Question about Sanyo DP46849 46 in. HDTV
On my 46inch sanyo model dp46849 will not turn on and it has power going to it
4 Suggested Answers
  • 8 Answers
SOURCE: I purchased a sanyo 46inch hdtv june 5. 3 times
needs main pcb call sanyo they most likely replace set no parts
Posted on Jun 08, 2009
caroldon
  • 17130 Answers
SOURCE: I have a 46" Sanyo
In most cases the standby light might blink with different rapidity to indicate a fault relevant to the processor. It is possible that most of these indicate that there are errors in the processing section . Since there is a possible short or leak in the circuit the output driver section can take in huge current to trip the SMPS or from advice from the micro processor. Remove the power plugs and make sure that high voltage sections are discharged of the potential stored in capacitors. Look for visible signs of leak or of busted capacitors. Look for bulged capacitors or damaged components- burnt or busted. Use a multimeter to check the continuity or shorting in components, if so detach from circuit and test . If the voltage builds up and the set power ON and then shuts up then the suspected section must be checked in detail.
The processor must have the +5 voltage to the function properly , the +B and secondary voltages also must be checked to infer the fault. Trace with caution and in running through the signal path , circuit trail.
Posted on Jul 08, 2011
ekcnoel
  • 998 Answers
SOURCE: sanyo dp46849 when first turned
The problem of your unit is the CCFL - cold cathode fluorescent light. if the both ends of the ccfl is already have a dark spot it must be replace or sometimes the holder of the ccfl is only loosed. Or try to consult a technician for sure, to do some actual test to your unit if you are not familiar in electronic parts and to lessen the stress. Good day and best regards.
Posted on Aug 09, 2011
Sanyo dp46849 no power
It is probably the power supply in you tv
it is close to the power inlet of the tv
look for capacitor s that are bold on top that means they are blown out
on one side there is a line with a - on it make pictures of it so you know with way to putt a new one back in it must be the same value microforat voltage schould be the same or higher
Jan 04, 2015 | Sanyo DP46849 46 in. HDTV
Computer chip
There is no "color chip" on Sanyo DP46849.
Perhaps it will be better if you explain what the problem is and let us try and diagnose the source of the problem.
Here is a link of the different repairs and parts we offer for DP46849:
http://www.coppelltvrepair.com/search?q=dp46849
Sep 05, 2013 | Sanyo Televison & Video
How do I bring up my menu on Sanyo DP46849 without a remote?
The button below the power button is the menu button.
Aug 17, 2013 | Sanyo DP46849 46 in. HDTV
Need replacement power cord for sanyo dp46849
Any electronics parts store such as Radio Shack should carry replacments
Feb 06, 2013 | Sanyo DP46849 46 in. HDTV
Sanyo DP46849
The power supply is failing
Sep 18, 2012 | Sanyo Televison & Video
I have a sanyo model dp46849. The sound just quit. What is the cause of this?
If sound output has gone out all of a sudden, its speakers should be suspected. The fault with audio output section also be the cause. Your TV needs a through checkup.
Apr 25, 2012 | Sanyo DP46849 46 in. HDTV
My sanyo dp46849 after tv is on for a while the picture goes out and sound stays on after about 20 or 30 min or so picture comes back! wtf? help me
It seems tv got problem in power supply board that need to be replaced and available in shopjimmy.com
Let me know if there is further question.
Thanks.
May 06, 2011 | Sanyo DP46849 46 in. HDTV
My sanyo dp46849 screen is discolored with red and black, any wisdom is appreciated
common issue with this model. if im correct not only is it red but it also has a ghosting affect this is caused by bad controller boards connected to the tv screen itself it is not any easy fix the only real option is to replace the whole panel which can cost between 200 to 1500.
Feb 22, 2011 | Sanyo DP46849 46 in. HDTV
Sanyo DP46849 composite video input malfunction
Sounds like a damaged port or related circuitry. You could take it to a repair shop if you really want to use that port, wouldn't cost too much
Feb 06, 2010 | Sanyo DP46849 46 in. HDTV
Sanyo DP46849 46 in. HDTV Logo
267 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
