Question about Dyson DC17 Animal Bagless Upright Cyclonic Vacuum
Husband sucked up soup. Motor still runs but how do I clean it out?
My QL60 just stopped sucking. The motor and fan run fine.
If the fan is running there has to be suction. If there is none it is because the air in entering via some other port and bypassing the normal intake. Check it out. Check hoses and fittings.
Mar 05, 2016 | Vacuums
Hoover steam vac maxx 77 motor suddenly not running?? its almost new
Should still be in warranty. Read the warranty and get in touch with Hoover.
May 07, 2015 | Hoover Vacuums
Sucked up some debris with Kirby, now the motor is not running right.
1) see the diagram attached.
2) clean it
3) test the belt for broken or crack
4) motor can be faulty by enough pressure in the bearing and winding overheating repair or replace.
Jul 19, 2012 | Vacuums
Dirty water is leaking back out
After shut off all steamvacs will leak dirty water that was sucked up back out. There is always some left in the nozzle. If it is a large amount there is clogged filter that isnt allowing the proper suction. Refer to your manual or go to hoover.com to download one for cleaning directions.
Jan 03, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Water was sucked into Miele Vacuum
the motor is shot.they cant handle water. you are looking at a very expensive repair. miele parts are about the most expensive around. next time look at a panasonic, or riccar. or for a lifetime vac, look at the Metropolitan, made in the USA(around $400)
Oct 14, 2008 | Miele Cat & Dog 326i Bagged Canister...
Dirty water blowing out of hole in top of unit... help!!!
perhaps your husband took the water stop(float) ball out of it . that stops the unit from over filling with water .
Mar 09, 2017 | Shop Vac 401-04-62 Original Wet/Dry Vacuum
My husband threw out my motor bag for my Delonghi Wet and dry M-31. Can I run the vacumm without this protecting the motor?
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=538790
Generic problem for all Vacuums
Delonghi Wet & Dry M-31
Posted by bcpercy on Apr 23, 2008
My husband threw out my motor bag for my Delonghi Wet and dry M-31. Can I run the vacuum without this protecting the motor?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
No…. I would advise NOT running the machine without the filter because you will burn up the motor. You can use a paper bag with a rubber band to slide over the motor to protect it from dust and also if you have a foam type filter – you can put the foam filter on first, then the paper bag then the rubber band, or if you have a cartridge filter you can run it with just the cartridge filter bur would suggest cleaning the cartridge filter after each use – also you can place the paper bag method over the cartridge filter as well or call the Delonghi factory and order the part or they will direct you to a local dealer, Info listed below:
http://www.delonghi.com/Int/USA/menu.htm
Mailing address:
Fox International, LTD., Inc.
23600 Aurora Road
Bedford Heights, Ohio 44146
Customer Service – Sales 1-800-865-6330
Customer Service – Fax # 1-800-445-7991
Email: customerservice@delonghiusa.info
Email – Sales salesdept@fox-international.com
Business Hours
Monday thru Friday 8:30 am to 5:00 pm EST
Thanks, Don – The Vac Man
Go Ahead. Use Us.
Apr 23, 2008 | Vacuums
Doesn't suck
you need too change the belt on the bottom where the brush is take off bottom cover and underneath is the belt if its broke replace it
Dec 22, 2007 | Kenmore 35912 / 35913 Progressive Upright...
Want suck
some form of blockage in hose
Oct 22, 2007 | Bissell 6594 PowerForce Bagless Upright...
Dirt devil mvp not sucking
Could be bad filters, is there suction at the end of the hose. That will tell you which direction to start looking. If no suction at hose end, then filters could be the problem. If you have suction, then the problem is down lower, dirt inlet is clogged, if belt has never been changed, then I am sure it has stretch to the point that under load it doesn't turn like it should. Could even be that although the motor is running, it may be running at a slower speed, in which case it would have to be replaced.
Oct 14, 2007 | Dirt Devil 12 Amp HEPA Filter Vacuum...
Dyson DC17 Animal Bagless Upright Cyclonic Vacuum Logo
134 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
