.
Jul 14, 2009 | Acer NSK8458AN Keyboard
Acer aspire 5100
This is generally a driver glitch. You will need to use an external keyboard and mouse, in order to uninstall the drivers for the onboard keyboard and mouse from the device manager, then disconnect the externals and reboot. The machine will find and reinstall the drivers for them automatically. If this doesn't work, then the problem is with the motherboard and you will need to have it serviced.
Jul 03, 2008 | Acer Aspire 5100 Notebook
Acer Aspire One  PC Notebook Logo
122 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
