Question about Brother CS-6000
Cannot select zipper foot on brother cs-6000i Unlike the other feet (J,R, A & N) that appear on the LCD screen so one can select depending on the foot in use, when attaching zipper foot "I" -which comes with the CS-6000i when purchased- this foot type does not appear to be programmed into the machine, and thus cannot be selected. I tried selecting J (using foot I) with the 01 straight stitch, but the stitches are coming out wrong.
5 Suggested Answers
  • 323 Answers
SOURCE: unable to adjust tension,
Sounds like the bobbin thread is not inside the tension on the bobbin case. This normally happens when the bobbin is upside down. Insert the bobbin and pull on the thread.The bobbin should turn counter clockwise.
sewman7
Posted on Jul 18, 2008
  • 1116 Answers
SOURCE: Brother CS-6000i - the bobbin thread is not coming
Check list:
1 - Flat side of the needle is facing the back of the machine.
2 - Threaded machine with the presser foot up - always.
3 - Bobbin thread is feeding from the spool in the correct direction and through the proper guides.
Lower and raise the threaded needle, holding onto the end of the thread.
If this does not pull the bobbin thread up, the timing may need adjusting.
There is a graphic for doing this as sewusa.com or take it into the dealer for service.
Posted on Mar 10, 2010
  • 1788 Answers
SOURCE: I am using my Brother
What kind of thread are you trying to use? Is it a decent fresh thread? If, it is old, throw it out and buy some fresh quality thread. Usually, cheap thread is the problem.
Posted on Jan 11, 2011
bugoy31
  • 1238 Answers
SOURCE: I am experiencing tension issues.
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Posted on Jun 08, 2011
I need a zipper foot for my Pfaff 1047. Where cn I find one?
Pfaff - Zipper Foot for IDT™ System (1)
www.pfaff.com/en-GB/Accessories/Zipper-Foot-for-IDT-System
The Zipper Foot is the most important zipper tool and will help you stitch the zipper perfectly in place. When attaching any zipper, it is important to sew right next ...
Pfaff - Invisible Zipper Foot
www.pfaff.com/Accessories/Invisible-Zipper-Foot Invisible zippers are the least noticeable of all zippers. As the name implies, the zipper is hidden in a seam, becoming virtually invisible. This makes it a popular ...
Pfaff 1047 Sewing Machine Parts - Sewing Parts Online
www.sewingpartsonline.com > Pfaff Parts Rating: 4.8 - ‎91,711 votes
Results 16 - 30 of 77 - An Online Pfaff Parts Superstore, We also supply 1047 manuals, presser feet and accessories. Fast, free shipping over $75. zipper foot for my Pfaff 1047 Google Search
Feb 27, 2017 | PfaFF Sewing Machines
How to trouble shoot without a manual?
you can download a free manual at //www.generalmanual.com/Home-Sewing-Embroidery-Machines/Brother-CS-6000i-Sewing-Machine.htm
F4 might mean that the bobbin on the top is in the position for rewind, slide bobbin to the right for the error code to go away. Hope this helps, Sandy
May 03, 2014 | Brother CS-6000i CS6000i 60-Stitch...
Why do I keep getting a F4 reading
Make sure the foot control is plugged in correctly. Make sure you have your foot off of the foot control when starting machine.
Got bernina 1015 sport sewing machinewith one foot want to buy zip,buttonhole &overlock foot is ther a special number or do all bernina feet fit al types of bernina machines
This machine uses 'New style' snap on feet. The reason it is 'new' is because old style Bernina feet are the complete foot, whereas new style you just 'snap on' the foot base.
Ebay is the best place to find original Bernina feet at very reasonable prices. I recently purchased a solid steel 'old style' foot from UK for U.S. $28.
When purchasing zipper feet, decide if you want regular zipper foot or invisible zipper foot. Often it is cheaper to order both at the same time, due to S&H fees.
Jul 24, 2011 | Sewing Machines
Have brother sewing machine sc9500. Need invisible zipper foot. Don't know which kind to get.
My invisible zipper foot is a plastic generic one which was describd as being "low shank" and it works fine on three different Elnas I own.
I would have thought your machine was a low shank style too, there is a fair bit of similarity between feet with low shank clip on style. So if your feet clip on and off the shank, then you should be able to clip on another type of foot too.
if you try this link http://www.sewingpartsonline.com/sewing-machine-presser-feet.aspx
then go through to the page for the foot attachment system that looks like yours you might be able to establish which one you need. THere is a brother high shank invisble foot listed, and an alternative part number. I jcan't see a Brother SC9500 machine listed so you might need to do a bit of elimination.
You could also email sewingpartsonline.com and ask them to help you identify the right foot.
Jul 12, 2011 | Brother Sewing Machines
Brother cs 6000i squeaking
By any chance were you using your walking foot when it was squeaking? I had the same issue and realized it didn't squeak unless I was using the walking foot, it was actually the walking foot that was squeaking :D I can live with that!
Sep 02, 2009 | Brother CS-6000
On the Brother XL3750, how many presser feet does it come with? and what are their functions?
Go to www.brother.com and enter your machine type. Look for online pdf file for that machine. It should be able to tell you what it comes with, what they are and what they are used for. Most machines come with a button hole maker, a zipper foot as well as a dozen other types of feet. Mine came with a free hand embroider foot, zipper, button maker, and two others.
Try online manuals, since you can read them, store them on your hard drive for easy referral later.
Jan 08, 2009 | Brother XL3750 Mechanical Sewing Machine
Brother CS-6000 Logo
55 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
