Question about Texas Instruments TI-5660 Calculator
Help. How do you replace the roll of paper. I need a diagram
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
How do you replace the thermal roll to get it to print
Make sure you are using thermal paper which is 57mm wide.
Open the printer cover. Lift the paper holder lever on top of the printer. Remove the old tube from the last roll if it is still in the bottom of the printer. Drop the new roll into the roll holder in the bottom of the printer. Make sure the paper is coming from the bottom of the roll rather than off the top as it unwinds. Pull the paper out the front of the printer and close the paper holder lever down onto the paper. The shiny side of the paper should be facing you as it comes out of the printer. If not, the paper will feed out blank during printing. If you are replacing the journal roll, slip the end of the paper into the slit in the takeup spool (black reel) and wind over a couple of times before dropping into place. Replace the printer cover and make sure the receipt comes out of the cut out in the cover.
Good luck.
Jul 11, 2015 | Casio PCR-T2000 Cash Register
Trying to put in a new paper roll
Turn off the Sharp EL-1801V.
  • 2 Cut the end of the replacement paper roll for a fresh edge and to ensure a smooth feed. Do not tear the paper roll, as feeding a torn paper roll can cause a paper jam.
  • 3 Insert the cut edge into the paper opening on the back of the Sharp EL-1801V. Hold the paper roll so that the edge being fed into the machine is coming from the bottom of the roll. Turn the power on.
  • 4 Press the "Feed" button until the paper is fed through the unit. Lift the metal paper roll holder up. Slide the paper roll onto the paper-roll holder.
  • Read more: Directions for Replacing the Paper Roll on a Sharp EL-1801V ' eHow.com http://www.ehow.com/how_7294657_directions-paper-roll-sharp-el_1801v.html#ixzz1eNqkJA8g
    Nov 21, 2011 | Sharp EL1801V Scientific Calculator
    Trying to replace the paper roll on a sharp EL1801V
    1 Turn off the Sharp EL-1801V.
    Got problenm went scanning and sending fax. the paper connot go true, every time we want fax & do scanning got problem same. Please help, very urgent.. Thank you Regards, Ana
    if the paper feeder (the rolling that retract paper) not rolling.
    you have to replace it. only a technician can do it.
    if its rolling, maybe an object is blocking paper to go through . cleaned it.
    Mar 04, 2011 | HP OfficeJet 4255 All-In-One InkJet...
    I need to order printing tape or paper for the P1-DH V. What is the item number for that? Thanks.
    There is no specific item number for the printing paper for this model. You can buy any brand of paper rolls, but it must be 2 and 1/4" or 57mm wide. Just go to OfficeMax or Staples and just look for the paper rolls that are 2 and 1/4" wide. If you need a lot of them I would go to Costco, great deal on paper rolls
    If you need a new to replace the ink roller the item number is CP-16
    This should help you out
    Jan 24, 2011 | Canon P1-DHV Calculator
    In my Selphy 710, the paper wont feed from the tray to the printer. The rollers are rolling, and the paper gets pushed up to the rollers, but Im not sure if its not gripping the paper, or if the timing is...
    sounds to me like the Pick up rollers need to be replaced, you can try to manually clean those rollers with some rubbing alcohol and some q-tips and gently clean those rollers, if that doesn't help then the rollers need to be replaced. You can usually find replacement pick up rollers online
    Nov 18, 2009 | Canon SELPHY ES1 Thermal Photo Printer
    Need help replacing the paper roll on a Casio BIG 12-Digit adding machine.
    Slide off the upper cover of the calculator, and cut across the paper roll to form a clean end.
    If you are mounting the roll externally (outside of the back of the calculator), then look for a slot in the rear of the calculator, which will accept the paper. Feed the end of the paper through the rear slot, and then into the internal feed slot, and hold the [FEED] key. After that, you can flip the arm back to mount the roll and replace the upper cover.
    If you want to place the roll inside of the calculator, then you need to feed from the bottom of the roll into the internal feed slot, and hold the [FEED] key. After you are finished, replace the upper cover.
    Aug 21, 2009 | Office Equipment & Supplies
    Paper will not feed
    What you need to do is remove the tray, and look for the feed rollers and clean them with either alcohol or a soapy cleaner like Fantastic.
    Clean them a few times, make sure they are dry then try again.
    That may solve it completely, or your rollers may be slick and need replaced.
    When those rolls get dirty, it's like trying to drive on ice. You just slip. Also, if those rolls are needing replaced, I wouldn't be upset with the refurb work. Sometimes those rolls fake you out. They appear and to touch feel perfectly fine, but try and feed a piece of paper, and it just won't.
    If you can, look into the paper tray with a flash light, and see if they are turning. If they are, then dirt or slick rolls is the only problem you have.
    Mar 01, 2008 | Samsung CLX 3160fn All-In-One Printer
    Cannot find solution to how to replace paper for the Sharp UX-108 Fax machine
    I must have an operation manual so Ican follow instruction and at the same time I will know what is the trouble.
    Jan 17, 2008 | Sharp UX 108 Roll paper Thermal Fax
    How to load paper
    Just put the thermal paper(paper roll) inside the machine and the SHINNY side of that thermal paper would be on the Top side where the thermal unit is place or vice versa.
    Dec 30, 2007 | Sharp UX 108 Roll paper Thermal Fax
    Texas Instruments TI-5660 Calculator Logo
    50 people viewed this question
    Top Texas Instruments Office Equipment & Supplies Experts
    k24674
    Stevan Milanovic
    Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
