Question about Dell A215 Computer Speakers
`Have trouble adjusting volume.When i try to adjust the volume tone is very scatchy and breaking up..something seems to be wrong with volume control knob.
    Genius:
  • Dell Master
  • 1,479 Answers
The volume control is dirty inside, many years ago I used to spray a little wd40 or similar into the control whilst rotating the knob to clear out the debris. the other options are to replace the control or buy new speakers. if you don't, worst case is the control will burn up if you do nothing.
Posted on Apr 05, 2011
  • star_guitar1
    star_guitar1 Jun 01, 2012
    wd-40 could work but i would not recommend it for use on anything electrical. you can purchase fast drying aerosol electrical cleaner from almost any hardware/autoparts store or walmart. this works best for me when cleaning the potentiometers ( volume knobs) on guitars to remove the same symptoms
    Sergeant:
    Champion:
  • 244 Answers
1) Turn your speakers off.
2) While blowing a can of compressed air into the switch, twist the knob up and down a bunch of times.
3) Repeat step 2 for roughly 10 minutes, blowing the dust out of the volume controller.
Try it again..
Good luck!!
Adjust Tone on Touch Controls
If there isn't an option to adjust the volume preinstalled than you're probably out of luck. Other than that your best option would be to physically cut the wire to the speaker making the tone, o get a friend with some sodering experience to bend the circuit and add an adjuster to the circuit.
Dec 01, 2013 | Amana Kitchen Ranges
Can't find how to adjust message tone volume
Message tone and volume works together,so if you have your ring tone volume at the loudest level, the alert tone for messages will be at the loudest as well. If you want to adjust the volume follow these steps:
go to settings --> personal --> profiles --> choose any profile that you want to be activated on your phone --> options --> personalized --> ringing volume --> choose from volume 1 to 5 as the loudest --> press ok then click back once --> options --> activate
From there you are good to go.
Thanks for choosing www.fixya.com
Dec 09, 2011 | Nokia E63 Cell Phone
How do i adjust the tone and volume of the board. its a Super L II Plus. Somehow I turned it off with the picture at the top. After turning it back on the only tone I can get is a sharp loud tone. I...
If this is really a SL II Plus there is no adjustment to volume.
The picture on the menu isn't a volume control. It turns on/off the alarm (beep).
The tones are sent by the controller at one volume, different tones indicate what the operator is doing at the tome.
Turning on digitizer = 4 beep tones
Selecting ponts = 1 beep tone
Feb 08, 2011 | GTCO Hard Board Digitizer, 30/36" (SL3036)
My rear speakers are not working now. Ran a test tone. Went to control panel to make sure the speakers were set correctly. I presses the test tone button to reset freq. Pressed tone test and connect...
Here is a guide to the sounds on a computer
the drivers might have been corrupted by something foreign or you might have got a virus run your antivrus program
if your computer came with a motherboard disc the sound drivers could be on it
you might have to uninstall then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have made the correct adjustments there
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can make adjustments there you can also tick in the box place icon in taskbar
hope this helps
Jan 13, 2011 | Dell WL6000 Computer Speakers
How do i turn up volume on hp officejet all in one
Adjust the volume
The HP All-in-One provides three levels for adjusting the Ring and Beep Volume and
the Phone Line Monitor Volume.
The ring volume is the volume of the phone rings. The beep volume is the level of
button press and error beeps. The default Ring and Beep Volume setting is Soft.
The Phone Line Monitor Volume is the volume of dial tones and fax tones. The
default Phone Line Monitor Volume is Medium.
To adjust the Ring and Beep Volume from the control panel
1. Press Setup.
2. Press 4, and then press 4 again. This selects Basic Fax Setup and then selects Ring and Beep Volume.
3. Press to select one of the options: Soft, Loud, or Off.
4. Press OK.
To adjust the Phone Line Monitor Volume from the control panel
1. Press Setup.
2. Press 4, and then press 5. This selects Basic Fax Setup and then selects Phone Line Monitor Volume.
3. Press to select one of the options: Medium, High, or Low.
4. Press OK.
Trust this is helpful. Please vote. :)
Dec 14, 2010 | HP Officejet 4355 All-In-One InkJet...
How do you set the key pad to silent?
Hi to adjust the volume of keypad tone you need to Adjust the volume of the key tones
In Idle mode, press [Up /Down ] to adjust the key tone
volume.
Let me know if this will solve your prob
Nov 27, 2009 | Samsung B2100 Cell Phone
MG100HDFX Amp - crunch setting seems too loud
There are 2 channels, Which means there are 2 sets of knobs ... One for clean and one for crunch. Start out with a low master volume and set up the crunch, Then the clen and switch between the 2 and make adjustments until they match volume wise ... Then turn the master up.
May 12, 2009 | Marshall MG100HDFX 100-Watt Amplifier Head
CAN'T HEAR RING TONES ON MY RAZR V3I CELL PHONE
Your outter speaker is damaged - you got to love ebay!
Contact your seller and request a replacement or refund because it will cost you upto $50 to fix it
Jan 23, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Tone adjustment
If it have no tone control simply add a tone control accross the volume controll and add two capacitors on both end of the tone controll as shown in figure
Jan 16, 2008 | GE 7-5295 Undercounter DC /Radio Combo -...
Dell A215 Computer Speakers Logo
204 people viewed this question
Top Dell Audio Players & Recorders Experts
jairo sanchez
Jax Planet
Jax Planet
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
