Question about Car Audio & Video
Auto CD changer
Cannot insert CD into changer
  • Anonymous Aug 09, 2008
    Had the CD cassette stuck in another model, and there was a "fix' where you could stuck your credit card down inside the changer and jiggle it, and it would release the cd cassette. Tried same thing with the Pioneer CDX-P670 and couldn't make it work.
    Any other bright ideas for fixing a constipated CD cassette?
I have 10 cd changer model cdc717 cd eject problem e99 is displaying
Posted on Aug 17, 2008
SOURCE:
No power to the disc changer, how do I manually eject the magazine
There is a manual eject slot on the side of the CD changer. You will need a small flat head screwdriver or a pry tool to insert into the slot.
Oct 11, 2012 | Kenwood KDC-C715 10 Disc CD Changer
Jvc ch-x350 12 disc cd changer. Loads cd but will not play it. reads: no disc and moves to the next cd and repeats. ??
If you are inserting non original cds, cds you make from your pc or cd copies sometimes they dont read, another reason is to make sure that you are inserting the disk with the correct side up, it will show you in the cd changer magazine slots. If none of this solves your problem then you have a defective cd mechanism and you need to replace or repair the changer. Very common problem with JVC Cd Changers, I used to replace them all the time and they tend to skip alot as well, get yourself a Pioneer if money is ok if not then follow my steps.
Good luck and dont forget to rate and vote for me if I helped you.
Thanks.
Jun 13, 2010 | JVC CH-X350 12-Disc CD Changer
My BMW X5 6 CD Alpine changer is jammed and will not work. How do I fix it and remove the disk?
If the issue is you cannot eject the cartridge this would be simple.
Slide the changer door open as if ejecting the cartridge. Take a credit card/driver license and insert about 2 to 3 inches between cartridge and chassis. You should hear a click and the cartridge should eject.
Once the cartridge is out check to make sure there isnt a stuck CD in the changer. If there is remove the loose CD. If the CD is stuck in the player itself insert the empty cartridge the changer will cycle through the process. Once it stops you can press eject button and the CD should be in the cartridge.
Feb 25, 2010 | Alpine Car Audio & Video
Eurovox 'Maestro Series' 10 stacker displaying 'E-99'
CD ERROR DISPLAYS
CD Changers
E01:
The disc magazine is not inserted in the cd changer
E02:
No disc is inserted in the disc magazine
E04:
The disc is dirty, or the disc is inserted into the disc magazine
upside down
E99 RESET PROCEDURE:
Remove CD magazine by pressing eject button on changer.
Remove all discs from magazine and re-load empty magazine into
changer. Using the Radio RESET CD system by pressing and
holding the “ON”/”POWER” button for about ten seconds, or in
earlier models the “EJECT/6” button.
FM/RF Remote Controls
E99 RESET PROCEDURE FOR REMOTES:
Remove disc magazine from changer by pressing eject button.
changer. Press RESET button on interface unit
WAIT:
The temperature is exceeding more than 55c(130f) and the cd
changer cannot be operated. When the cd changer cools off, this
wait disappears. When the RESET button on the interface unit is
pressed, this WAIT appears for a few seconds.
IF THESE ERROR CODES STILL KEEP APPEARING
CONTACT YOUR DEALER.
Jun 21, 2009 | iLO CA3000V CD Player
CD ERROR DISPLAYS
CD Changers
E01:
E02:
E04:
upside down
WAIT:
Jun 14, 2009 | iLO CA3000V CD Player
How do you reset a 6 disc cd changer in 1999 VW Beetle?
1st just try unplugging the changer overnight. also check and see if a cd may be inserted into the cd mech itself.
May 15, 2009 | Alpine CHAS-634 6-Disc CD Changer
2002 infiniti i35 cd 6 changer
The 6 cd changer should be located in the trunk eith on the right or left side. I hopre this helps you. Don't forget to rate my answer.
Feb 12, 2009 | 2004 Infiniti I35
Panasonic stereo with 5-cd changer
Hi, I have a Panasonic SA-ak25 system. I played one cd then inserted a second. When the second cd had finished it ejected but the first cd is still in the player, When i try to eject it the lights start to flash and it always stops on no (4) can anybody help. Bob.
Jun 15, 2008 | Audio Players & Recorders
Car Audio & Video Logo
158 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
