Question about Panasonic Proline AG-DV2500
My DV2500 was repaired a couple of months ago (power switch) Before this repair it married up with my laptop with no problem. Since it came back from being repaired....it hesitates...the video breaks up on screen and often the video display will freeze with capturing. I have tried rebooting...capturing directly from the camera (works great) I could guess the settings might need to be checked, but I don't want to do that because I could make matters worse. Thank you !!! Larry
  • Panasonic Master
  • 19,396 Answers
Hi Larry.
At a glance it does not sound like a setting problem. The unit may still be defective, and the repair hasn't fixed the whole set of problems. Here the manual showing how-to.
Try to preset the time code and do a CLEAR of time code values. Also set it to drop mode. If that does not help, install it and test it on a different computer. If you get the same problem, then the unit is defective.
Regards.
Ginko.
Posted on Apr 06, 2011
Laptop screen goes off and then to sleep mode
go into your control panel and under power saving turn off the sleep mode settings also check power saving sleep mode settings in bios by pressing f2 at boot also check battery options in security settings hope this helps and yes hp techs are just high paid plumbers reading memos from screens so there not usually much help lol
Mar 01, 2013 | HP Pavilion Computers & Internet
I bought this computer a couple of months ago and have used it about 3 times. When I turned it on, there was no power and it was fully charged before I went offline the last time. Now my battery icon...
Then, it should be FULLY covered under WARRANTY, either from the store from where you bought it, or from ACER.
> new battery from COSTCO
It's probably 100% fine; it's your laptop that is the problem.
Exercise the WARRANTY to get the laptop repaired/replaced, at NO COST to you.
Jul 25, 2011 | Computers & Internet
Hp pavillion dv2500 laptop- LEDs glow, fan noise may be heard briefly, display remains black, and computer fails to startup or boot
This sounds like the possibly infamous Nvidia GPU defect. It is caused by heat, over time the solder fractures and separates from the board. Typically the solution is either repair it (temporary fix) or get a new board and hope for the best.
Jun 03, 2011 | HP Pavilion dv6707us 15.4" Widescreen...
I bought a FujiFilm FinePix S1600 one month ago. I used it for couple of times and was working fine. Then suddenly I couldn't switch it on. When I press the power on just flashes and it is not switched on....
The sounds like a systems control board problem, or the systems control has detected an issue with the camera. The only option is to return it to the place of purchase for repair or exchange.
Jan 18, 2011 | Cameras
My panasonic AG DV2500 mini dv VCR hates loading and ejecting.
this loading problem in the AG-DV2500 is caused by a defective cassette housing. list price from Panasonic is about $375.00.
Oct 15, 2009 | Panasonic AG-DV2500 DV/Mini DV VCR
I have a sony Wega KDF 46e2000 and a couple of months a go it started going off and on by itself. And the local repair shop said we needed a new bulb it was going bad. So we bought one a month ago and I...
Three blinks is a lamp cover error. Make sure the lamp cover is back on securely and try again, there is a switch that does not allow the TV to turn on unless the lamp cover is on correctly.
If this does not work, then it means the lamp cover switch was damaged when you were putting the new bulb in and you need to get the switch repaired or get a new switch. They are two of them and cost about $15 each.
Oct 10, 2009 | LG 42LC2D 42 in. LCD HDTV
Hp dv2500 wont turn on
does the laptop plug in tightly to the power socket
if not the pavilion part to get the system power needs replacement
contact a local technician and state the power adapter plug-in on the motherboard needs replaced
these commonly go bad on pavilions
it should cost you less than 100usd to repair
or rma the laptop if you have warranty coverage left on the hp dv2500
good luck
Sep 28, 2009 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Hi i recently bought a 5920 acer laptop ,i used it for couple months ,while using it one day i pluged in the charger and left the room for couple minutes only to dicover it was not on anymore since then...
sounds like power pack. Look for your warranty papers. Or, call ACER in your country and arrange repair (might also be the laptop itself). They can arrange pick up and repair under warranty.
Aug 04, 2009 | Acer Aspire 5920 AS5920 Notebook
HP Pavilion dv2500 - FTB
The troubleshooting you have done seems to be fine. It does not seem to be a problem with the power supply,cord or battery.Did you try a hard reset. If there is a reset button on the bottom of your laptop, you might want to try pressing that with laptop plugged in, not plugged in, with battery, without battery and different combinations thereof.
If this does not work or you don't have a reset button read on.
Before assuming it's the motherboard, there is one other possibility. There is a part called a PCA switch. It is possible this switch has gone bad or a plug might have come loose.
If you are comfortable with doing your own work, you can obtain a repair manual for your laptop online. Within this manual, it should explain what is involved in replacing this part. It is really not too complicated.
It does not sound like a hard drive problem simply because it doesn't seem to be getting power to any other part of the laptop.
You can try these steps.
Regards
Aug 03, 2009 | HP Pavilion dv2610us Notebook
Repair Procedure for HP Pavillion Dv2500
U could be more specific, however you are covered up to 1 year from the day of purchase for any manufacturing error, not accidental. Depending on the country u r in call HP and let them noe of the problem. The'll help u out. If possible I recommend just restoring ur PC to factory setting if it is software related problem.
Jul 11, 2008 | Computers & Internet
Panasonic Proline AG-DV2500 Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
