Question about Kenmore HE2 Plus Front Load Washer
My washer is putting the code F24 on the display, I have checked the water and it is hot but I'm not sure if I have a heating unit on this washer, I thought the water just came from my hot water connection. I have checked the drain filter and it is clean now, there doesn't seem to be any water getting into the machine and I can't find the problem, and I can't reset it either, it says to do a disgnostic test, did that, it said to do starting diagnostic test and bypassing the service history mode, i did that, and it goes through the rinse cycle only the short one, but no water. Please Help!!
  • john_cross Apr 05, 2011
    Sorry, info only ;-0(
    All washers have heaters just in case the supplied water is not hot enough or if the washer is plumbed in as cold water supply only- by a 'y' piece. Also rinses are normally by cold water.
    If the taps are fully on, the hoses not kinked or squashed at the back, the machine possibly has a malfunctioning water inlet valve. I've posted this as clarification rather than solution so it will stay live for someone else to assist!
    Good luck,
    John C
  • binkychelle Apr 06, 2011
    Ok I found the problem, the two little black wires (connected by a little white plastic thing) were disconnected, the plug is located on the back of the tub kind of, you have to use a mirror to see it. Take off the bottom front panel of the washer, look for the two black wires they would be hanging down with their connector. I guess they come disconnected through the washer shaking and what not, however I am very happy I found the place where they plug in, otherwise it would have been 150.00 about to have a tech come and fix it!!
    Brigadier General:
  • 6,277 Answers
Hi from retired Englishman in SW France again,
You mentioned your machine 'shaking'. Here's how to ensure it doesn't in the future!
It is necessary to ensure absolutely that the machine has all 4 feet very firmly on the floor, and I mean firmly ;-0)
Doesn't matter whether it is empty or not but switch it off then-
very firmly push one front corner diagonally into the centre of the machine and see if the machine moves or rocks AT ALL, even the slightest. If it does you will need the open-ended spanner which came with the (new) machine........which of course went missing a long time ago?!! An adjustable spanner will suffice.
Adjust the foot under that corner downwards until it is very firmly- almost pushing- against the floor but not so far that the corner lifts up!
If this corner did not rock do the same to the other.
Once you cannot rock the machine the slightest little bit, screw the locking nuts up tight to the underside of the machine so that they will not move. Ideally the rear feet should also be locked.
Good luck,
John C
Posted on Apr 07, 2011
Error F24
This advice is for Whirlpool Duet and Kenmore Elite model FRONT LOADERS displaying the "F24" Error Code. Some of the error codes on these model washers can be erroneous, however. The first step in troubleshooting any error code is to simply unplug the washer for AT LEAST 30 minutes in an attempt to reset the Central Control Unit (CCU). This is the main "brain" of the washing machine. If the error code reappears following a CCU reset, then you have a genuine problem.
"F24" is an indication of a water temperature sensor (NTC) error, or Heating Circuit failure. Check the Water Temperature Sensor and check connections to the Water Temperature Sensor.
To access, you will have to UNPLUG your washer and remove the lower access panel under the door. The panel comes off by removing the screws under the bottom edge. HINT: If you place a 2 x 4 under the front feet of the washer, it will make access to the screws much easier. If the panel sticks, a tap on the sides will knock it free. The panel will drop down then come off. The sensor (NTC) is located at the base of the wash tub in the front on the heating element. This will be a small square shaped plug between the heating element terminals. Make sure this plug is secure and not loose or unplugged. It is common for the connector plug to come loose due to vibration. If the plug is intact, check the contacts for corrosion. If everything appears as it should, then unplug the wire harness and take a resistance check. Readings will be as follows:
Temperature Meter Reading
32°F (0°C) 35.9 K ohms
86°F (30°C) 9.7 K ohms
104°F (40°C) 6.6 K ohms
122°F (50°C) 4.6 K ohms
140°F (60°C) 3.2 K ohms
158°F (70°C) 2.3 K ohms
203°F (95°C) 1 K ohms
Roughly...around 9K ohms at room temperature if I'm reading the chart correctly. Take readings as listed and also double check the connector to make sure it is not oxidized. Try cleaning the plug and reconnecting to see if the error code goes away. If not, you will probably have to replace the sensor. If the sensor checks good, take a reading across the heating element terminals. It should indicate about 15 ohms.
Lastly, remove the washer top panel by removing the three screws holding the panel in place in the rear. Once the screws are removed, slide the panel back then off. Locate the Central Control Unit (CCU) directly behind the wash tub. Take a resistance check at the Heating Element Solenoid by removing connector 9 from the CCU (this is the second connector from the RIGHT as facing from the front). A reading across test points 1 & 2 should also read 15 ohms.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.%$#@
Jul 03, 2010 | Kenmore HE2 Plus Front Load Washer
We keep getting an f24 error. It won't spin out
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.****
May 31, 2010 | Whirlpool Duet GHW9150P Front Load Washer
How can I repair code F24 on whirlpool duet sport washer
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.&&&&
May 20, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I am getting error codes F24 and F34. The power
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.)(*&
Jan 18, 2010 | Kenmore Elite 45986 Front Load Washer
DEUT WHIRLPOOL -problem during wash cycle
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.%%%%
Jan 06, 2010 | Whirlpool Duet GHW9150P Front Load Washer
What does F24 mean? The machine stops and F24 flashed I have to stop and start rinse and spin cycle.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.&*()
Dec 23, 2009 | Kenmore HE2 Plus Front Load Washer
Fault code F24
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!
Mar 25, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F24 code
This advice is for Whirlpool Duet and Kenmore Elite model FRONT LOADERS displaying the “F24” Error Code. Some of the error codes on these model washers can be erroneous, however. The first step in troubleshooting any error code is to simply unplug the washer for AT LEAST 30 minutes in an attempt to reset the Central Control Unit (CCU). This is the main "brain" of the washing machine. If the error code reappears following a CCU reset, then you have a genuine problem.
Feb 24, 2009 | Kenmore 46462 Front Load Washer
Error code f24
F24 indicates a water temperature sensor error. If during the wash cycle in the water-heating step, the water temperature sensor (NTC) value is out of range the F24 error code will display.
Possible causes:
  • Too cold of water or hot water is turned off
  • Temperature sensor failure or loose connection
  • Control board failure
Dec 18, 2008 | Kenmore Washing Machines
Fault F24 on kenmore front load washer
F24 error code a water temperature sensor error or enought hot water to the washer.
check to see you have both valves are turned on. Also, the water inlet valve on the washer has a screen and it is known to get clogged and restrict water flow. Turn off the hot water valve. Pull the hot water hose off where it attaches to the back of the washer.
Even if you are getting good hot water flow, inadequate water temperature can cause an F24 error code. Check the temperature setting on your hot water heater. It should be set at 120 F. You should reach this hot water temperature at your washer within about 1 minute.
If you are getting a good hot water flow, you may one of the following failures:
1 loose or dirty connection at the temperature sensor or control board.
2 The temperature sensor could be out of range. Bad or shorted sensor
3 Control board failure.
The temperature sensor should have a resistance reading of 6.6k ohms at 104 degrees F and should drop in Ohms as temperature rises,
The temperature sensor is located at the back lower section of the tub with 2 small black wires. It would require a ohm meter to measure the resistance of the sensor. .
Apr 20, 2008 | Washing Machines
Kenmore HE2 Plus Front Load Washer Logo
164 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
