Question about Kids II Baby Einstein Musical Motion Activity Jumper
THE SEAT PADDING SHRUNK! I NEED A NWE 1 - Kids II Baby Einstein Musical Motion Activity Jumper
Its a 1985 Kawasaki 550 ltd I want to know how to remove the seat
COULD BE 2 12 OR 13 MM BOLTS ONE EITHER SIDE, See this on ebay it shows the layout.
http://www.ebay.co.uk/itm/YAMAHA-KAWASAKI-HONDA-SEAT-SEAT-CUSHION-SEAT-PADDING-SEAT-400-500-550-650-/142330098872?hash=item212388f4b8:g:kBoAAOSw~bFWNcrY
Mar 16, 2015 | kawasaki Motorcycles
Got the wrong instructions on how to fit a BabyStart Sprint Group 0-1 Car Seat. Need instructions on how to fit it.
We have babystart seat it looks like a sprint but isn't. I need instructions to adjust the belts. And to to take off belts so we can take off padding and wash.
Dec 28, 2013 | Baby Gear
I want to washhe padding of my beline ferrari seat and can't get them out,any help??
if its fabric i found that the powder laundry soap,bucket of water and a microfiber wash cloth ....put 1 scoop in about 3 gal water wet cloth squeeze out most water ..leave damp wash repeat......step back and be amazed!!
Aug 16, 2012 | Ferrari Beline Toddler Car Seat
Padding under carpeting gets soaking wet after rain/wash
check your window seals and seals by defrost vent. One is leaking
Jun 19, 2012 | 2006 BMW Z4 Roadster
CAN'T GET THE SEAT OFF
2 bolts at back and sides, 1 for each asscheek. gently push padding toward center of bike to reveal 5mm allen wrench screws.
Feb 18, 2010 | 2002 Honda CBR 954 RR Fireblade
Driver seat frame is cracked. I need to have it welded or ? Palatine, IL. area
probably easier to replace it than to have it fixed, to weld you must remove the seat from car then remove the cloth and padding so it does not burn.
Aug 12, 2009 | Cadillac DeVille Cars & Trucks
Dont kno how to remove seat padding from my pushchair
as awful as it is, you may have to remove the screws inorder to remove the fabric to be cleaned...
Nov 25, 2008 | Baby Gear
Evenflo aura travel system
I hope this information helps:
1) There are harness anchors (metal clips) located on the bottom of the seat. Push these up through the slot to the front of the seat on both sides. To do this, you will need to pull them toward you, and then turn the anchors to fit through the slots.
2) You should be able to remove the bottoms of the straps at this point. Remove them, then pull the tops of the straps through the slots. (You will need to remove the buckles during this process.)
3) Slide the straps through the slot you need for the correct harness height.
4) Replace the buckles in the correct positions.
5) Replace the bottoms of the straps into the harness anchors.
6) Push the harness anchors through the padding and back into the bottom of the seat. Clip into place.
Dec 04, 2007 | Evenflo Aura Traditions Travel System...
Kids II Baby Einstein Musical Motion Activity Jumper Logo
Top Kids II Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Kids II Toy Expert? Answer questions, earn points and help others
