Question about Nuova Simonelli Premier Maxi Espresso Machine
How do you program the volumetric settings for various brewing buttons??
  • jodydandmike Dec 10, 2008
    need to know how to set all the electonic data on setting for my shots wich are not running consistantly ive messed with grind shutt it off not depending on the timed system ,,,
    im only getting a crem shot off one head and it doesnt have the right smell or taste im after its almost as if my pressure is bouncing around
Could be a couple of things. You will know if the pressure is bouncing around by watching your gauges. You want to pull between 9-10 bars when pulling a shot. The programming issue could be the fact that if it is used it could have what I like to call
a touchy brain board. Those do have to replaced every so often depending on how much use the machine gets. You can reprogram whenever shots start pulling bad until you have no choice but to replace the brain board. They are cashy. To program: push the stop and pitcher button at the same time and all lights will start flashing on that head. Have your grind set, use a lined shot glass and measuure your shots according to short or long, watching the flow, crema etc. The ultimate shots pull between 25 and 28 seconds.
Hope this helps.
Posted on Feb 12, 2009
SOURCE:
How do you manually fill the boiler tank of a Nuova Simonelli Premier Maxi 2 Group?
by opening the bypass valve under the tray need the drain. but certainly you have a problem with either pump motor or volumetric pump
Apr 14, 2016 | Nuova Simonelli Premier Maxi Espresso...
I have a Nuova Simonelli Aurelia, suddenly the machine lost power? any help
Check the breaker. It might be too much for the circuit with other appliances. If the breaker is OK, pull the plug on the wall and then count to 10 and plug back in.
Jan 29, 2016 | Nuova Simonelli Aurelia Volumetric 2 Group...
Nuova simonelli manual switch flashes
it means that no water is flowing on the flowmeters. need to check flowmeters if clogged
Jun 03, 2013 | Nuova Simonelli Coffee Makers & Espresso...
I have a premier maxi which recently stopped heating the water. When the coffee is brewed, it comes out cold. not hot water and no steam. What can the problem be??
First thing I would check is the reset thermostat on the right side of the machine above the element. Turn machine switch off then push in on pin you will hear a click.
Aug 06, 2011 | Nuova Simonelli Premier Maxi Espresso...
Nuova Simonelli Premier Maxi V , 2005...when water turned on machine constantly leaking from the pressure relief valve and the hot water valve.
Has the machine been in cold storage? If no then the inlet solenoid could be the culprit. There might be sediment keeping the valve open.
May 11, 2011 | Nuova Simonelli Premier Maxi Espresso...
I have a 3 group 2002 premier maxi. the laft and
The metering jet filter on top of the heads are blocked or the solenoid coil is damaged.
Jun 18, 2010 | Nuova Simonelli Premier Maxi Espresso...
Nuova Simonelli Premier Maxi Espresso Machine Logo
371 people viewed this question
Top Nuova Simonelli Coffee Makers & Espresso Machines Experts
Pierre Laplante
Jeffrey Groves
Jeffrey Groves
markybean
Level 1 Expert
Are you a Nuova Simonelli Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
