Question about Air Purifiers
How do you install the remote transmitter in a Hampton Bay Ansley ceiling fan?
    Brigadier General:
  • 4,736 Answers
Jaggirl, most Hampton Bay, Remote Controlled Ceiling Fans have the receiver already installed inside the fan's cowl. The Transmitter is the Hand Held Remote. Both require batteries.
Posted on Apr 05, 2011
Motor runs but wheels don't turn
If you have used it for a long time then minerals in the water may have built up somewhere and now needs to be removed wither by cycling a cleaner of some sort or physically scrubbing the moving parts yourself.  The first ting to try is unplug the machine, remove all the filters, and try cleaning with vinegar. Smells bad I know but following up by cleaning with a regular detergent should remove the smell. Detergent alone will not break up the calcium, the acid in the vinegar does that. Next we need to find out what gears may have slipped or if there is a belt out of place. If everything mechanical is in working order then the cam from the motor to the rest of the unit may be shucked in which case it would depend on where it is broken to determine the best repair. Please, if you could as some problems like this are not always simple, take a look at your particular unit and provide me with some further description of what is going on.
May 27, 2008 | Venta - Airwasher LW44 Air Purifier
I have a tower fan 42" that produces no air. I have checked the fuse (ok), I have connected to black wires that were way from their harness....still no air
apparently nobody gives a hoot will throw the piece of **** in garbage and never buy a product from this company ever again.
its not a profanity it is a bodily function
Nov 01, 2014 | Bionaire BT440RCU Remote Control Tower...
Indoor unit fan blows, then stops etc. every 1-2 minutes
At least it is cooling properly. U might just want to call Mitsubishi and ask them if it is operating normally based on your observations.
Apr 30, 2017 | Mitsubishi 18000 Btu Mr.slim Ductless Mini...
Where is the power steering pump for 1997 Dodge Stratus
I-4 cyl is in the right bront of the engine bay
V-6 cyl in buried on the right rear of the engine bay.
May 22, 2014 | Mopar Performance Dodge stratus pump....
I have a 42" wind
the first thing to check is that the remote control is working and the control panel of the fan itself are working probably and i think they did but you have to check first
this fan oscillating control button is not a mechanical connection like the regular fan so if you are not using it wrong(and i think you don`t ) an if all the buttons are working -except the oscillating function - (and i think they are ) turn that thing back and test it at the shop
May 22, 2011 | Lasko 42" Wind Curve Fresh Air Ionizer Fan...
Altura has a reciever icant seem to install does not fit
Not sure if this is the same model as your but, most of these fans install the same. As in figure 9 in this manual you see where the receiver is in stalled. there should be enough room in the wiring box in the ceiling to keep the receiver and still cover it with the ceiling plate. hope this helps. If you need more information please let me know and I will try to help further.
http://www.homedepot.com/catalog/pdfimages/11/118abd68-b275-4304-b7ab-98f9011dd811.pdf
Dec 29, 2010 | Air Purifiers
Unit blinks as if it wants to start put will not start fan starts moving and than stops repeately. Front panel buttons do not work some of remote buttons do
I would check the wiring connections to the fan and to the display board. Make sure they are seated properly. If that does not fix it, then call your dealer or the company and see what options you have. The company number is 800 989 2299.
Aug 31, 2010 | Ecoquest Fresh Air Air Purifier
My Lasko 42" Wind Curve fan when I plug it don't power up. Pluged at diferents outlets, same results Thank you
Check out the cord, (frayed or broken) usually right where it enters the unit, and the switch.... if these check out then the motor has gone bad...
heatman101
Aug 18, 2010 | Lasko 42" Wind Curve Fresh Air Ionizer Fan...
Air Purifiers Logo
176 people viewed this question
Top Air Purifiers Experts
Are you an Air Purifier Expert? Answer questions, earn points and help others
