Question about Cycling
Dont no were the adjustment line is - Cycling
    Brigadier General:
  • 8,546 Answers
What exactly are you needing instructions for? Most bikes are just static frames with a bunch of aftermarket stuff hung on them.
Everything on a common bike is found on just about any other brand of bike and the individual components are usually documented at the manufacturers
Posted on Apr 05, 2011
How to reroute the drivibg belt or fan belt
Hi,just inline the crankshaft to the top dead centre marks,then check that the camshaft marks line up,if they dont line up then turn the crankshaft pully again untill the camshaft marks line up,slacken the timeing belt pully adjuster take belt off and replace with new one,tighten the pully adjuster back up,now put a spanner on the crakshaft pully and turn clockwise untill the top dead centre marks and the camshaft marks inline if they dont then slacken the ajusting pully inline marks again and try again,if marks do inline ok then you are ready to start the car.
hope this helps good luck.
Feb 25, 2015 | Cars & Trucks
Screen getting darker and color will not adjust
THIS LOT FAULT AJUSTMENT YOU ARE ELECTRONICS PERSON TAKE 25 W SOLDERING IRON RESOLDERING TO CRT NICK BORAD OR AJUST ON LOT, WATCH BELOW VIDEOS
NOTE:DONT TOUCH LOT ON SUPPLY
DONT TOUCH LOT&CRT LINKING PLACE WITH OR WITH OUT SUPPLY
SEE :LOT(LINE OUT PUT TARASFORMER) IMAGE ON GOOGLE
Mar 23, 2014 | Mitsubishi WS-65819 TV
2.8 td gwm dont wana start
HOWS FUEL LINES FILTERS ETC CARB CLEAN AND ADJUSTED IF SO YOU VALVES ARE NOT ADJUSTED DUE TO WEAR ETC
Jun 15, 2013 | Motorcycles
Distorted picture the screen has lines throughout
do mean retrace lines screen may need adjusting may be i dont know becouse lines in scree can mean any thing
Jun 04, 2012 | Toshiba TheaterWide 52HM84 52" Rear...
Horizontal lines, they can go away for awhile if we move the TV, but they come back. Most annoying. Can't figure out if there is such a thing as a "horizontal hold" button on this thing, but I...
Hello
If your TV has nice thread like horizontal lines on the entire screen, at aboug 1 inch apart or so, it is due to the high screen voltage. In some sets, this voltage may go high due to a defect in screen control adjust preset, integrated to line output transformer [LOT].
You just open your tv and locate the screen adjust control. It can be seen on the above said LOT itself. There will be two adjustable controls, one for adjusting focus voltage, and the other for adjusting the screen voltage.
Dont touch the focus adjuster. The screen adjuster will be at the bottom of the focus control, and both of them have visual markings there stating 'Focus' and 'Screen'.
Just turn the screen adjust control a little, while looking the picture on the screen, and adjust it till the lines on your screen just disappears. Never turn more than this position. The turning must be counterclokwise, not clokwise, as this should shut of your TV.
Take every precautions when we works with an elelctrical equipment. As high as 25,000VDC points are there, while tv is working, you should be very cautious. Do this with confidence. Take care. OK.
Nov 21, 2010 | Zenith Televison & Video
1990 Buick Century custom, 3.3 V6, 4 door automatic. I have replaced the linings, wheel cylinders, both rear drums on this vehicle. When the linings are tight to the drum the brakes seem to operate...
YOUR BRAKES SHOES NEED ADJUSTING THAT WHY ITS LOOSE.SEE YOU ADJUST THE BRAKE SHOES BY TURNING THE STAR WHEEL ON THE ADJUSTER SCREW UNTIL DRUM JUST SLIPS OVER THE SHOES.WHEN TURNING THE DRUM THE SHOES SHOULD NOT RUB IF THEY DO REMOVE THE DRUM AND BACK OFF STAR WHEEL A LITTLE BIT SO THEY DONT.
Feb 09, 2010 | 1990 Buick Century
Convergence On Panasonic PT-47WX54j
You dont need codes for the service menu you need to repair the convergence circuit. If the lines wont line up in the customer menu they wont line up in the service menu either. Do you know how to solder? If so we can fix this yourself with a little instruction. Otherwise you will need to call a repairman. A good repairman will run you $300-$500 depending on your area. Let me know what you want to do.
Tim Nolan
Sep 25, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Day light savings - time adjustment
start -> settings -> system -> clock
Adjust the time, mine does it automatically so i dont know why
it doesnt do it for you, but im sure you can do it manually.
drop me a line if you need more assistance.
Mar 11, 2008 | HP iPAQ rx1950 Pocket PC
Adjusting convergence grid
i correct grid will look all white. all colors aligned up.
you should be able to move the lines with the remote. and you cant burn anything out by doing convergence.
Jan 27, 2008 | Samsung HC-P4752W 47" Rear Projection...
Center screen convergence problem
The convergence adjustment on the TV set are for the center adjustments ONLY. if you cannot get them in or they are way out, then you have a convergence IC problem. Dont feel bad though as it happens to every rear projection set ever made. Good Luck
Dec 30, 2006 | Toshiba 53AX62 53 in. Rear Projection...
Cycling Logo
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
