Washing machine not draining - Washing Machines
    Brigadier General:
  • 6,277 Answers
As you do not say the make and model I am making a informed guess!
I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Apr 05, 2011
REPLACE PUMP
easy
  • How to Replace a Washing Machine Water Pump: 12 Steps www.wikihow.com/Replace-a-Washing-Machine-Water-Pump
    • 4 MIN
    • 76K VIEWS
    2016-01-08 · Video embedded · How to Replace a Washing Machine Water Pump. Washing machines are durable and expensive appliances. Repairing them is often less expensive than replacing ...
  • Washer Not Draining? Washer Drain Pump Replacement (Part ... www.youtube.com/watch?v=DwV71h86Gxw
    • BY REPAIRCLINIC.COM
    • 3 MIN
    • 381K VIEWS
    2010-05-14 · This video provides step-by-step instructions for replacing the drain pump on top loading direct drive Whirlpool washing machines. The most ...
  • Geeks On Home: How to Replace a Washing Machine Drain Pump www.geeksonhome.com/how_6509829_replace-washing-machine-drain-pump... How to Replace a Washing Machine Drain Pump. Washing machines take the drudgery out of laundry day, and they're a lot easier than using a washbasin or beating ...
  • Related searches for Washing Machines replace pump
  • How To Replace The Pump in a Washing Machine - YouTube www.youtube.com/watch?v=cvyCSQMPkCc
    • BY BUYSPARES
    • 5 MIN
    • 74K VIEWS
    2011-07-13 · For all your washing machine spare parts and accessories, visit: http://bit.ly/1VKQiNZ If the pump in your washing machine is faulty or broken, ...
  • How to Replace the Pump on a Washing Machine - Bosch ' ... www.espares.co.uk/.../how-to-replace-the-pump-on-a-washing-machine- View All Washing Machine Pumps Now » How to Replace the Pump on a Washing Machine - Bosch. Is your washing machine failing to drain following a wash cycle?
  • How to Replace the Pump on a Whirlpool Washing Machine www.geeksonhome.com/...replace-pump-whirlpool-washing-machine.html How to Replace the Pump on a Whirlpool Washing Machine. The pump in a washing machine helps remove the water from the washer's tub. Water comes in through the ...
  • How to replace a washing machine pump on Aeg, Electrolux ... www.youtube.com/watch?v=yrY9R_T8qrY
    • BY HOW-2-REPAIR.COM
    • 10 MIN
    • 17K VIEWS
    2014-03-26 · How to replace a washing machine pump on Aeg, Electrolux, John Lewis, Zanussi washer dryers Please remember to mark us to your ...
  • How to change and replace a washing machine pump on ... www.how-to-repair.com > Home > Washing machines > Pumps After checking that the pump is faulty in our previous tutorials you will need to replace the old washing machine pump with a new one. Disconnect the appliance from ...
  • Whirlpool Washing Machine Pump Parts from RepairClinic.com www.repairclinic.com/.../a11b5c36/Whirlpool-Washing-Machine-Pump-Parts Shop for your Whirlpool Washing Machine Pump from our huge inventory. Return any part for any reason.
  • How to Replace Beko Washing Machine Pump www.how-to-repair.com > Home > Washing machines > Pumps This video will show you how to replace Beko washing machine pump, If your Beko washing machine is not emptying or draining the water then it is a good chance
  • Mar 10, 2016 | Washing Machines
    Tip
    Washing Machines will not rinse or spin
    If the water won't drain out of your washing machine, either something is stuck in the drain hose or pump, or the pump is broken. Both fixes are simple if you're even just a little bit handy with tools. We're showing the repair on a Maytag washing machine.
    What is wrong with a washer that does not spin?
    If your washer fills with water but doesn't agitate, the problem is likely to be a faulty lid switch, a broken belt, or a problem with the motor. (Note: Direct-drivewashing machines do not have belts.) To diagnose the problem, do the following: 1Check the washing machine's spin cycle.
    How to Drain Washing Machine That Won Drain Family Handyman
    Washer Doesnt Agitate or Spin
    Error codes in front load washers
    Washing Machine Not Rinsing How To Fix
    My washing machine stops at Rinse Does not DRAIN or SPIN
    What causes a washing machine not to drain and spin?
    If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing.
    SOLVED Why won my washer spin or drain Kenmore 110 Series Washing Machine
    Maytag Washing Machines will not rinse or spin Google Search
    on Dec 12, 2017 | Washing Machines
    Washer does not spin and drain properly
    How To Fix A Washing Machine That Is Not Spinning or ...
    removeandreplace.com/.../washing-machine-or-washer-dryer-is-not-spin...
    May 15, 2013 - Washing Machine Service Repair Manuals Online Your washing machine is not working properly. It does not spin, won't drain, can't turn on, ...‎Washer Not Draining Water - ‎Washing Machine Service ... - ‎How To Fix A Washing ...
    Washer Repair - Not draining or spinning ... - YouTube
    ? 5:17
    https://www.youtube.com/watch?v=k41abYwM9WY
    Jul 12, 2013 - Uploaded by ApplianceVideo.com
    Washer Repair - Not draining or spinning - Repair & Diagnostic- .... off and my machine spins but it doesn't drain (high spin) does not work.
    Dec 19, 2015 | Whirlpool Cabrio WTW5500BW White 27"...
    Holding water
    Good Day,
    Your washing machine is fully automatic?
    the washing cycle is normal?
    if yes do the same maybe it will help you.
    for the fully automatic washing machine mostly have drain pump, please check the filter of your drain pump, how? remove the cup of your drain pump like a ordinary cup, screw it clock wise or counter clock wise.
    Remove drain pump filter and clean it, some hair pins, cotton buds or coins or any small item that coz of clog up.
    if your washing machine dont have drain pump ,but fully automatic check the drain motor if running or not? how? open the back cover for top loader washing machine only, select spin cycle and press start to see the drain motor running? the drain motor is like a small box with small wire to pull the lever of the drain to remove water inside, if the motor running or pull the lever of the water pipe but water still inside the washing machine, remove the drain cup or cover and clean it or check if have coin or cloth inside that coz of clog or water stuck,
    if the drain pump or drain motor is weak this is will cause and long time draining or totally not running the drain pump or drain motor and its cause of totally stop the cycle of washing machine in rinse time or spin time, because all fully automatic washing machine, after washing cycle the drain pump or drain motor must be on, to remove water before start the next cycle. rinse or spin cycle.
    Nov 02, 2013 | Washing Machines
    Washer won't spin
    Good Day,
    Avanti washer repair
    Good Day,
    Nov 01, 2013 | Washing Machines
    Machine lacked about 23 minutes in cycle, it stopped with lights flashing. It will not drain, therefore cannot spin. It just beeps whenbi try to start it again.
    Good Day,
    Nov 01, 2013 | Whirlpool Cabrio Washing Machines
    Machine stopped in mid cycle with the drain/unlocking light on. No error codes. Machine goes directly to the drain/unlocking position after start. Will not fill, spin, operate. Any ideas?
    Good Day,
    Nov 01, 2013 | Whirlpool WFC7500VW Washer
    Won't drain and showing F 01
    Good Day,
    Oct 31, 2013 | Maytag EPIC MFW9700S Front Load Washer
    Simpson Aquarius washing machine 7kg: water
    SOUNDS LIKE A PLUMBING PROBLEM WITH DRAIN PIPE .YOU COULD FIT NONRETURN VALVE TO DRAIN FROM WASHER BUT THAT WOULD NOT STOP SINK FROM OVER FLOWING
    Jan 08, 2010 | Washing Machines
    Washing Machines Logo
    15 people viewed this question
    Top Washing Machines Experts
