Question about Toys
I bought a used set on e-bay, and I have no idea how it goes together.
  • 3 Answers
What kind of toy?
Posted on Apr 05, 2011
Do not have a remote
If this is a Hampton Bay fan, you probably can buy a suitable remote from a Hampton Bay dealer...BUT before rushing out to buy a remote, it would be a good idea to find out whether the reason this fan turned up at a yard sale is not that the remote receiver failed
Jan 07, 2013 | Hampton Bay AC418-OBB 60'' Brookedale Oil...
I bought a house with hampton bay fans and used a different lighting kit and hooked blue and black wires together and white to white wires and plugged connector back in and light kit will not light and...
If you have the fan working are sure there is not a light switch some where in th room that goes to the light side of the fan.and the chain for the light will have to be pulled to on also.is it a remote control fan that would have a remote that has been lost.some fans have a little black box in them that is a radio cntrl.you should be able to remove the fan with a few screws at the base next to the ceileing.be careful they can be heavy.
Apr 03, 2011 | Hampton Bay 44 In. White Carousel II with...
I purchased a Wilson & Fisher? 10? x 12? Bay
Call Wilson & Fisher and get the to send you the instruction sheets .
Can do this either by conputer or fax.
Jun 23, 2010 | Garden
Receiver quit. replacement has just one wire and a
all of the white wires connect together and to the white house wiring ... the black of the house wiring goes to the AC input of the module (may be a black wire ) .. the blue wire from the lights goes to the light output of the module (as you already know) ...
now the motor actually has only two wires .. one white that should already be hooked up with all the other white wires .. the other goes to a block that contains the speed controlling capacitors .. and that has the 4 wires (you metioned cominng from the motor) .. the capacitors are no longer needed since the speed control inside the module takes over .. so you can eliminate the capacitor block (thats normally connected to the speed control switch that you wont need either)... that will leave you with just one wire from the motor that has to be connected to the modules motor wire output ... that should do it ... set the code on the module and remote the same (in battery compartment of remote) (good idea to make sure your neighbor isnt using the same code ..
connect the green wire (or bare wire) to the metal of the fan ..usually a green screw or a bare wire .. thats the safety ground ..
May 27, 2010 | Hampton Bay 24002 Ceiling Fan
I bought a Hampton Bay ceiling fan and I have
Hi ,, the usual wiring for the fan / light is that in the ceiling the white wires connect together , the black house wire connects to the black fan wire, the red house wire connects to the other fan wire, usually blue or black with a blue stripe. If this does not resolve the issue, then check the wall switches and see that there is a power wire to each switch and that there is a red wire from the fan on one switch and the black wire from the fan on the other switch ..
Apr 07, 2010 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Bought a used c86 epson off e-bay and it wont
that means that the heads must be replaced or the ink pump is faulty. It is not even worth the repair.
Call the Ebay seller and have your money refunded.
Apr 16, 2009 | Epson Stylus C86 InkJet Printer
Toys Logo
44 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
