Question about Poulan Pro 16-Inch 38 cc Anti-Vibration Chainsaw #PP3516AVX
The chain will not move. if it is off the thing it goes around is bound up tight.
  • Poulan Master
  • 2,239 Answers
If the chain will not rotate around the bar it is possible the chain brake has activated, grab the hand guard and pull it fully back to the top handle, it should click as the brake locks.
Posted on Apr 05, 2011
Testimonial: "I am so happy for an EASY solution!! Will go home and check the brake to see if it is engaged!! You men are great!!!! S"
My stihl ms-180-c chain saw will not keep chain tight. you tighten chain rev. engine chain will just about come okk -tighten chain rev. engine same thing.
you have to use the tension screw to move the cutter bar to tighten the chain then you do up the bar mounting nut to keep it tight
May 12, 2017 | Stihl Garden
How do you adjust chain
Flip bicycle up-side-down so it sits on the seat and handlebars. Loosen the 2 nuts that hold the rear wheel on. Sitting behind the bike on the ground, so that you can align the wheel to a straight position, pull the wheel back so that the chain is snug. You don't need to pull hard, just hold the wheel in place and straight. Using the other hand, slowly tighten the axle nuts back down until the wheel is held in place. Once the nuts are tight enough to securely hold the wheel, tighten the nuts. Sometimes this method will make the chain too tight. If this happens, repeat the process as above, only this time when you go to tighten the nuts back down, squeeze the chain slightly to create a bit of slack. Ideally, the chain will be tight enough not to skip or slip, and at the same time, loose enough not to make noise, bind up, or do any damage.
There are "chain tensioners" available that hook around the rear dropouts of the frame and also around the axle, allowing you to tighten the chain to exact specs. simply by tightening or loosening adjuster screws. They will also help to keep things from loosening up over time. These make things much easier and I highly suggest looking into them.
Use any of a variety of oils and lubes available, but try to avoid WD-40 for chain lube. It will stop a squeak for now and make things seem to move smoother, but in the long run, WD-40 will attract dirt and debris to the constantly moving parts of your chain and can shorten the life of a chain considerably. Hope this helps.
~Ed
Jul 13, 2014 | Huffy 26 in. Cranbrook Cruiser Bike
How adjust chain ECW 1841
Most saws I have used have a tensioning screw that engages the bar. Loosen the nuts holding the bar just enough so you can move the bar up and down. Turn the screw to snug up the chain. With gloves on you should be able to move the chain around the bar. If it does not move it is too tight
Mar 27, 2014 | Garden
How to replace ryobi electric chain
There should be a tensioning screw that needs to be backed off to allow the bar to be moved towards the back of the saw. I am not sure on your saw if the screw is on the cover or on the saw side of the bar. So start by taking off the cover over the bar then you will see the tension adjusing screw. On the screw will be a peg that fits into a hole in the bar. Turn the screw so the peg moves towards the sprocket. When the bar is far enough back you can place the chain over the bar and sprocket. Then with the peg in the bar put the cover back on and turn the screw to move the bar forward till the chain is snug. If it is too tight the chain will not move around the bar. With gloves on you should be able to move the chain around the bar. If you can not it is too tight. Back off the adjusting screw till you can then fully tighten the cover screws.
Nov 26, 2013 | Garden
Loosen the nuts on the cover so you can just move the bar up and down. Now find the tension screw. It will be on one side or the other of the bar. Take the slack out of the chain. If you turn the screw too far the chain will not move. Also hold the bar tip up while adjusting. With gloves on move the chain around the bar. If you can not move it the chain is too tight
Apr 20, 2013 | Craftsman Garden
Chain fell off and I can't get it back on.
Turn the saw off. Look for several nuts on the right side of the saw that hold the cover on and the blade to the saw. Loosen these nuts, and before taking the cover off, loosen the chain adjuster by turning it (usually a screw head on the same side, or on the front of the saw as you look down the blade towards the saw.) Loosening the chain adjuster moves a pin that goes into the bar (the part the chain rides around when operating) to push it away from the saw to tighten the chain when you are tightening it. Take the cover off, and put the chain around the sprocket at the back like a bicycle chain, and then while holding the bar (sometimes a partner helps) parallel to the saw and outward away from the front of the saw, align the bottom parts of the chain inside the bar guide slot all around the bar, holding just enough tension that it doesn't fall off the sprocket or get misaligned in the bar guide. Try moving the chain a little bit to make sure it is not binding on anything. If it doesn't move at all, make sure the chain brake is not on. Once it is moving smoothly, put the cover back on, and begin to hand tighten the nuts. Just before they begin to get tight, eyeball where the chain tensioner pin is in relation to the hole it is supposed to go in. Adjust the chain tensioner screw to move the pin towards the hole. When it pops in the hole, continue tightening the nuts by hand until tight. Now you and your partner can let go of the bar. Adjust the chain tensioner for the proper tension in the chain, not too loose, not to tight, refere to your manual. Finish tightening the cover nuts using the universal wrench to the specifications given in the owners manual.
Sep 06, 2011 | Poulan 14" Electric Chainsaw
Clicking sound from rear wheel
If shaft drive, check that the bolts are tight on driveshaft housing and also look for oil leak there.
Check/ Change rear gear oil. Tighten loose bolts
If chain driven, check/ adjust chain tension, a loose chain will make noise.
if chain is dirty it will make noise.
Other than that the only thing i can think of is you have a nail in your tire and your hearing it hit the road everytime it goes around
Dec 03, 2010 | 2007 Triumph Rocket III
Chain saw chain stopped moving
Was it running and shut down and was froze or when you went to restart it was frozen? Two things I have seen cause this other than a seized engine. One - chain bound up. Remove side cover and inspect chain mechanism. Two- the pull cord is bound up. Remove the pull cord cover and inspect.
Jun 15, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
My Liftmaster garage opener won't go up, only down. It's not bound mechanically. I just replaced the shaft assembly because the old one broke. But since I've done that the garage only goes down, it won't...
BE SURE YOU HAVE THE CHAIN/BELT INSTALLED PROPERLY.
IF THE DRIVE IS AT OR NEAR THE UP LIMIT SWITCH THE DOOR CAN'T GO UP.
LOOSEN & REMOVE THE CHAIN/BELT.
TRY RUNNING THE OPENER TO BOTH LIMITS - JUST TO SEE IF IT WORKS.
RUN THE OPENER TO THE DOWN LIMIT.
MOVE THE TROLLEY TO THE CLOSED POSITION - RECONNECT CHAIN/BELT.
HOPE THIS HELPS
Mar 31, 2009 | Sears Craftsman LiftMaster Chamberlain...
Chain is locking up on my chain saw
if the chain get tight the bar is moving. inspect inside the bar for metal burs .does the gear on the end of the bar spin freely, it may need grease/cleaning. are you sure its grabing the bar and the cluth isnt grabbing it?
Mar 28, 2009 | Garden
Poulan Pro 16-Inch 38 cc Anti-Vibration Chainsaw #PP3516AVX Logo
113 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
