Question about Dell Inspiron Mini 10 Notebook
Dell Mini 10 with Unmountable Boot Volume...what to do?
shakeelm
  • 224 Answers
SOURCE: HOW CAN I FIX MY COMPUTER? ITS READING UNMOUNTABLE BOOT VOLUME?
You need your Windows XP cd for this fix.
Boot from the Windows XP CD and at the first prompt, press "r" for repair. Press 1 when asked to choose windows installation and then enter the admnistrator password. If you don;t have one, just press "enter" and it should show you "c:\windows>"
At this prompt, type the following
chkdsk /r
THis should take quite sometime but will fix the problem at the end. when you get the c:\windows prompt again, type the word "exit" and your system will reboot and load windows XP normally
Posted on Mar 07, 2009
SOURCE: my dell inspiron mini 10 won't boot.There is just
My dell inspiron mini 10 won't boot.There is just a flash of white light then a flash of amber light when I press the power button. That's it, nothing else. I've removed the battery and unplugged the unit and put it back together and it still does the same thing. HELP!
Posted on Jun 29, 2010
  • 23 Answers
SOURCE: Unmountable boot volume
If your notebook came with a Windows installation disk, you can fix the issue this way:
1. Insert the installation disk into your CD/DVD drive, and boot up your computer.
2. At the Welcome screen, hit the R key on your keyboard. This will launch Recovery mode.
You should now see a DOS prompt on your screen.
3. Type chkdsk /p and hit Enter. This will launch a utility that scans for hard drive errors.
The process may take some time, so be patient and allow it to do its job.
4. After the chkdsk is done, type fixboot and hit Enter to repair any damaged boot files which may have become corrupted. When prompted to choose "Yes" or "No," type Y for "Yes."
5. Type exit and press the Enter key to reboot your computer.
Assuming chkdsk was successful in fixing the disk errors, you should now be able to boot back into Windows.
If you do not have a Windows installation disk, but have access to another computer with a CD/DVD writer, you can download Hiren's Boot CD to help fix your corrupted boot drive.
1) Download the Hiren's disk image, and follow these instructions for burning the boot CD.
2) To ensure your system boots from the CD you've created, follow these instructions on how to set your BIOS to boot from CDROM.
3) Alternately, you can download a free utility that will create a bootable USB flash drive containing all of Hiren's tools. The above link also provides step by step instruction on creating a Hiren's USB drive, as well as how to set your BIOS to boot from it.
4) Boot the problematic pc from either your Hiren's CD or Hiren's USB drive.
5) Once you've successfully booted your system using Hirens, you will see a menu with a variety
of tools and utilities. Navigate to the hard disk tools menu, and run HDD Regenerator.
You'll need even more patience this time -- as HDD Regenerator is a bit more comprehensive in its error scanning than chkdsk. On the bright side, HDD Regenerator has a reputation for repairing disk errors that chkdsk was unable to.
Good luck, and I hope this helps!
Posted on Jan 08, 2011
  • 11800 Answers
SOURCE: getting "unmountable boot volume" error
Windows is totally corrupted - you will have to reinstall it. For that you will need an external CD unit and the recovery disk that came with the Mini. If you don't have it then you can either buy it from HP or borrow a similar XP install disk from a friend and use it and your key.
Posted on Mar 13, 2011
  • 902 Answers
SOURCE: how to remove the unmountable
if you can boot normally i suggest going to filehippo.com or cnet and download a free disk partioner and it will remove the boot volume for you. under run, msconfig, there is a boot option select the boot mount you want that may fix it let me know
Posted on Mar 15, 2011
get a copy of hirens and run HDD regenerator I think you have some bad sectors and a corrupted windows.
Feb 03, 2013 | Dell Latitude D410 Notebook
Hp mini "unmountable boot volume"
I ran across the same problem. I used chk disc utility on a hiren's bootable usb. It found and fixed the errors on the main volume and it rebooted up without a problem after that.
Jan 27, 2012 | HEWLETT-PACKARD HP Mini-Notebook...
My little sisters dell inspiron mini just got the Unmountable boot volume message. I've looked online but most of the options require a cd which is of course not helpful when the mini doesn't have...
The best option is, look around for external cd-rom with usb connection, and reformat the laptop.You need to go into the bios and change the boot order to make your usb cd-rom to first in the boot list. Once the usb cd-rom is plugged into used port, with operation system cd in it, on your laptop..press F2..go into the bios, to the boot order make your usb cd-rom on top boot list,,then save changes to exit the bios. Once again the system reboots..with message PRESS ANY KEY TO BOOT FROM CD ROM.. so just simple steps to follow..its not going to be expensive..good luck
Sep 17, 2011 | Dell Inspiron Mini 10 Notebook
Dell dimension e310 desktop error message unmountable boot volu me
> unmountable
The disk-drive cannot be "mounted", i.e., the motherboard cannot access it
> boot volume
To "boot" a computer is to load a small "loader" program from the disk-drive;
that program "pulls-up-by-the-boot-straps", to read the rest of Windows from the disk-drive.
If the disk-drive has "failed", then you'll get messages like the one that you reported.
Replace the disk-drive.
Jun 12, 2011 | Dell Dimension E310 PC Desktop
How to remove the unmountable boot volume 1525 dell inspirion be cuz i have the blue screen, try go to the safe mode but freeze after it shows all the hard drive data its a stand still
Mar 15, 2011 | Dell Inspiron 1525 Notebook
Getting "unmountable boot volume" error
Mar 13, 2011 | HP Mini 1000 Netbook
Stop: 0x00000ED
0x000000ED Unmountable Boot Volume
Boot to the Windows CD, go to recovery console, run CHKDSK /R see if the issue resolves, if not replace the HDD
May 15, 2010 | Dell Dimension 2400 PC Desktop
Blue Unmountable Error Screen
run MEMTEST, DOWNLOAD MEMTES, BURN IT ON BLANK CD OR DVD, RESTART YOUR LAPTOP WITH THIS CD IN, CHECK THE PROBLEM, MAKE SURE IT PASSES ALL THE STEPS, ALSO TRY TO INSTALL OS FROM ANOTHER CD...MAYBE THERE IS CORRUPTED FILE ON CD OR IT`S SCRATCHED OR SOMETHING, AFTER ALL THIS IF YOU STILL HAVE SAME ISSUE- 2 ND STEP IS REPLACING YOU HDD
Mar 08, 2010 | Dell Inspiron Mini 10 Notebook
chkdsk /r
Mar 07, 2009 | Dell Latitude D600 Notebook
Dell Inspiron Mini 10 Notebook Logo
1,071 people viewed this question
Alun Cox
