Question about Hoover U8188-900 Bagless Upright Vacuum
How do you change the belt on this vacuum - Hoover U8188-900 Bagless Upright Vacuum
How do you replace the belt
Fern,
We can help you better if you give us more information. We need the brand of vacuum and the model so that we can help you better.
Apr 30, 2015 | Vacuums
How do we change the belt on our Kirby Vacuum Cleaner
Here is a link to a video explaining how to change the belt on a Kirby vacuum. It is at the bottom of the page
http://www.totalvac.com/videos/kirby-vacuum-cleaners-videos.htm
Jun 02, 2010 | Kirby Heritage II Vacuum
Burning smell
the belt needs changed. its slipping. make sure its not clogged with carpet or string ect. first. if not buy a belt at walmart. in stock...
Sep 08, 2009 | Hoover Tempo Widepath Upright Vacuum -...
Pictures on how to change belt on a wildcat vaccum
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=846664
Generic problem for all Vacuums
Posted by dixieldavids on July 28, 2008
Pictures on how to change belt on a wildcat vacuum
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Not knowing the brand name and model number for the vacuum but I can give you a generic way of changing the belt. You 1st need to remove the bottom plate by screws, levers or clips, then you can get @ the belt, if not then you should remove the top cover and then you can get @ the belt. 1st remove the belt from the brushroll and install the new belt on the pulley side of the brushroll and then use a belt puller or a screwdriver with a bend on the end and then stretch the belt onto the motor pulley and then track the belt in a straight line so that is running in a straight line. Replace the bottom plate and the belt change should be done. Please feel free to contact your local vacuum cleaner dealer in your area.
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 28, 2008 | Vacuums
I can't change belt
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=832643
I can't change belt
Posted by jaw53t on July 25, 2008
I can't change belt
Jul 25, 2008 | Hoover U5753-900 WindTunnel Bagless...
Instructions on changing a belt on an Elite Hoover Vacuum Cleaner Model # v5075-930 Serial # 089500053577
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=825812
Posted by ed_maxwell on Jul 24, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Knowing the brand name and model number for the vacuum but I can give you a generic way of changing the belt. You 1st need to remove the bottom plate by screws, levers or clips, then you can get @ the belt, if not then you should remove the top cover and then you can get @ the belt. 1st remove the belt from the brushroll and install the new belt on the pulley side of the brushroll and then use a belt puller or a screwdriver with a bend on the end and then stretch the belt onto the motor pulley and then track the belt in a straight line so that is running in a straight line. Replace the bottom plate and the belt change should be done. Please feel free to contact your local vacuum cleaner dealer in your area.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Go Ahead. Use Us.
Jul 24, 2008 | Vacuums
How do I change the belt in an upright vacuum?
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=755349
How do I change the
Posted by budnvic on Jul 08, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Well, I can try to tell you a how to for a generic vacuum, but we really need more information as per the brand name and model # in order to tell you the best way to change the belt on your current vacuum. Most vacuums have a removable bottom plate o which will release by screws, clamps or levers and the bottom plate should come off or the top cover will come off. Then the belt should be exposed. Then cut off the belt, lift up on the brushroll side where the pulley is and place the belt on the pulley, then reinstall the brushroll – now use a belt puller or screwdriver and pull / stretch the belt onto the motor pulley – then track the belt by rolling the belt in a straight line – if the install worked then reinstall the top cover and or the bottom plate. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Go Ahead. Use Us.
Jul 08, 2008 | Vacuums
I need to change the belt on the hoover preferred 16.0 how do I open it up?
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=683113
Posted by catch100681 on Jun 18, 2008
I need to change the belt on the Hoover preferred 16.0 how do I open it up?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. There are only 2 ways in order to change the vacuum belt on a Hoover vacuum cleaner. There should be a couple of levers or screws on the bottom of the vacuum. Once you remove the screws and or the bottom plate the belt should be exposed –if not then the top cover of the vacuum will come off and then you can service it from the top of the vacuum. The average flat belt change is every 4 to 6 months for the best cleaning and to store the extra belts in a Ziploc bag in the refrigerator, for some reason if the belt is a geared belt then you would change it once year. If you have a question look inside your owners manual or to contact your local vacuum cleaner dealer in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
8 a.m. - 7 p.m. EST
Go Ahead. Use Us.
Jun 18, 2008 | Vacuums
How to change Vacuum belt
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=553572
Posted by tully054 on Apr 28, 2008
How to change Vacuum belt?
Not knowing the name brand or model # most vacuums belt change from the bottom or by removing the top cover to change the belt for an upright, if you have a bottom plate remove the bottom plate and remove the belt, make sure the brushroll spins free and does not have any thread or hair buildup, once that is done slide the belt onto the brushroll pulley and then stretch the belt onto the motor pulley, once on the 2 pulleys then tract the belt and replace the bottom plate – plug in and turn on to check. If you have the type where the top cover comes off it is then the same procedure listed above for the brushroll and belt. If you have a canister with a powerhead there are 2 or 3 screws on the bottom and the top cover would come off and then follow the procedure just like the upright. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Thanks, Don – The Vac Man
Go Ahead. Use Us.
Apr 28, 2008 | Eureka Mega Boss 4460DT Vacuum
No belt
There are two screws on the top side just behind the Brush housing. Remove these two screws, one on each side, and the top plate can be removed. Then you can follow the directions above.
Hope that helps.
Apr 21, 2008 | Eureka Altima Upright Vacuum Model 2996AVS...
Hoover U8188-900 Bagless Upright Vacuum Logo
94 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
