Question about Hotpoint Kitchen Ranges
Why does my Hotpoint range Model HRCR3800ZWW-1 not bake evenly? Buns at center of pan remain white.
  • ggepp Apr 05, 2011
    Visually at least all portions of the baking element glow an even red when the element is activated. I have checked the convection fan blades for any uneven/warped symptoms. All blades have a trailing edge bent at an exact 90 degree angle. Would reducing the 90 degree angle of the trailing edge help? Is there some way to either increase or decrease the convection fan speed?
    Your further suggestions would be greatly appreciated.
  • Hotpoint Master
  • 3,289 Answers
When you bake in your oven, the element below the rack heats. Broiling causes the element above the rack to heat.
The bake and broil heating elements may be identical or slightly different in shape, size, etc. They often look like this:
It is possible that your bake element is not heating evenly. What you're describing sounds like the mid part of the element is not getting as hot as the sides - leaving the middle of the dish you're cooking undone.
The element is pretty simple and straight forward to replace. Many cost between $10 and $40. Shut off the oven /stove. Unplug or shut off circuit breaker / remove fuses. There is often a couple screws that hold the element to the plug in the oven. They are usually in the holes shown above in the back metal plate. Once the screws are removed, the element can be pulled straight out of the plug.
Insert the new element in the reverse of removal and secure with the screws. Open a window in the kitchen. Restore power to the stove and select BAKE for 300 degrees or so. This will allow the oils and dust that may be coating the element to burn off before cooking with it. A very small amount of light smoke and a slight burning smell may be detected this first time used.
I hope this helps and good luck! Please rate my reply. Thank you.
Posted on Apr 05, 2011
  • Steve Apr 05, 2011
    I wouldn't go bending any fan blades - as that is a recipe to throwing it out of balance and rapid failure. Do the buns in the center stay white on the bottom, top or both?
Recipe for cinnamon buns in a Charlescraft bread maker
DIRECTIONS
  1. Put yeast in bread machine (I use the top rated one at: http://bestbreadmaker-review.com) first on bottom, then flour, sugar and salt.
  2. Then melt butter in microwave. Add beaten egg, milk and water.
  3. Pour onto dry ingredients in bread machine on the dough setting.
  4. When dough is done, put it onto a lightly floured surface.
  5. Knead in enough flour to make it easy to handle.
  6. If it is too elastic, cover and leave 10 minutes.
  7. Use floured rolling pin to roll out dough on floured surface.
  8. Roll out into rectangular shape to approx 1/4-inch thick.
  9. Use filling and spread over entire surface of dough with spoon.
  10. Roll up dough.
  11. Cut into circle with a sharp knife about 1-inch thick; place these in a greased 9x13-inch pan.
  12. Cover with a tea towel and leave in a warm place for approx 30 minutes, until double in size.
  13. Bake in a 350° oven for about 25 minutes, light brown on top.
  14. When done, make glaze and swirl over buns.
Oct 17, 2015 | Kitchen Appliances - Others
I lost my instructions for the recipes and i don't know how to make the cake mixes
I have the recipe for yellow cake from the handbook:
preheat over for 15 minutes and spray pans with cooking spray
1. pour contents of yellow cake mix into bowl and stir to break up any lumps. 2. add 1.5 teaspoons of water and stir to form batter 3. pour batter into baking pan and spread evenly. 4. place pan in baking slot of oven and use pusher end of pan tool to push it into baking chamber. Do not use your hands. 5. bake cake for 12 minutes. 6. when baking time is complete, use pusher end of pan tool to push pan into cooling chamber and let cool for 10 minutes. 7. when cooling time is complete, use holder end of pan tool to remove pan from cooling chamber. Transfer cooled cake to a plate, turning over so bottom faces up.
frosting 1. pour contents of frosting mix into bowl. 2. add 1/2 teaspoon of water and stir until smooth. For thinner frosting, stir in a few extra drops of water. 3. spread frosting over cooled cake.
Sugar Cookies
1. pour contents of sugar cookie mix into bowl and stir to break up any lumps. 2. add 3/4 taespoon of water and stir to form dough. 3. sprinkle your hands with flour and shape dough into 6 small balls. 4. flatten 3 cookie balls and place in baking pan. 5. place pan into oven and use pusher end of pan tool to push into oven. Make sure both metal doors are closed. 6. cook for 10 minutes. 7. when baking time is complete, use pusher end of pan tool to push pan into cooling chamber and let cool for 10 minutes. 8. when cooling time is complete, use holder end of pan tool to remove pan from cooling chamber. 9 repeat steps 4-8 to make remaining 3 cookies.
those were the basic recipes in the handbook. Hope that helps
Jul 25, 2011 | Hasbro "easy Bake Oven and Snack Center"...
I just bought your breadmaker B2200 and i am looking for recipes for a basic white and whole wheat bread.The booklet does not have basic recipes. I am looking forward to baking bread for a long time to...
Basic White
1 1/3 cups lukewarm water
2 tablespoons powdered milk
1 1/2 teaspoons salt
1 tablespoon sugar
2 tablespoons butter or margarine
3 3/4 cups white flour
1 teaspoon yeast
1. Measure ingredients in the order listed into Baking Pan.
2. Insert Baking Pan securely into unit; close lid.
3. Select BASIC setting and 2.0 lb. loaf setting. Choose LIGHT or DARK crust setting.
4. Push Start button. There will be a 15-minute preheat delay before mixing begins.
5. The Complete Signal will sound when bread is done.
6. Using pot holders, remove Baking Pan from the unit and carefully turn bread out of Baking Pan. (Mixing paddle may remain in bread. Remove paddle when load if cool.)
7. Allow to cool before slicing.
Time 3:50 hours
100% Whole Wheat
1 1/2 cups lukewarm water
2 tablespoons powered milk
2 tablespoons honey
2 tablespoons molasses
3 3/4 cups whole wheat flour
1 3/4 teaspoons yeast
2. Insert Baking Pan security into unit; close lid.
3. Select GRAIN setting and 1.5lb. loaf setting.
4. Push Start button. There will be a 25-minute preheat delay before mixing begins.
Time: 4.10 hours
Feb 19, 2011 | Black & Decker Bread Machine
I need to order the oven bake unit elemnet. Part #WB44x5082
Copy and paste the link below for parts ordering.
http://www.repairclinic.com/Appliance-Parts?searchText=wb44x5082&Search=Find%20Parts
Sep 17, 2010 | GE Hotpoint 30" Self-Cleaning Freestanding...
Oven temp
I am experiencing the exact same problem. May try to trouble shoot myself if no one provides assistance on this site. It looks like the problem has to do with either the Sensor, Heating Element or etc..
Jul 03, 2010 | Amana ACF4215 Electric Kitchen Range
How do I change the bake element in hotpoint range?
you have indicated by your model that this is a Gas range?? therefore it will not have a bake element. if you are having problems with the bake not lighting you need to get the igniter checked out. if the igniter is glowing an orange color it will need to be changed it needs to glow white hot in order for it to ignite the gas. hope this helps.
Nov 08, 2009 | Hotpoint RGB745 Gas Kitchen Range
I cannot get the auto self clean cycle to end
It sounds like your oven control module is bad. It conrols all bake, broil, including self clean.
Mar 25, 2009 | GE Hotpoint 30" Self-Cleaning Freestanding...
Hotpoint stove with f3 code.
Replace the oven control module.It controls the bake and broil including clock and timer functions.
Jan 28, 2009 | GE Hotpoint 30" Self-Cleaning Freestanding...
Door lock is on
Hold the lock button for 3-5 seconds or Find the main circuit breaker for your oven. Turn it off for fifteen minutes, then flip it back on. This should allow the door to open. Another thing sometimes, the dial for self clean will hang up, but this should fix it.goodluck hope this helps
Dec 22, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Oven elements
a few issues, did you overcrowd oven cavity,(2 or more trays side by side??) properly preheat oven?? new pan perhaps too large for oven capacity, not allowing air flow around, or too low of a rack position
Feb 23, 2008 | GE Spectra JBP78 Electric Kitchen Range
Kitchen Ranges Logo
115 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal DeAngelo
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
