The NW - 891 NEC washing machine does not finish the third cycle or drain?
  • goanna63 Dec 24, 2008
    This has been the latest problem with this washing machine. I'm ready to 'chuck it out' and buy another one.
    Cheers
Our nec washing machine nw 891 leaks water into drum when finished , I think it needs new washers, is this hard to do?
Posted on Jan 17, 2010
I have a nec nw-691, when you put it on spin cycle it brings error message --lid open??? plz help
Yuo might try making sure it is still level but I'd just try using a lower spin speed. How have to use "gentle spin" when I wash towels or my washing machine has errors and stops. If still too damp just use a gentle spin only cycle once more to finish the job.
Apr 16, 2015 | Washing Machines
My NEC NW-81R top loader when it turns on does not make the usual introductory series of beeps and is stuck at a spin cycle but won't start. The only button that works is the power button...any...
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Check this link to replace the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Thank you for using fixya.
Sep 24, 2011 | Washing Machines
I have a nec nw-652 top loader when i start the machine the water fills the tub but at the same time i can hear small amount of water is going down the drain then stops. Once the water in machine is topped...
Hi just read your posting.Now can you please let me know where your drain hose is draining to,Is it into the laundry sink or some place else.Can you see the water coming out of the drain hose?Please reply with additional information and I am sure I can help you rectify this fault.Looking forward to your reply.
Sep 18, 2010 | Washing Machines
NEC washing machine model NW-891 can't get past the rinse cycle it just keeps on rinsing, emptying and rinsing again and again
It is the problem of the board, which can be fixed, by a specialized mechanic. Contact a nearby mechanic with sufficient tools. Sometimes you will have to replace your board which will be expensive. In that case, if your unit is an old one, try to get an exchange.
Jul 05, 2010 | Washing Machines
No response after starting cycle
could be the door interlocking device
Aug 26, 2009 | Washing Machines
My washing machine will not drain. It finished all the cycles but didn't drain after the rinse cycle. It still spun afterwards with water still in it.
Aug 10, 2009 | Whirlpool Washing Machines
Nec nw-891 washing machine will not complete the programmed cycle
Apparent malfunction in the timer circuits. Specific Component replacement not available.
Jun 30, 2009 | Washing Machines
Water runs into tub but does not fill?
be sure the drain hose is not lower than the wash tub this will caust the water to run out, 2nd be sure the drain hose is not pushed to far into the house stand pipe and the there is rome for air to go inbetween the drain hose and stand pipe eather of these will cause the machine to siphon mostly on rince cycle or on the 2nd and third loads you do. last your house drain could be starting to back up fill the washer with water and listen to it drain if you hear a gurggling sound in the house pipe you may need a plumber to cleanthis out for you.
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
395 people viewed this question
Top Washing Machines Experts
