Question about Car Audio & Video
Hi, I've dropped my face unit and now it has no display. The unit works ok though. Any simple suggestions to fix it? Thanks Ed
  • Ed Holmes
    Ed Holmes Apr 07, 2011
    Hi, its a DEH P70BT.
    Thanks Ed
  • 6,993 Answers
What it the name and model of the unit that is not displaying any longer after it dropped?
I look forward to your reply......
Bye for now.
Posted on Apr 06, 2011
Kia sorento temperature display not working
is it possible a fuse that may have blown? something simple anyway,im pretty sure of that.
Apr 13, 2013 | 2003 Kia Sorento
My blinkers don't work. Its an 87 ford tempo. Have extra fuses and stuff I've been told its all I need to replace and fix my car. Where do I start though?
make sure your fuses are ok and youve got power if ok check the blinker sender unit its usually round and silver with 2 or 3 wire going to it. usually under the dash but could be in the engine bay
Nov 19, 2012 | 1987 Ford Tempo
Hello, I've got a Denon AVR-2106 dropping into standby every time I turn it on. I know this is fairly regular problem, and I've seen plenty of posts here suggesting things to look at to diagnose...
check the power supply for the micro controller \ logic.
5 or 3.3 Volt IC's
And check with AC measurement too ( try to measure AC ripple )
Could very well be dry electrolytic capacitors with excessive ESR.
Ed
Mar 14, 2017 | Denon AVR-2106 Receiver
Oven control lock beeping along with F3:E4 flashing on the display
Hi-- The code described; F3 E4  indicates an open circuit- oven sensor.  As far as oven problems go this one is easy to fix. -------Unplug sensor and check resistance. Normal is around 1100ohms. ---If open, then replace with new part.  <This will solve the problem>.  You did not provide any other information besides 'beeping' and 'F3:E4'.  A simple Model # from the tag on unit is required for any service or information.  However, since this is a specific fault code, the oven temperature sensor is the most likely suspect. Please acknowledge this post. Solution is to replace the oven temperature sensor.  Thanks-  Ed
Mar 30, 2010 | KitchenAid Ovens
BATTERY CHARGING PROBLEM
hi there!
thanks for using Fixya.com!!
I suggest, try to change your battery to anew one. then charge it, if you are still facing the same problem, check the charger (but make sure you are using compatible and original charger ok?).
If you are experiencing the same problem though you are using the original charger, please change your charger to anew one, just to make sure that you do not have any problem with your phone.
then, if the same problem occurs, then perhaps you have a problem with phone itself.
Better, bring it to your technician, to have a better troubleshooting of your phone.
Hope this will help you, a simple solution, with a simple and handy troubleshooting.
Thanks! don't forget to rate me with my solution!
Feb 21, 2009 | Sony Ericsson J230i Cellular Phone
Having compaq presario c700 facing cound problem......
hey!
we have to face it, the microphone feature is not working on XP. i've tried to install it a millionth times, no go. it's working very well on vista. if you want, you can just try to do dual boot. both XP and Vista in one system. just a suggestion though...
Hope this helps!
Thanks,
Karlox™ :)
Jun 06, 2008 | Compaq Presario 700 470024-192 Notebook
LG DLG 5988B gas dryer not heating
HELLO:
Have you looked at the over heat sensor on the left hand bottom of the burner pipe?
I found this and with a simple test with a butane lighter.
I used a cheep Digital volt meter and set it to ohms.
The sensor was open meanning that their was no connection between the terminals.
On the rear of this sensor there is a small button.
When I pushed the button I hear it click and the switch closed up.
I reinstalled it and the machine work perfect.
I think this is a fail safe if the exaust flue becomes clogged.
Otherwise why would it have a re-set button on it?
I am not a service / repair person.
Unplug the unit before you take the lid and front cover off.
the burner unit is in the lower right hand corner as you face the dryer.
The top comes off first and then the control panel and then you can remove the door and fron panel to expose the blower and burner.
Be carful and good luck.
Uncle Ed.
Nov 05, 2007 | LG DLG5988 Gas Dryer
Dual XD7600 Head Unit Problems
Sounds like the flexible connector that connects to the drop-down front panel is bad, broken pattern lead.
Aug 07, 2007 | Dual XD7600 CD Player
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
