Question about Maytag Washing Machines
How to change Maytag Neptune Washer Boot Drain 12002533
  • 23 Answers
You should just have to take the back panel off. and you should see the drain pump and where it the hose that goes from the tub to the drain pump. its not very fun to do. make sure you have channel locks and vise grips are also nice sometimes. and watch out for your fingers they might get pinched. good luck
Posted on Aug 06, 2008
Rubber seal is **** and water leaks every wash, Can you help!
Try checking out the site below:
And tips with pictures can be found here:
I stumbled upon this while having another issue with a later model Neptune. This didn't fix my problem, but this sounds like something you may want to look into.
Here's a link from that points to a replacement seal if you need one:
Not sure if that'll do the trick, but worth a look! I hope that helps!
Jul 07, 2011 | Maytag Neptune MAH5500B Front Load Washer
Sometimes there is water that fills in my washer after I use it. It does not happen right away but by the next day. I don't know the model but I do know this is an old have had it for...
Q - My washer seems to keep filling  with water, the water keeps coming in the washer and going out the drain without the washermotor running.
A - This often is a drain hose that is too low or a drain hose that has been pushed too far down inside the stand pipe....the water is actually siphoning out of the washer. Do not "seal" the drain hose to the house plumbing pipe, this will also allow the water to be siphoned out.
  1. Boot change helps
  2. Consumer Display Code Table on the Electronic Display Maytag Neptune Front load washer
  3. Free on-line repair manual for the Neptune washer MAH3000, MAH4000, MAH5500, MAH7500  ( Acrobat reader required )
  4. How to access the console on the mechanical timer models
  5. How to access the workings of the washer
  6. My washer door is locked and it will not open up...HELP
  7. My washer will start when I push the start button, but a few seconds later, it will shut off
  8. My washer will not pump out + pump noise problems
  9. My washer will not spin
  10. Odor complaints from the front load Neptune washer - mildew complaints + a new "freshen up" procedure
  11. Parts breakdowns/exploded of the Maytag Neptune front load washer ( mechanical timer models )
  12. Problem chart for MAH3000 & 4000 Neptune washers
  13. Readers repair tips
  14. Trouble shooting tips from the Neptune manual for MAH3000 and MAH4000 models
  15. Tips from our friendly engineer on changing the boot and re-installing that clamp and spring
  16. Tips on changing the washer belt  ( acrobat reader required ) Belt parts link
  17. Tips that show what components need to be checked/replaced if a certain resistor on machine control board is bad. It is as follows: Burnt resistors in Maytag Neptune washer models MAH4000 and MLE/MLG2000
  18. Washing one item in a front load washer
Apr 01, 2009 | Maytag Washing Machines
MAH4000AWW- Boot Seal
ngfam1 At your service!
It is is normal for the Neptune to have water left in the inner tub after the wash finishes!
I used to have a Neptune and I sold them too!!
I had them change that drain under warranty when it was new and it never stopped the smell or the mold!
After the third repair I threw it in the trash and bought a Speed Queen Commercial grade washer and thats the last one I will ever by!
8 loads a week for 25 years!!!!!!!
The moldy oder problem is in every Maytag Neptune made!
The Neptune comes new with water in it from the test run!
All the water never gets totally discharged. This is one reason why everyone complains about the moldy, musky or even stinky smell of the Neptune! Every day I have people here asking what too do about the moldy wet smell!
I do tell them to run the washer once a week without clothes and with hot water and 1/4 cup of bleach. And then make suer to do only white clothes directly after wards as not to get a drop of beach water on a colored article of clothing!
Then leave the door open after every load when not in use!
That's Maytag!!!!!!!!
Perhaps they will make some good changes!!
Hope this helps and makes you feel a little better as to some water sounds! HOW OLD IS THE WASHER??????
Below I referred you to a great service nation wide!
If none of these tasks remedy the heat problem then here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
You will be fine
Bless You ngafm1
Aug 29, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune Washer Boot Drain 12002533 installation
its is hard to do if you have some one to help makes it easer to hold on put a thin piece ribbben strong and then pull it will go on
Feb 29, 2008 | Washing Machines
Maytag neptune mah5500bww leaking water
Here is the solution I found that worked for me, there is a small drain hole at the bottom of the boot that is connected to a drain hose. Remove the hose and clean out to make sure that it has not become plagged. replace hose and reattach boot. Mine stoped leaking imediately.
Feb 22, 2008 | Maytag Neptune MAH5500B Front Load Washer
Change rubber gasket
Remove the door hinges and plastic covers on the unused hinge screw holes on the opposite side of the door opening (door is reversable, so there are places to mount hinges left and right). Front panel will now snap out at top and lift off lower spring clips. One screw on each side will now release top panel and it will hinge up. Prop up with broom handle or something. Now you can get at everthing. Rubber gasket is held onto drum with a cable loop and very strong spring. It rolls off the lip easily to disassemble but is VERY difficult to get back on without special tools or at least two people. We used strong vice grips and much struggling and sweat, and #@*&%!&@ and finally got it on without damage to the new gasket. Door side of rubber gasket is easy in comparison with rubber tabs inserted into slots and working the gasket into a groove. Hose clamp at bottom of rubber gasket to connect drain hose.
Sep 05, 2007 | Maytag Neptune MAH5500B Front Load Washer
Open Questions:
Washing Machines Logo
182 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
