Question about Admiral AW22 Top Load Washer
I have an Admiral MOD ATW4475VQ0. The problem is when the washer should go into the Spin Cycle. The washer goes through all the other settings, but when it gets to the Spin Cycle it clicks then continues to go through the rest of the cycle without spinning. If I set the dial manually about 1/8" before the spin setting it works fine. What can cause this and how do I repair this issue?
  • 958 Answers
SOURCE: Admiral washer AAV8000AWW
the timer motor is either bad or there is no power going to the timer motor.that is why the timer is not running.
Posted on Feb 29, 2008
  • 351 Answers
SOURCE: Admiral AAV8000AWW washer - clothes are wet after spin cycle...
may be a loose belt or a partial blockage somwhere.
Posted on Mar 08, 2008
  • 1314 Answers
SOURCE: Admiral top loader no spin cycle
you can take an ohmmeter and remove one lead from the switch set your meter to continuity and see if it reads open then depress the switch and see if its closed or take both wires off the switch and put a jumper wire in the connectors to bypass the switch and see if it spins and yes its normal to keep agitating with the lid open the switch just works on spin
Posted on Mar 15, 2008
ngafm
  • 166 Answers
SOURCE: Runs great stuck on rinse cycle
Peace,
ngafm to your rescue,
Yes it is in the dial and mechanism of the timer!
Things wear out! So is life!
Only a trained laundry tech can make the electronic diagnoses.
How old is the washer?Sounds old!
If the appliance is 10 years old or more you it may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
Water,Electric and detergent! And put money back in your pocket!
The new appliance will pay for itself in only a few years!
You will be fine
Bless You ngafm
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF
Posted on Sep 08, 2008
  • 17 Answers
SOURCE: Washer does not spin clothes out properly
check belt may be worn out
Posted on Apr 10, 2009
Admiral washer machine tub appears loose and unattached in rrear
First of all is your machine working or not?
If it is working and it's a front loading machine. The machine drum is hanging inside the machine using strong springs that helps it to reduce vibrations during washing and spin cycle.
When machine goes into spin(dry cycle), it usually shakes a little.
Dec 08, 2014 | Admiral Washing Machines
Ge super capacity plus washer. Mod wlse3150a0ww. no matter what setting it always starts on rinse then goes to spin.It also will not drain.
If the washer is stopped mid cycle it will default to rinse and spin. It will then get stuck in a loop. It is necessary to reset the electronics. Unplug the electrical cord from the unit. Wait 30 seconds. Turn the cycle selector all the way around clockwise. Turn it again and set it on any setting accept rinse or spin. Plug the unit in. It should begin a new cycle and be working normally.
Jan 22, 2010 | GE 3.2 cu. ft. Washer
Water temperature not consistant with Admiral Washer Model: ATW4475VQ0
replace the thermistor . as it is or has failed . pt # w10144820 / complete assembly .. this chould correct the problem . **** hop this will help feed back pls .
Dec 23, 2009 | Washing Machines
Admiral mod#lnc6760b71
Water runs out, but does not spin, nor dry the clothes. Motor is good.
Dec 08, 2007 | Admiral AW22 Top Load Washer
Nov 09, 2007 | Admiral AAV7000A
Admiral AW22 Top Load Washer Logo
56 people viewed this question
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
