Question about Pentair Pool & Spa
My pool pump runs but its not circulating the water. water is not flowing trough the pump.
    Top Expert:
  • Pentair Master
  • 6,465 Answers
Check for leak intake or pump top seal
Posted on May 08, 2016
  • 297 Answers
SOURCE: pool pump intex 51 pumps water but return flow is low
if you cartridge is completly clean then start by disconecting the out tube that goes to the pump housing
sometimes debris gets caught there entering your pump.
a little hair causes other things to back up
once you are satisfird that those 2 things are ready then close it all up and open the bleeder cap on top of the cartridge holder
Now let water in from the suction side
when water starts coming out of the bleeder cap then open the return side
Now turn on the puimp
let it run for 20 seconds and then close your bleeder
Should be working fine after that.
dont forget to leave the bleeder cap alone on the bottom of the canister unless you are draining the water from the canister to clean it. As soon as you are done close it back up
Posted on Jul 15, 2009
  • 128 Answers
SOURCE: High chlorine/cloudy/salt water pool
Purchase a PoolRx unit for your pool. PoolRx.com....No more algae!! Clearer water
Posted on Aug 30, 2009
  • 4 Answers
SOURCE: no water flow though pool pump
Check and see if all valves are turned in the appropriate positions. Sometimes homeowners forget to switch the valves from spa mode to pool mode or vice versa and wonder 'why isn't my pump pushing water?'. Another thing to consider is what type of pump you have. If you have an owners manual, check and see if you have a flooded suction pump or if it's self priming. You may need to dump water into the trap before seeing water flow through. You may also have faulty valves or check valves. Check your filter and make sure all positioning of valves are in proper place. If all else fails...call a pool professional. These small self performing tips are just something to consider to save some money in the long run in lieu of calling someone that may poke your eyes out with a service call and something as trivial as turning a valve. Hope this helps!
Posted on Oct 10, 2008
jharwell668
  • 640 Answers
SOURCE: filter pump running hot and water is not
If your pool filter and pump are running not and not circulating, it sounds like either your pump is not primed properly, you have an impeller jammed/or broken, or you have something clogging the hose to the return line that is causing pressure to build up. Check all three of these and bet you will find your problem.
Posted on Sep 08, 2010
  • 11800 Answers
SOURCE: I have a Waterway SVL56
That means that the connection between the motor and the actual centrifugal pump is broken. This is terminal: replacing the broken part will cost you more than the price for a brand new pump. Just cut your losses and replace it.
Posted on Dec 18, 2010
Our hot tub will only heat when jets are on?
Depending on the design tubs and pools need water to be circulating before heater runs to prevent the heater from burning out. If the circulation pump runs constantly the heater should work any time but a plugged or restricted filter might not let it flow like it needs to.
If the pump only runs in the jet mode then it might be the way it is designed.
Try checking with the manufacturers website for an FAQ section.
Oct 06, 2015 | Pool & Spa
Tip
Simple keys to a beautiful clean pool.
There are 3 keys to a clean swimming pool; filtration, circulation and chemistry. Not having the right amount of any one of these keys will soon cause the pool to be dirty. Filtration requires a filter that allows enough flow and catches any particles in the water. Circulation means enough water is circulating. Chemistry is having the chemicals to the right levels in the pool. The most important component to accomplish these keys is the pump. If the pump doesn't work then the filter doesn't work, the water is not circulating and since chlorine feeders need circulation to deliver enough chlorine to the pool, not having a working pump quickly causes the pool to go green.
on Aug 11, 2011 | Intex Easy Set Pool 15x36
Tip
Simple keys to a clean swimming pool.
There are 3 keys to a clean swimming pool; filtration, circulation and chemistry. Any one of these keys will soon cause the pool to be dirty. Filtration requires a filter that allows enough flow and catches any particles in the water. Circulation means enough water is circulating. Chemistry is having the chemicals to the right levels in the pool. The most important component to accomplish these keys is the pump. If the pump doesn't work then the filter doesn't work, the water is not circulating and since chlorine feeders need circulation to deliver enough chlorine to the pool.
Can the pool overflow from rain?
A pool will over flow in the rain, the pool pump is only for circulating water not for draining overflow , you can go to a local pool supply and buy a pump to hook to a garden hose and drain it partially, be aware that the pump runs on electric power and you want to be careful not to drain the pool below the skimmer level or you will end up replacing the pool pump motor
Dec 11, 2014 | Jandy Pool & Spa
Why the intex pool 2500 pump stops water flow after 3 hours
bad pump motor replace pump its overheating
Jun 23, 2014 | Intex Pool & Spa
Sta Rite Pool Pump
Probably need new pump if the impeller broke.
If impeller broke, then motor will run, but no water circulates
Call pool company.
Motor resources:
http://waterheatertimer.org/Color-codewire.html#motor
Apr 18, 2013 | Sta Rite Pool & Spa
Sticker wore off on the filter. which button backwashes? the pool is about to overflow.
b> VALVE SETTING FUNCTIONS OF VALVE POSITIONS FLOW DIRECTION THROUGH VALVE FILTER PUMP - TOP - THROUGH FILTER - BOTTOM - RETURN For normal filtration and vacuuming pool through filter. BACKWASH b> PUMP - BOTTOM - THROUGH FILTER - TOP - WASTE For reversing flow for cleaning filter. RINSE b> PUMP - TOP - THROUGH FILTER - BOTTOM - WASTE For initial start-up cleaning, plus resetting filter bed after backwashing. WASTE b> PUMP - WASTE For vacuuming directly to waste, lowering pool level/draining pool. CLOSED b> NO CIRCULATION PAST PUMP PORT For shutting off all flow to filter and pool. RECIRCULATE b> PUMP - RETURN For bypassing filter, but circulating pool water. May be plumbed for "off-system" pool water access. Ideal for Jet-Air® fittings. WINTER b> VALVE NOT IN USE
Ifthis answer does not fix your problem, please comment with additional detailsprior to rating the answer. Positive feedback is appreciated once your problemis solved! Thank you.
Aug 28, 2011 | Hayward SAND FILTER, PRO SERIES
Aug 26, 2009 | Pool & Spa
Digital read out....fault high ref pressure.
Verify circulating pump is on and that there are no water flow restrictions to the heat pump. Make sure all necessary valves are open or in the proper positions to allow proper water flow to the heat pump. Verify filter and skimmers are clean. Check for water level in the pool. This condition may also appear if the heat pump has not been operated for an extended period. To clear the condition, cycle the heat pump, on and off, up to 3 times. If this does not correct the problem, call for service.
Jul 25, 2009 | Jandy Ae2500t 115,000 Btu Heat Pump
Pool & Spa Logo
162 people viewed this question
Top Pentair Pool & Spa Experts
Pj Kiley
Pj Kiley
Level 1 Expert
Jay Finke
Jay Finke
Bill Jordan
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
