Question about Teac MC-DX22I Shelf System
TEAC Micro Hi Fi System CD-X10i no sound from speakers Im reemplaced the ic LC 75342 but no sound in any function
5 Suggested Answers
  • 4102 Answers
SOURCE: TEAC DC-D2800 Digital Compact Hi-Fi System
check all wires to speaker are correct also if you take the unit apart you might find that their is 2 or 3 fuses inside it might be that one of these has blown.
Also check no dust has over heated anything as this is often the case when anything electrical has been off for a while.
Let me know how you get on ok
Posted on Dec 10, 2007
SOURCE: teac cd-x10i
  1. press the standby/on switch off
  2. Press and hold the TIME SET button for more than 3 seconds and release it when "12H" or "24H" appears on the display. press the right and left arrows to select. press TIME SET again.
  3. the hour value blinks use the right and left arrows to select the current hour. press TIME SET gain.
  4. The minute value blinks. using the right and left arrows select minutes.
  5. press TIME SET again and the clock starts.
Posted on Jan 04, 2008
  • 4234 Answers
SOURCE: cd on teac hi fi says disc error model dx450i
If the lens is clean, then either the optics have failed or they are significantly out of alignment. The more probable is that the optics are defective. These can be replaced, but the cost is likely to exceed what you wish to spend. At this point check for replacement alternatives.
Dan
Posted on Feb 26, 2009
SOURCE: Problème avec mon MICRO HI-FI TEAC MC-DX2O aidez moi SVP
contacte moi sur hmiyanran@yahoo.fr
Posted on Sep 23, 2011
I need a replacement for the remote for my TEAC Micro hi-fi MC DX220iDAB system. The remote is RC 1104 but I cant find one. Will another work instead?
Possibly. Try locating another Teac remote for another unit very similar to what you have vintage wise. Often they use identical frequencies, may not have all the same buttons, but will work.
Nov 07, 2015 | Teac Audio Players & Recorders
Does the Teac Micro Hi-Fi System CD-X9 support an Ipod nano?
  • Not in the format that IPod supports but it easy enough to convert the IPod songs to the MP3 format that would allow you to burn an MP3 disk that will play on that system.
  • You want to convert it to MPEG-1, Audio Layer 3, 44.1 or 48 kHz fixed bit rate.
  • Here is one of many site you can download the converter from http://www.winmpg.com/ipodto/ipod_mpeg1.html
  • Once you convert the ITune then just burn it to a CD-R or CD-RW disk and the system will play your songs just fine.
  • Hope this helps.
Regards, Tony
Jun 07, 2011 | Car Audio & Video
I ended up with one piece of a Teac model CD-X8 MIcro Hi Fi System. you can see what the whole system looks like at http://www.amazon.com/Remanufactured-CD-X8-Wall-Mountable-System-Subwoofer/dp/B000B65GV6...
Yes - you have the sub-woofer. It is a powered sub-woofer with a built in amplifier for both itself and a pair of small satellite speakers. Frankly, given the low cost of the whole system it may not be worth selling on ebay due to the high shipping costs of such an item, but I imagine you could get $30 for it or so on local craigslist or something, assuming you have no use for a sub-woofer...
May 05, 2011 | Audio Players & Recorders
Have bought ipod nano 5th generation and find the sound is distorted when using my teac cx-225idab docking system. older version of ipod is fine. any clues.I thought it was the ipod and had it exchanged...
Usually, that will happen if the ipod is not compatible w/ the docking station. Try to connect the ipod to a different docking station to check if it will gonna do the same thing...
Oct 26, 2009 | Teac CD-X10i Docking Station for Apple...
I need the code for a Teac CD-X10i mini hi fi system
I can help you program your Logitech Harmony 520 remote for your Teac CD-X10i.
The Logitech Harmony 520 remote control is programmed through the Harmony Setup Software you can download from here.
Once installed, you will simply run the software, and select the devices you would like to control from menus. The software finds the right codes for you and loads them into your remote control.
I hope that helps.
_____________________________________________
Harmony 520 Manual Download
Logitech Harmony Firmware Update
Harmony Win Software Download
Logitech Harmony Safe Mode Fix
Harmony Remote Glow Light Fix
Aug 19, 2009 | Logitech Harmony 520 LCD Remote Control
My teac micro hi-fi system CD-X10i doesnt work
many units have a fuse inside the back cover near where the power cable comes in. be careful to replace it with the same size fuse as the problem that blew the fuse might still be there and could potentially cause a fire.
I have the same unit and i am looking for help because the cd will not run (wont spin the cd), but the door works. also the FM reception sucks.
Larry
Jun 15, 2009 | Teac CD-X10i Docking Station for Apple...
Cd player not working
Hello
Replace the laser pickup unit along with its connection wire to main board. OK.
Apr 08, 2009 | Sony CMT-NE5 CD Shelf System
Teac MC-DX22I Shelf System Logo
199 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
