Question about Garden
I have a DewaltDC900KL cordless drill that will not work. The motor will not spin when I press the trigger switch. What could be the problem?
  • 41 Answers
Dewalt cordless drill and drivers are well known for the trigger switches to just quit , and the only way to fix them is a new switch .pull side cap off,. which is held in place with a couple screws . unplug the two wires going to it plug them in new switch ,pretty easy no surprise.
Posted on Apr 05, 2011
Drill burnt out and new motor hasnt solved problem? please help
check trigger switch with a multi-meter for functionality, then check you batteries if still good and further review your wiring connections
Feb 20, 2016 | Drills
Hi used my dual drill last weekend and it seemed fine went to use it this weekend and it dose not work ,both batteries charge but when you press the trigger nothing happens ,I have. Power all round the...
look at the windings in the housing and if they are black not bright brown they will be burnt out Also smell the motor and you will tell if it is burnt as it will smell burnt.
Jun 15, 2013 | Drills
Where can i get a new trigger switch for a kawasaki 19.2v cordless drill?
I have a trigger out of a new drill. My motor went out. Do you want to purchase the switch? deansbarn@hotmail.com
Mar 19, 2011 | kawasaki 19.2V 4 Piece Cordless Tool Kit
How do you know if the trigger is bad? getting dc volts to trigger but nothing out when I press it.
It's not unusual for Dewalt triggers to go bad and it appears you have correctly tested the trigger. You can test the motor by wiring it directly to the battery but hold on to it and only give it a short burst of power so it doesn't spin out of the case. Dewalt triggers are fairly easy to find online but shop around, they're not cheap.
Jan 26, 2011 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Dewalt cordless drill dc988- drill motor works intermitantly when trigger is pulled. Works a little better as it warms up. Im thinking vsr switch, brushes, or motor/armature. please help...
Test the brushes by catching it in a stalled condition when you have it triggered, then rotate it slightly. If it takes off suspect the brushes or a dead segment on the comutator.
If it doesn't respond to this, then consider the VSR trigger... open it and test by bypassing it when in stalled condition...
Mar 20, 2010 | Dewalt 18 Volt Dc988 Hammer Drill,dc825...
Dewalt cordless 12v drill, 3speed model...spinning problem
Sounds like your brushes are either damaged or the armature is failing the current. Remove the brushes first and inspect them, that is where your arcing is coming from. If the brushes appear ok, your problem is in the armature itself. Regardless of low use, if you store the unit with the battery attached, there are issues with the current draw while stored.
Jan 17, 2010 | Garden
Black Max 24v Cordless Drill/Driver Model 33643-24v. How do you insert the drill bit? I can't "unscrew" the top and am sure I'm doing it wrong...(as it doesn't work)
grab the top by where the drill bit goes in and press the trigger on the drill motor. The direction of rotation will tighten or loosen the Jaws of the chuck.
Jun 14, 2009 | Mx Black Max 24v Cordless 1/2 Inch Drill /...
Makita 14.4V Cordless Impact Driver only works at high speed
Most cordless drill / drivers like this have electronic switchs which unfortunately would have to be fixed by a repair agent. Depending on it's age - make sure that you tell the agent that it never really worked properly, warrentys only cover parts that were faulty from manufacture and not wear and tear, so it may get fixed for free depending on the repair centre
May 18, 2009 | Makita 3/8" Dr. 14.4V Cordless Drill Kit
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
