Question about Panasonic Viera TH-50PX80U Plasma TV
Is it possible to clean the inner side of the glass front screen from my panansonic TH42-PZ80
    Scholar:
  • 126 Answers
Anything is possible! It would be a lot of work because you have to totally disassemble the tv to get it broken down far enough to do that - and also make sure you dont break either of the glass when disassembling or reassembling.
thanks,
Michael
Posted on Apr 05, 2011
Scanner carrier error
Usually it happen when inner side of Platen Glass Dusty or Carrighe shaft, Cleaning of Inner side of Glass and Carriage Shaft might help to prevent Scanner Carrier error
Nov 12, 2013 | Ricoh Aficio SP 3510SF
Separate door and glass from Ignis FXVM6 oven for cleaning
To separate the inner glass from the door. Unscrew the sixsided screws sitting in the middle of a back plastc box that retains the glass at the bottom of the inner glass on each side. Once the screws are out , remowe the small boxes and lift the lower part of the glass before pulling it towards you. There are four sticky pads that keep the glass in place, so make sure they stay in place when you remove the inner glass and clean the door. To refit, reverse the operation.
Sep 10, 2013 | Ovens
Philips DPTV 310, 60PP935217 We got this tv. As it was brought, they took out the front glass to transport. Question is. There are 2 glasses. Wich glass, in wich order, and which side has to be Built
The pair taped together usually are the inner and it is possible to put in backwards----should have marked this with masking tape before removal which is rarely needed to transport this set---cover with heavy quilt and face forward in a pickup etc so wind does not **** screens out.
Nov 02, 2012 | Philips Televison & Video
I have a Mitsubishi 60"
there may be dust behind the screen & also on the reflecting glass. u will see that upper back portion cover is removable. remove it & see that glass there is glass on inner side of cover. clean it, also clean the screen. u will see there are 3 picture tubes faces on bottom side, clean all of them.
if it does not work then u can increase brightness of tv by increasing "screen" control of tv which is on the lower back portion of tv. this can be done by any tv repair expert only.
Sep 05, 2011 | Philips Magnavox 51MP392H Rear Projection...
While printing, red turned to pink on printed sheets. All cartridges have ink.
Try
Clean the Scanning Area sikaku.gif Cleaning the Platen Glass and Document Cover i_expl.gif Caution
Be sure to turn off the power and disconnect the power cord before cleaning the machine.
i_important.gif Important
bullet_s2.gif The inner side of the Document Cover (white sheet) (C) is easily damaged, so wipe it gently.
bullet_s2.gif If the glass of the ADF (A) is stained with ink, correction fluid, or the like, black streaks may appear on the printed paper when the document is loaded in the ADF. With a clean, soft, lint-free cloth, wipe the glass of the ADF.
With a clean, soft, lint-free cloth, wipe the Platen Glass (D), the inner side of the Document Cover (white sheet) (C), the glass of the ADF (A), and the inner side of the ADF (white area) (B) gently. Make sure not to leave any residue, especially on the Platen Glass.
sikaku.gif Cleaning the ADF i_expl.gif Caution
1. Open the Document Tray.
2. Open the Feeder Cover.
3. With a soft, clean, lint-free and dry cloth, wipe off any paper dust from the inside of the Feeder Cover (A).
4. After wiping, close the Feeder Cover by pushing it until it clicks into place.
5. Close the Document Tray.
6. Reconnect the power cord then turn on the machine.
Oct 27, 2010 | Canon PIXMA MX850 Multifunction Printer
How come my canon mp830 printer prints a black line on left side when using ADF?
there are many possibilities that you will have to check out for: 1)either there is any dust got collected in the ADF assembly.so that dust is also coming in the prints. 2) of there is any thin object like hair got stuck up in the inner side of the ADF assembly.so whenever the print comes this copy of hair comes in every print out. 3) also there can be a slight crack in the ADF glass assembly.so this slight crack is giving the line in prints. 4) also the other reason can be that the black cartridge is low on ink.in this case it needs replacement of cartridge or the cartridge refilling. ----- so the first step you can follow is that you take a cleaning brush and clean all the dust on the upper ADF glass assembly where you place the paper.then take a moist tissue and clean the glass of the ADF assembly. then check out.if still the same problem then take a air blower and blow the air in the inner as well as outer area of ADF assembly and check out.if still the same problem then check out if any crack on the ADF assembly glass.if no crack then its the fault in the inner side of glass.for this the assembly and printer both needs to be disassembled.but this will require proper tools.its advisable to get it done by local printer/copier repair technician familiar with this brand/model. This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Mar 09, 2010 | Canon Office Equipment & Supplies
Where can I get a replacement plactic screen cover
This set has 3 screens---the outer one is really only for glare--clear plexigalss--no longer available from Sony.
Sony 4-070-602-01
SCREEN, FRESNEL Sony 4-064-343-11
SCREEN, LENTICULAR Sony 4-058-894-11
SCREEN, PROTECTION (CONTRAST)Outer one is (Contrast) the other two inner ones are showing as available and about 180 each.
You would have to either have someone dismantle or do it yourself---most of these sets you have to remove all three screens from the rear of the set---then remove the outer contrast one if it is scratched or cracked--
If you get it out and measure it: It is possible you may be able to find a company who can cut you a plexi-glass piece to replace it with--lots of work to do this and you have to use extreme care when you remove the two inner screens--easy to damage them---Usually the inner two are taped along all the edges to keep dust etc from getting between them and the front one is a short distance forward of them.
The front protective screen is really only there for glare and to protect the inner screens from damage---I have seen people who had a cracked outer one just dismantle and remove that one---put the others back and use the set that way---have to be careful as the inner screens are easy to scratch or damage with the outer one removed.
Also---I have seen several where someone removed the outer one and got a piece of plexi glass big enough to put on the outside of the front of the set---secured all around the edges with velcro--does not look as good as the original but prevents glare and protects the inner screens.
If this told you something you did not know or helped you rate this solution as I do this here for free.
SD TECH
Jan 03, 2010 | Sony KP-53V80 53" Rear Projection...
Frigidaire Self Cleaning Electric Oven - Inner glass shattered, need part and instructions for door
It isn't that tough to change the glass assembly. Most of the Frigidaire have 4 screws that hold the front of the door to the inner part- sandwiching the glass in between. It is only sold as a unit- 2 glass pieces, assembled with an aluminum frame. Call All brands Appliance parts at 508-587-7100 and they'll get the part out to you. (Tell them Greasy Wheels sent ya, they'll take good care of you.) The most common reason the glass breaks, is a scratch in the glass. Sometimes it's just a dragged pan, other times it's from cleaning it with a sharp instrument. Don't do that....
Oct 24, 2017 | Ovens
Power window problem. engauges then disenguages
Section 01-11: Glass, Frames and Mechanisms 1997 Windstar Workshop Manual REMOVAL AND INSTALLATION Door Glass and Regulator, Power Windows Removal
svw~us~en~file=ani_caut.gif~gen~ref.gif WARNING: IF THE REGULATOR COUNTERBALANCE SPRING MUST BE REMOVED OR REPLACED FOR ANY REASON, MAKE SURE THAT THE REGULATOR ARMS ARE IN A FIXED POSITION PRIOR TO REMOVAL TO PREVENT POSSIBLE INJURY DURING C-SPRING UNWIND.
  1. Remove front door trim panel (23942) and front door inside panel sound insulator (20394). Refer to Section 01-05 .
  1. Remove inside door belt weatherstrip.
  1. Remove front door window glass (21410) as described in this section.
  1. Remove two nut and washer assemblies attaching the window regulator equalizer arm bracket (23230).
  1. Remove four rivets retaining the front door window regulator base plate to door inner panel.
  1. Remove front door window regulator (23200) and front door window channel bracket (23288) from vehicle.
  1. Working on a bench, carefully bend tab flat to remove front door window regulator arm slides from front door window channel bracket.
  1. NOTE: Use care not to break tab; if tab is cracked or broken, replace front door window channel bracket. Make sure rubber bumper is installed properly on new front door window channel bracket, if replacement is made.
    Install new front door window regulator arm plastic guides into front door window channel bracket and bend tab back to 90 degrees.
Installation
NOTE: The front door window channel bracket and window regulator electric drive (23394) are installed into the vehicle as one assembly. The front door window channel bracket may be disassembled from the window regulator electric drive as described in Door Glass and Regulator, Power Windows .
  1. Install window regulator electric drive with preassembled front door window channel bracket into vehicle. Set the regulator base plate to door inner panel using base plate locator tab as a guide.
  1. NOTE: Two 1/4-20 x 1 inch bolts and two 1/4-20 nut and washer assemblies may be used as alternates for glass retention. However, torque must not exceed 4-7 Nm (35-44 lb-in). Equivalent metric retainers may be used.
    Install four rivets to retain front door window regulator to door inner panel.
  1. Install window regulator equalizer arm bracket.
  1. Lower front door window regulator arms to access holes in door inner panel. Install front door window glass as outlined.
  1. Install inside door belt weatherstrip.
  1. Adjust front door window glass to make sure it is properly aligned with glass run. Check window for smooth operation.
  1. Install front door trim panel and front door inside panel sound insulator. Refer to Section 01-05 .
Item Part Number Description 1 21410 Front Door Window Glass 2 23288 Front Door Window Channel Bracket 3 23394 Window Regulator Electric Drive 4 23230 Window Regulator Equalizer Arm Bracket 5 222A00 Front Door Glass Run Latch Side Retainer 6 N621906-S36 Nut and Washer 7 N800510-S36 Screw 8 23200 Front Door Window Regulator 9 W525172-S Rivet 10 W525175-S Rivet 11 — Wire Connector (Part of 14630 Wire Assembly) A — Tighten to 7-10 Nm (62-89 Lb-In)
Apr 13, 2009 | 1997 Ford Windstar
Lines all over second page
It is possible to clean the inner side of the glass. First you need to remove the scan module by removing two screws on each side, then remove the cable. Carefully take out the module. You will notice 4 small screws in the side, after removing which you can detach the LED module. Remove the vertical screws and this will detach the Lens Module. Now you will have access to the inner side of the glass. Ensure that the electronics, the Lens module and the LED are carefully placed back and cable connected properly. There is a small spring plate screwed along with the LED module, which needs to be placed properly. Please do not use any sharp instrument.
S. Mohan, Chennai, India
Jan 28, 2009 | Canon DR-5060F Pass-Through Scanner
Panasonic Viera TH-50PX80U Plasma TV Logo
123 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
