Question about Panasonic PT-47WX49 47" Rear Projection Television
THE SET TURNS OFF BY ITSELF AFTER FIVE MINUTUES OR SO IS THIS THE LAMP
  • 1,476 Answers
Mercurysabl2,
It could be. If the lamp has not been changed and the set is more than 3 years old I would change the lamp first. Even if it is not the lamp you will eventually need a new one and will have one. I have a tip at
http://www.fixya.com/support/r4168009-change_lamp_in_dlp_projection_tv
which explains the procedure and where to get a good lamp at a good price.
Thanks for using FixYa and for the great rating.
hardrocko
Posted on Apr 05, 2011
HL-S5086W turns itself off
if your tv is dlp. the blub is probably the cause. i have a r5087 and had same problem. replaced blub and set works fine
Nov 16, 2013 | Samsung HL-S5086W 50" HDTV
First of all, I replaced the lamp about 4 months ago, so it is relatively new. The Problem: The TV almost never turns on after the first try. The sound always comes on, the red light stays solid, but...
Some of these sets had a stupid feature. In the customer menu look for something called quick start.
The way you can tell if it is engaged is when you turn the set off the lamp dims but does not go out and the fans stay on all the time, clearly this feature was meant to speed up the turn on time but with it engaged when you turn the set off the lamp is still hot, if you turn it off and try to turn back on it will not function for fifteen or twenty minutes.
If you get the set to come on watch the lamp from the back and then turn the set off, does the lamp just dim down or go off? Lamp fan should run for a maximum of five minutes to cool lamp off, if it does not shut off and lamp only dims down look in the customer menu for quick start and deselect it, it is DEFAULT setting if set was unplugged.
These sets with this feature had problems where the lamp did not last two years.
Before you rate this solution let me know if you find what I described.
SD TECH
Jun 24, 2011 | Toshiba 46HM95 46" HDTV
IPod touch Digital Media Player: My ipod touch has disabled itself for over 21,000,...
plug it into your computer and start itunes and reset the ipod.
May 18, 2010 | Apple iPod touch
Maytag over the range microwave model mmv5165baw purchased in 2007 turn offs the power after 4 minutues of continuous use. I have take out the powercard from plug for 10 minutues in orders to fix power...
Ours runs for 2 minutes and turns off for twenty then "resets". Gee I'm So glad I didn't buy the one that was $70 cheaper(NOT) that one would probably still work! Had this only one year and it's the Last Maytag item we will ever rely on!
Good luck finding a fix, it's a common problem apparently!
Apr 24, 2010 | Maytag MMV5165 Microwave Oven
I Have a Sony KDF-E50A10, It turns on for about 5 minutes then turns off by itself for about 1 to 2 minutes then turns back on by itself, this continues on and on so long as I dont turn the tv off.
thats a very nice set ... it has 3 LCD stages that give it a really nice wide range picture .. your trouble is caused by a worn out projection lamp ...you can change the lamp yourself if you are handy that way.. . the lamp you need is a sony XL2400 .. it goes in a cubby in the back of the set ... listed below is one supplier of that lamp . you might get a little better price if you look around the internet but add in shipping if not included.. the new lamp should last about 6-8,000 hours and cost about $150 on the internet .. much more from a dealer or service shop ..
http://www.onecall.com/productdetails.aspx?id=29755
dont get finger prints on the new lamp glass areas .. make sure the old lamp is not hot before servicing .
Apr 12, 2010 | Sony KDFE50A10 50" HDTV
It keeps overheating.
Is the fan set to run continuously? Go to the menu and see if it's set up to run. Also we have this problem with mounted projectors in our classrooms, we have to keep the room cool, and make sure the projector gets circulation of air.
Hope this helps.
Nov 18, 2009 | Philips ProScreen 4750 Impact Multimedia...
I have a lg rt 52sz, lamp light flashed so i replaced the lamp, now when i turn the tv on the red light turns orange for 8 secnds then tv turns itself off, the lamp is still flashing. Signed unhappy...
make sure the lamp is in correctly and the door is also on good. there is a switch on the lamp door opening that wont let the set turn on if the door is not on.
Apr 24, 2009 | Televison & Video
TV turns off after two minutes. Power light blinks for a few minutes then TV comes back on. Turning the power off after the set shuts itself off will cause the power light to blink five times for a minute...
5 blink indicates - AKB circuit (AKB), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. Also unit be in IK blanking, try turning up screen slightly.
Jan 21, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Tv turns off tne comes back on
Please count red light flash again.
5 times flash shows Lamp Error.
6 times flash shows No "DD 6V " output (G1 board) Its bit technical term.
Need fuhrer help, please Post it here.
Thank you.
Sep 21, 2008 | Sony Grand WEGA KDF-50WE655 50" Rear...
Panasonic PT-47WX49 47" Rear Projection Television Logo
23 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
