Question about Dishwashers
Close door and beeping noise starts and green light stays on . doesnt perform a cycle.it wont allow you to reprogramme.
  • 2 more comments
  • bernardsmth9 Apr 05, 2011
    there aren't any buttons on the sixth sense integrated. so it isn't possible to press them !
    whirlpool sixth sense adg7960
    how can i change the control board?
    my dishwasher is integrated . will this job be the same .where will i get a new control board?
  • Dishwashers Master
  • 1,902 Answers
Hello & Welcome to FixYa
Flashing light is reset by pressing two buttons in sequence 3-4 times, to reset your dishwasher press these buttons in sequence:
High temp wash-heated dry-high temp wash-heated dry
Please get back to me if you have any other questions.
Kevin
Posted on Apr 05, 2011
  • 2 more comments
  • Kevin White
    Kevin White Apr 05, 2011
    Please tell me the make and model# of your Dishwasher
  • Kevin White
    If you have already cleaned the drain filter located inside the bottom access panel and the problem is still there so now the control board needs replacement
  • Kevin White
    you can follow the instructions given in this video:
  • Kevin White
    Yes....
Model NFW7200TW Washer wont fill with water
Are you sure you have both hot and cold water connected? Try turning the water valve on, if you don't have hot water make sure you choose cold cycle. That's the first place I'd start.
Dec 02, 2015 | Amana Washing Machines
Control lock light is on , toke door lock off once cleaned it put it back on and it worked now its on aagain and washer wont work
1 close washer door and dispenser drawer
2 select Clean washer cycle
3 Press start/ pause
The basket will rotate,then the door will unlock,lock again,then the cycle will continue
Water should come in and run a short sensing cycle about 3 minutes
4 This will determine item in the washer
a if no items are detected it will move to step 5
b if item are detected wash any control lock light will stay on door will unlock open and remove any garments
If b pessnpower to cancel f code then repeat 1,2,3
Once cycle begins allow it to finish
5 after cycle is complete leave the door a jar to allow for venting and drying of interior
Only use HE high efficiency detergent
Jul 05, 2015 | Whirlpool GHW9100L Front Load Washer
The light in my freezer stays on when the door is closed.
I am curious how you know it is on unless you get inside. Some have magnet switches that will not cycle until the gasket seals.
Jan 11, 2015 | Viking Freezers
FL code on Washer
FL is a door lock code. open the soap dispenser door, and find the thin flourescent green, or bright red color nylon cord located in the front left or right areas of the dispenser area, this will allow you to manually release the door lock. Empty the washer, close the door and perform another drain and spin cycle, if the door lock still fails, you may need to have the door lock assy replaced, especially if the door lock is making a click, or buzzing soung like it wants to operate, if it's completely quiet than you may need the board replaced...Pleazer Appliance...
Aug 15, 2014 | Maytag Neptune MAH5500B Front Load Washer
Lights come on and it beeps when u select cycle but it wont run
Do you hear the water going in? If not, the float switch is probably stuck . From the inside you can see the cover usually on the front left corner on the floor of the dishwasher by the bottom rack. Remove the screw and float cover. The you see a small piece sticking up, gently push on it many time to try to free and clean it. This is actually pushing the float switch. Clean the plastic covers of soap gunk. Reassemble and try. The switch can be accessed from underneath if you want to replace it. Also a clogged or defective water valve will not allow water to enter.
Mar 24, 2014 | GE Dishwashers
Washer wont complete cycle
Sound like the control board is bad
Jul 25, 2012 | AEG Lavamat 72640 Front Load Washer
Cda cw 494 - dishwasher makes beeping noises and stops halfway through cycle . will restart if turned off but will not complete . doesnt seem to be filling properly .now and then does complete cycle and...
Greetings,
usually, open and close door..then start counting the flashes. these will give you your fault code. The code then tells us where to go from there. off hand, i would say you have a heater problem.. Either, the water is not getting hot enough because of a faulty heater, or faulty thermostat. The button above the green light that flashes try and hold that down for a minute to reset....let me know about the flashes
Nov 16, 2010 | Whirlpool Dishwashers
My ps3 doesnt work
if it wont load your icons and freezes before your xmb, put it into safemode and try restoring the filing system. to get it into safemode...
hold down the power button while the console is in standby. the light will go from red to green.it will beep once flash green beep again, and then beep a third time. after the third beep the light will turn red.
once the light is red, take your finger off the power button and place it back on the power button. the light will go from red to green, beep once flash and then beep twice quickly. after it does the double beep, take your finge roff. the light will stay green and you'll get a screen asking you to connect the controller.
after connecting the controller, try option 3, or whichever option is restore filing system. this can possibly correct media loading and will 95% of the time fix the console when it freezes before loading up your icons(the xmb)
Mar 19, 2009 | Sony Playstation 3 (PS3) Console
Interior Lights and Door Ajar light stay w/beeping noise.
Try spraying WD-40 into the door latching mechanism (door side). I learned this fix after two battery replacements, but have only had to spray twice in the more than seven years of ownership
Jan 20, 2009 | 1998 Ford Expedition
Lid lock stays on and constant beep on excellence washing machine
i have the problem when i turn power on 2 green wash cycle lights plus the red lid lock stay on with constant beeping every second then when i push the start button the 2 green lights go out and the red lid lock light stays on but no beeps please help
May 26, 2008 | Fisher and Paykel IWL12 Top Load Washer
Dishwashers Logo
97 people viewed this question
Top Dishwashers Experts
Owen Barnes
