Question about Hoover Washing Machines
The belt will not stay on the wheel that turns the drum washing machine hoover hnl7146
    Brigadier General:
  • 6,277 Answers
It's always the best idea to purchase a replacement belt as the old one is bound to come off for the same reason as it did the first time ;-0)
Belts are not expensive- sorry I do not know how much yours would cost- and are easy to be changed by a competent person:-
REMOVE POWER FROM THE MACHINE AND REMOVE THE BACK.
The motor support bolts should be loosened and the old belt removed. Often putting the new belt on is a bit of a struggle, even with the motor 'loose', because it is new and smaller!
Once on it should be tensioned by pulling the motor against the belt firmly- but not over tight- and the motor support bolts tightened.
ON NO ACCOUNT SHOULD ANY FORM OF LEVERAGE BE USED TO TENSION THE BELT. THAT COULD LEAD TO DAMAGE TO THE BELT, MOTOR AND BEARINGS- EXPENSIVE!
Hope this is your problem solved.
Good luck,
John C
Posted on Apr 05, 2011
My hoover Ophs712 7kg washing machine drum has seized motor is turning how do i reset or repair
if motor is turning its not seized? check bad motor coupler or worn broken belt, door switch
Mar 06, 2015 | Hoover Washing Machines
I HAVE JUST FITTED MY NEW DRIVE BELT ON MY HOOVER WASHING MACHINE HSE130M AND IT KEEPS ON SLIPPING OFF?
This is potentially very bad news I'm afraid. There are very few reasons for a belt to come off. Presuming that you are convinced it is the right size (and it probably is) Then there is a fair chance that the belt is coming off because the main bearing on the drum is worn out, allowing the inner drum (and therefore the large drive wheel on the back) to "flop about".
To test your bearings, open the door of the machine and by putting a little lifting pressure on the top of the inner drum, attempt to rock the stainless steel inner drup up and down.
The outer drum is mounted on springs and shock absorbers, so it will rock about (and it should do this) but the inner drum should not move up and down in relation to the outer drum. If the bearings are bad enough to allow the belt to dislodge then symptoms will typically include:
A clonking noise as you lift and releas the inner drum (this is the inner drum rattling on its bearings
You will have become aware of the spine cycle becoming far noisier recently and pissibly even a grinding crunching noise when the machine spins
The drum may feel like something is crunching or stopping you turning it when you spin it by hand with the door open
A leak from under the machine, which you will probably be able to trace to the back of the machine, coming from the centre of the drum. This is the result of the failing bearing allowing water to escape through the seal ar the rear
Jul 04, 2011 | Hoover HF130E Front Load Washer
Washine machine fills but drum does not turn
hoover hd 1400 aaa motor turns and so does drive belt but the drum doesn't? what is the problem?
Sep 25, 2009 | Hoover Washing Machines
Hoover Washer/Dryer WM120 : Dryer function - drum not turning
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
treru
Jan 25, 2009 | Hoover H120M Front Load Washer / Dryer
Cant get new drive belt to fit washing machine. right one but cant get it to stretch enough to fit from drum wheel to motor
this is a common problem as nowadays stretchy belts are used in order to avoid motor adjustment.
fitting requires some brute force. the way i do it is to put the belt on the motor pulley then start it as much as i can on the drum pulley. turn the drum pulley keeping force sideways to push the belt on and as you turn, the belt will go on
Oct 21, 2008 | Hoover Washing Machines
Washing Machines Logo
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Johnny Ramirez
Johnny Ramirez
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
