Question about Whirlpool Washer Motor Coupling 285753A
Need wireing digram no voltage on water valve motor bad will a bad motor kill the voltage to the water valve
My dishwasher will not fill
Earl,
If you have had any work done under the sink, double check and make sure the water to your dishwasher was turned back on. Assuming that the water is on, your other choices are that you have a bad water valve, which you can check if you have access to a multimeter. Set your meter to voltage, unplug the wires harness going to your water valve and if you have a knob to set your program, slowly turn that knob to where you would start the cycle and see if you get voltage when you put the probes into the wire harness. If you have voltage then the valve is bad and needs to be replaced. if you have no voltage then you may have a bad timer or control board. If you do not have a knob to set the program but push buttons instead, you basically would do the same thing to start the cycle to get those same results. Hoe this helps!
May 21, 2015 | Kenmore Elite Stainless Steel 24" BuiltIn...
Driver side power window not working
can be 3 things. (4)
1: bad wiring, connections,, not a fuse that would kill others.
2: bad switch.
3: bad window motor.
4: window frame jamming.
the tests are simple and in the FSM (factory service manual).
factory FSM
Alldata online
mitchells online
others.
in short, using a meter finds this easy.
using meter you can check the voltage to the motor.
and current.
if the voltage is good an current 0 , motor is open
of the voltage is low and current excessive the motor is shorted.
if the voltage is 0 and no current the switch or wires are open.
is that what you seek or just a wild guess.
if the latter, id say, rolling dice,,, wire fell of switch.
Apr 06, 2013 | 2004 Suzuki Verona
Does the vent motor come on when you turn on a powervent hot water heater
`1) Copy following link to troubleshoot by type of gas control valve, blower motor links, pressure switch testing, and other professional resources:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
http://www.thetankatwaterheaterrescue.com/forums/forum3/
2) Power-vent blower motor can go bad.
Plug motor directly into outlet, or turn on-off switch on, and see if motor works.
Check outlet for correct polarity, and for at least 80% of rated voltage.
Check vacuum switch. Blower creates vacuum, and the vacuum switch detect vacuum, and signals gas control valve that burner sequence can continue.
Gas control valve can also go bad. Wiring etc can go bad.
Feb 04, 2013 | Rheem 50 Gallon FVR NATGAS Water Heater...
I'm getting no spark to the plugs .the bike has been standing for ten years.Looking for the wire digram gs550e 1980. pls can you help. thanks
There are 2 coils on your bike. If no spark at all 4 spark plugs, it could be bad kill switch. Disconnect the wires going to both coils. You should have battery voltage at one of the leads going to each coil with the key on. If spark at 2 plugs of the same coil, the other coil could be bad.
Good luck, i hope this helps.
Jun 28, 2011 | 1984 Suzuki Gs 550 L
Dishwasher goes thru cycle but does not get water to spray sounds like pump is runing but no water
Greetings,
its possible the pump motor is bad, this is if it fills with water , but does not wash...if it does not fill with water..Its possible the water valve is defective, broken wire or the pressure chamber....there is alot of possible reasons...mosy likely, check voltage at water valve first...simple things I found was , someone worked on something under sink and turned off water valve going to d/w, check this as well......
Dec 28, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Only cold water water lines good
if you have switched your hot with your cold and now have only hot, your water inlet valve is either bad or it may not be getting the voltage to open the solenoid. Check your wiring and see if you get voltage to the hot water side of the inlet valve. if you do have voltage change out the water valve.
Mar 09, 2010 | Kenmore Washing Machines
The dishwasher will not drain after its' cycle.
Your dishwasher uses one of two ways to drain. It either opens a valve on the main pump while it's running to let it pump the water out, or it turns off the main pump and uses a smaller pump with a separate motor to drain the water. You'll know which method it uses by the sound it makes when it drains, provided it's working properly. If it sound like it's running normally when it drains, but maybe quieter, it uses the main pump motor and opens a valve to drain. If it sounds completely different than it does and sounds like a different motor running when it's draining, it's using a separate pump to drain.
If your dishwasher uses the main motor to drain, you'll need to check the drain valve to see if it can open. Pull out the dishwasher, with the power turned off, being careful not to damage the sometimes fragile water line, and find the drain valve. It'll probably be located in between the big motor the drain hose. The valve's electromagnetic operator will be on the outside of the tube where the valve is. Make sure it's connected to the wires and make sure the valve isn't blocked with gunk.
If the dishwasher uses a separate pump motor drain, pull out the dishwasher with the power off, being careful not to hurt the sometimes fragile water line, and locate the drain pump. It'll be connected between the big motor and the drain hose. You may need to disconnect one of the hoses and make sure the impeller can turn freely. It may be blocked with gunk. Make sure the wires to the pump's motor are connected properly.
You may also need to check that the wires are plugged into the dishwasher's controller properly.
If the problem is still happening and you checked either the drain valve or drain pump, it'd help to get an electrical meter, disconnect the the wires from the drain valve or pump, and check to see if you can read a voltage on those wires when the dishwasher is trying to drain. If you can read a voltage, the drain valve or pump probably needs to be replaced or repaired. If the voltage doesn't show up, the problem is in the wires or the dishwasher's controller.
If it uses a mechanical knob that rotates and controls the cycle, you need to make sure the drain wire is connected properly. You could take apart the knob timer box to and replace the switch behind the control wheel that turns the drain function on and off.
If the dishwasher uses a digital controller, with buttons and lights and stuff, Follow the drain wires to the control board in the door and make sure they're plugged in. If you see a small black, blue, gray, or white box cube on the circuit board close to where the wires connect, tap it firmly with a screwdriver. That is a switch controlled by the microprocessor that turns the drain function on and off.
Sep 20, 2009 | Hotpoint Dishwashers
Maytag performa PAV2200 - cold water fill does not work, but hot does
Check the solenoids at the water inlet valve. They can be checked using a multimeter or ohm meter for continuity. If either solenoid has none, it is defective and the water inlet valve assy will need to be replaced. I am attaching a photo for reference. Hope this helped and best wishes.
Aug 04, 2009 | Maytag Performa PAV2200
My car rpm need drops down below one and them come back up one minute later ruff idle it feels as thoe it going to stall on me i need to find an engine digram so i can fix the problem i am no machanic but...
It could be many of things, i dont have a digram, however check for a vacuum leak, i had a similar problem on the PCV valve, there is a tube that runs from it, on the front of the motor next to the header and goes to the back under the center of the intake manifold. Its hard to get to if its messed up. Have you done a tune up, plugs, wires, filter(air and fuel)? if the fuel filter is badly clogged it may not be getting enough fuel ? Hope I could help.
Jun 03, 2009 | 2002 Ford ZX2
Inlet Water
do you have voltage to the water valve if no then check the float switch if switch is good problen is in the control
if you check the water valve and have voltage to the 2 wires on the valve ac voltage btw then the valve has to be changed
Apr 23, 2008 | Dishwashers
Whirlpool Washer Motor Coupling 285753A Logo
27 people viewed this question
Dan Webster
Dan Webster
Sal De
