Question about Whirlpool Kitchen Ranges
Whirlpool polara refrigerated range displays f3 code after its been on for about half an hour model #ygr556lrkso does anyone know what i can do to fix love this oven...
  • 409 Answers
SOURCE: whirlpool gs475lems range oven problems
it means bake range over temperature.
have a technician check out the oven temp sensor. you may have a short in wiring or it may need to be replaced.
if problem still persists, replace the clock.
Posted on Sep 13, 2008
aborcass
  • 2651 Answers
SOURCE: Whirlpool Gas Range E2 F3
Bake range over temperature, replacing the oven sensor is the easiest and most common solution for this problem.(w10181986) heres the part number
Posted on Nov 23, 2008
I HAVE A WHIRLPOOL GAS RANGE MODEL NUMBER SF379LEMS.OVEN WILL LIGHT UP BUT AFTER TEN MINUTES IT WILL KICK OFF ANF ON ON ,THEN AFTER AWHILE I WILL JUST SHUT OFF.ANY SUGGSTIONS. ADAM
Posted on Nov 24, 2008
SOURCE: Whirlpool Range Model GR399LXG
Accidently hit the autoclean and then stopped it, Now the oven will not lock so I can't clean my oven
Posted on Apr 09, 2010
blueextc3221
  • 15935 Answers
SOURCE: Whirlpool gas range model gw395leps00 error code e2 f3
The F3 E2 error code indicates that the electronic oven control board in the range senses an over-temperature condition in the oven.
This can be caused by a failed temperature sensor probe, a wiring problem between the sensor and the control board, or a failed electronic oven control board.
If the oven is apparently not overheating when this error code appears, then your likely failure is the temperature sensor probe.
If the oven is overheating, then you likely have a failed electronic oven control board due to a stuck relay not cycling the oven heating element off properly.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question####
Posted on Sep 29, 2010
Tip
Whirlpool oven, stove and range fault codes (ERC and EOC display errors).
Here a list of Whirpool oven fault codes. The codes had been collected from different service manuals. This was a memo that I wrote for my own use. I think this can be useful to owners and technicians.
WHIRLPOOL - most models
Range/Stove and Oven Fault Codes, Common error codes.
F1 - Analog control board Failure
Disconnect for one minute - if error comes back, replace control board
F1 - Shorted control keypad
Replace keypad
F3 - Oven temperature sensor open
Replace oven temperature probe
F2 - Oven temperature sensor shorted
F3 - Oven too hot
F3 - Clean temperature too hot
Replace oven probe
F5 - Door latch switch fault
Test and replace the door switch.
Whirlpool with 4 Digit Failure Code:
F1 - E1 - Electronic control (flip flop)
Replace control board
F2 - E0 - Shorted control keypad
Replace keypad
F3 - E0 - Oven temperature probe open
Replace temperature probe
F3 - E1 - Oven temperature probe shorted
F3 - E2 - Oven temp too high
F3 - E3 - Clean temp too hot
Replace temp. probe
F5 - E0 - Check door latch
F5 - E1 - Check door latch
Replace switch if defective
WHIRLPOOL Polara models 5 digit codes:
F1 F0 - EEPROM communication error
Replace ERC
F1 E1 - EEPROM checksum error
Replace ERC
F1 E2:7 - UL A/D errors
Replace ERC
F1 E4:2 - Model ID error
Reinsert keytail.
F1 E6:0 - Latch signal mismatch error
Replace ERC
F2 E0:4 - Shorted key error
Replace keypad assembly
F2 E1:3 Keytail unplugged
reinsert the keytail
F3 E0:5 Top oven sensor open
Test and replace top probe.
F3 E1:6 Top oven shorted
Test and replace temp probe
F3 E2:9 Bake range over temperature
F3 E3:8 Clean range over temperature
Test and replace temp probe.
F3 E4:10 Bottom oven sensor open
F3 E:15 Bottom oven sensor shorted
F5 E0:14 Door switch errot
Test and eventually replace door lock switch
F5 E1:16 Door latch not operating
Test and eventually replace door latch
F8 E0:17 Refrigeration error
Test the cooling module.
PF Power failure - Does not indicate a fault.
PF occurs when power is disconnected.
WHIRLPOOL
Models SF3, 30'' and 24"
F2 - Oven temperature above specifications
Check 8-pin connector from temp. probe to Electronic Oven Control
F3 - Open oven temperature probe failure
Check wiring, replace oven probe if necessary
F4 - Shorted oven temperature sensor failure
Check wiring harness, replace oven temperature probe if necessary
F5 - Push button stuck or faulty
Check for binding of pushbuttons and control panel glass. If OK, replace touch panel
F6 - Electronic control logic error (timing)
Replace Electronic Range Control (ERC)
F7 - Electronic control logic error (lock motor)
Replace ERC.
F8 - Electronic control logic error
Replace ERC.
on Jan 31, 2010 | Whirlpool RBS305PDS Electric Single Oven
What dose F3 code mean
Amana Appliance Fault Codes - PartSelect
www.partselect.com/JustForFun/Amana-Appliance-Fault-Codes.aspx
Fault codes for Amana ovens, range, stoves including dual convection wall overs and 'big ovens'. ... F3-1 - Oven Temperature Sensor/Circuit Failure - Check wire connections and ... what does it mean when the oven turns off and f3 shows ... My Amanaagds902ww gas range flashes "Door" when attempting to light the oven.
Amana Gas oven Fault Code F3 - Appliance Repair Forum
forum.appliancepartspros.com/oven...ranges-cooktops/143114-amana-g...
Nov 17, 2010 - 2 posts - ‎1 author
Have a Fault Code F3 display on oven when trying to set oven ON. Researched ... Yes, your F3 code would indicate a sensor circuit problem, Jenn-Air Electric Range Code F3
Mar 15, 2011
Range keeps giving error codes E0/F3 and E4/F3 and the ...
Nov 22, 2010
Replaced Sensor Still Getting F3 Error
Sep 20, 2008
F3 Error code on whirlpool Range
Sep 10, 2007
More results from forum.appliancepartspros.com
Amana Fault Codes - Appliance Help O
Dec 25, 2015 | Amana Kitchen Ranges
My built in oven AKZ 110 is showing F 03 and nothing happens when I try to tune it in to work just stays on F 03 no fan no light either
This should help any further assistance please feel free to contact me.
WHIRLPOOL
Range/Stove/Oven Fault Codes Non Y-Line
NOTE: Not valid for Y line. If there is a Y near the end of your model number, do not use this chart.
Failure
Code
Condition Check/Repair 4 Digit Failure Code F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1 Safety flip flop Replace Electronic Range Control/Clock (ERC) F2 - E0 Shorted keypad Replace Electronic Range Control/Clock (ERC) F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace component 2 Digit Failure Code F0 or F1 or F5 Failed transistor Replace Electronic Range Control/Clock (ERC) F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor F3 Open oven temperature sensor or thermal fuse Replace oven temperature sensor or thermal fuse F4 Shorted oven temperature sensor Replace oven temperature sensor F6 Problem in time keeping circuit 1. Reset time and/or cooking operation
2. Check for proper ground F7 Stuck function switch or button on Electronic Range Control (ERC) Replace ERC (Electronic Range Control/Clock) F8 Failure Electronic Range Control (ERC) Replace ERC (Electronic Range Control/Clock) F9 Door lock circuit Check wiring and test operation of door lock switch bkg-faultcodedivider.jpg txt-gototop.jpg WHIRLPOOL
Range/Stove Oven Fault Codes, Common
Failure
Code
Condition Check/Repair Digit Failure Code2 F1 Analog to Digital Failure Disconnect for 30 seconds - if display reappears - replace control board F1 Safety flip flop Replace board F1 Shorted keypad Replace keypad F3 Oven temperature sensor opened Replace oven temperature sensor F2 Oven temperature sensor shorted Replace oven temperature sensor F3 Oven too hot Replace oven temperature sensor F3 Clean temp too hot Replace oven temperature sensor F5 Check door/latch switch Replace switch if defective 4 Digit Failure Code F1 - E1 Safety flip flop Replace board F2 - E0 Shorted keypad Replace keypad F3 - E0 Oven temperature sensor opened Replace oven temperature sensor F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace switch if defective
Jul 16, 2011 | Whirlpool Ovens
Gives codes F-2 &F3 what is the problem jachin2145@comcast.net
Hi, Error Code F2
An F2 error code indicates a failed connection with the keypad. Ensure that the connection between the keypad and control board is tight, and press the "Cancel" key. Wait one minute to see if the error code returns. If it does, the keypad is defective and needs replacing.
Error Code F3
F3 error codes are triggered by problems with the oven temperature sensor. You cannot tell whether the sensor has shorted out or has simply failed to generate a reading if your Whirlpool range only displays two-digit codes. On a Whirlpool range with four-digit error codes, the F3-E0 code represents a failed temperature sensor and F3-E1 represents a short in the sensor. Regardless of which code is displayed, replacing the temperature sensor is the only way to correct the problem.
Hope that helps.
Thanks for using fixya...
Oct 27, 2010 | KitchenAid KESC300 Electric Kitchen Range
I have a whirlpool polara oven that kicks whenever
you can google sears appliance parts and order it from them I found them to be the cheapest for parts .they come out of canada. The error codes are mostly right and you probaly can do it yourself.
Apr 21, 2009 | Ovens
I have a whirlpool gas oven model # SF395LEEBO
Jan 11, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Nov 23, 2008 | Whirlpool GS470LEM Gas Kitchen Range
Kitchen Ranges Logo
179 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
