Question about Panasonic DMR-EH50S DVD Recorder
While going through the setup procedure the Set 3 was accidentally changed to Set 1. Any activation of the Control setting only makes the unit go to "Set 1" It appears to be locked up at that point. The instructions for resetting do not work.
  • Panasonic Master
  • 508 Answers
You can try resetting the remote itself (this is necessary whenever the batteries are replaced). Remove the batteries, as if to replace them, press any key on remote (to clear its buffer) then reinsert them. Next step, since your unit is 'Set 1' (or remote command mode 1 - DVD1/RC1) - you could (on the remote) press 1 and OK/ENTER together - hold them for 10 seconds, then release.
This should restore the remote to the unit. If it doesn't, a workshop service may be required to reset the unit internally, but at a cost. Try the remote battery reset first (even try using new batteries).
Posted on Apr 06, 2011
Testimonial: "Your correction routine works like a charm. Thanks a million from an 88 year old who has been working in electronics since July 1941."
  • Demonic-2011
    Demonic-2011 Apr 07, 2011
    Instructions seldom help the user, glad you asked FixYa :)
Accidentally set my TV to factory defaults
only digital signal is available now analog has been switched off no longer transmitting. You could try returning in all of your channels from the main menu the tv can do this automatically but you need to select the procedure . retune the digital channels only
1. click on the home button
2. scroll sideways till you reach settings
3. in settings scroll down or up and click on digital set-up (centre button of your scroll control)
4.then scroll down to, and click on digital auto tuning (centre button of your scroll control) this will activate automatic channel tuning the tv will do the rest and will wipe out old settings and retune in all channels
Jun 04, 2013 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Setting up my Harmony 880 to work with My Sharp Aqous TV and LG 3400 DVD player - I gt no picture or sound
Begin the Setup Process
Step 1: Create your Harmony Login
If the Harmony remote web site is not automatically launched, go to the Harmony remote web site and
create an account.
Step 2: Complete the Online Setup Process
Once you have created your Harmony login, the online setup process begins. You will guided through a
series of question-and-answer steps to complete each of the five main steps of the online setup process:
1. Identification: Requires you to create a login on our member web site.
2. Check Connection: Ensures your computer and your Harmony remote are communicating
properly.
3. Set up Devices: Helps you set up a description of your personal home theater system.
4. Set up Activities: Helps you set up a description of the connections for devices that allow you to
perform Activities (e.g. Watch Television Activity).
5. Update Remote: Updates your remote with your personal configuration.
Jul 09, 2012 | Logitech Harmony 880 LCD Remote Control
Code ck sr tuner no sound
Hello
So many improper commands send to the unit may make its system and memmory to be confused, and will not operate properly. Just reset the unit to factory settings, and try.
To reset the unit to factory default settings, so the following
[1] Press STANDBY/ON on the front panel to set this unit to standby mode.
[2] Press and hold TONE CONTROL and then press STANDBY/ON to turn on this unit. The advanced setup menu appears, in the front panel display.
[3] Press PROGRAM buttons to select PRESET.
[4] Press STRAIGHT repeatedly to select RESET.
[5] Press STANDBY/ON to confirm your selection and set this unit to the standby mode.
This procedure completely resets all parameters of this unit including SET MENU parameters. However the advanced setup menu parameters will not be effected. The intial factory paramenters will be activated next time when you turn on this unit. To cancel initilization procedure at any time without making any changes, press STRAIGHT repetedely ot select CANCEL and then press STANDBY/ON.OK.
Apr 03, 2011 | Yamaha RX-V463 Receiver
My niece decided to push a rather odd sequence of buttons on the sound system and now nothing is setup correctly. while i have fixed the niece problem, i have yet to figure out why i cant fix the sound...
It's in the manual on page 59.
1 Press STANDBY/ON on the front panel to set this unit to the standby mode.
2 Press and hold
The advanced setup menu appears in the front panel display.
3 Press PROGRAM l / h to select “PRESET”.
4 Press
STRAIGHT repeatedly to select “RESET”.
Select “CANCEL” to cancel the initialization procedure without making any changes.
5 Press STANDBY/ON to confirm your selection and set this unit to the standby mode.
• This procedure completely resets all the parameters of this unit including the set menu parameters.
• The initial factory settings are activated next time you turn on this unit.
To cancel the initialization procedure at any time without making any changes, press STRAIGHT repeatedly to select “CANCEL” and then press STANDBY/ON.
Aug 14, 2010 | Yamaha HTR-6130 Receiver
My 8330 does not let me browse the internet on my
Hi BlackBerry smartphone with tethered modem capabilities can be used as an external modem to connect a computer to the Internet.
To set up a tethered modem, complete the following tasks from A to D
A) Install BlackBerry Desktop Software 4.1 or later on your computer.
B) To set up an Internet APN, complete the following steps:
1) Click Start > Settings > Control Panel.
2) Double-click Phone and Modem Options.
3) In the Phone and Modem Options window, click the Modems tab.
4) Select Standard Modem and click Properties.
5) Click Change Settings.
6) In the Standard Modem Properties window, click the Advanced tab.
7) In the Extra initialization commands field, type the following:
+cgdcont=1,"IP","<your Internet APN>"
The extra initialization command is: +cgdcont=1,"IP","wap.voicestream.com"
8) Click OK.
9) In the Phone and Modem Options window, click OK.
C) To configure dial-up networking, complete the procedure that is appropriate for Windows Vista
1) Click Start.
2) Select Connect To.
3) Click Setup a connection or network.
4) Click Setup a dialup connection.
5) In the Dial-up phone number field type *99#.
6) Type the user name and password provided by your wireless service provider.
7) In the Connection Name field type BlackBerry.
8) Click Dialing Rules.
9) Make sure the profile created in Task 2 has been selected, and then click OK.
10) Select Connect to establish an Internet.
D) To connect to the Internet using dial-up networking, complete the following steps:
During this procedure, do not operate the BlackBerry Browser or any third-party applications on the BlackBerry smartphone. An active data session might interfere with the modem connection. Also, make sure an ethernet connection is not active at the same time.
1) Connect the BlackBerry smartphone to the computer.
2) Open BlackBerry Desktop Manager.
3) Click Start > Settings > Network Connections > <name of your new connection>.
4) Type the user name and password provided by your wireless service provider.
5) Click Dial.I hope this information will help you
Nov 26, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
I have a (cyberhome ch-dvd 300) dvd player and changed setup menu now lost video cant see to change back is there a reset code or something
I wish I could find the website that gave all the repair hints for this DVD player, but I downloaded the info, and can no longer find the site. Here is what it says with regard to your symptoms. I hope this helps. I have done all the mods the site suggested, but continue to have difficulty with the remote, tray opening, etc. I have 2 machines and used to love them, but frustration has taken it's toll. Recovering from a condition with no TV picture
Accidentally switching to PAL and getting a rolling black & white picture happens all the time to baffle users, especially on models with a System or P/N key on the remote. To get back your color and sound just switch to the proper system in the menu or put in a movie of the correct type and it can switch automatically or try the procedure below for resetting to the defaults.
Sometimes owners will accidentally switch to Progressive Scan in the menu then get no picture at all. You can fix the no picture condition on the CH-300 by resetting the defaults to interlaced as mentioned in the users manual:
"To reset the VIDEO OUTPUT, turn Off the player, turn back On, open the disc tray and press and hold the Stop button on the player for 10 seconds to reset the scan mode."
The Reset procedure doesn't seem to work on all versions but you can sometimes get a usable B&W picture allowing you to get to the menu and change the settings by connecting the composite video input of your display to the Red Pr/Cr or Green Y component output jacks on the rear of the cabinet.
You can also go into the Menu and set it blind with the following key presses on the Remote:
1. With the unit Stopped, press Setup.
2. Press Enter.
3. Press the Down Arrow 3 times.
4. Press the Right Arrow Once.
5. Press Enter.
On 300Z & 300ZS models if the video is set to Progressive Scan and you can't get a viewable picture on the Red or Green jacks try going into the Menu blind and changing it back with the following key presses on the Remote:
1. With the unit stopped, press Setup on the remote.
2. Press the Right Arrow Once.
3. Press Enter.
4. Press the Down Arrow 2 times.
5. Press Enter.
6. Press the Up Arrow 2 Times.
7. Press Enter. This should switch it back to Interlaced scan with S-Video and Composite output.
To change the Parental Control setting on the CH-300 use the factory password of 3351. For the CH-400 use 1379.
Nov 02, 2009 | Televison & Video
Computer set up
There are three sections in the language application that you must work on.
1. The first tab, in the first section, set it to "English (United States), and in the second lower section, set it to United States.
2. The second tab, in the top section press the button and in the first section of the new box use the drop down and select "English (United States)-US. The box below should have what language the keyboard is set to input. If you make changes, the bottom right button is "Apply".
3. The third tab, in the first section, the drop down menu should be English (United States).
Once again, press the Apply button when you have finished making changes.
Dec 25, 2008 | Computers & Internet
Romote control not working
1. The owner's manual is available online:
http://www2.panasonic.com/consumer-electronics/support/Video/DVD-Recorders-Players/DVD-Recorders/model.DMR-ES35VS
Download the manual under Operating Instructions.
2. To remedy "SET1" problem, Press 1 & Enter at the same time.
Hope this helps
Aug 10, 2008 | Panasonic DMR-ES35VS
Awa lmd5908cp region codes
Please be advised following procedure for set the region code to
multizone.
1. Power on the unit
2. Open DVD door
3. Press setup button on remote control.
4. Press right button on remote control 3 times.
5. Press 9653 continuously, then you will see the default region code on
the screen.
6. Select 0 to set region code to multizone.
Jun 16, 2008 | Televison & Video
Parental control code
ok first go to the DVD setup which should be located near the bottom of the remote is says SETUP. Then it will give you a list of options go to the one with the parental code one. Then you should try and change the password. My tvs old password was 8888 but I am not sure if it is the same on all tv's. If it is right then you should be able to change the password to whatever you want! I hope this helps anyone who sees this response!
Sep 09, 2007 | Aiwa VX-S207 20 in. Combo
Panasonic DMR-EH50S DVD Recorder Logo
103 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
